[资料分享] 对于CC2640R2f 看门狗可以这样
Jacktang   2020-2-5 10:01 楼主
在TI的官方例程中就有看门狗的用法,例如:
C:\ti\simplelink_cc2640r2_sdk_2_40_00_32\examples\rtos\CC2640R2_LAUNCHXL\drivers\watchdog
这是我的SDK目录下的看门狗工程,
因为官方已经封装好了代码,所以在我们使用 看门狗的时候,直接调用即可,
头文件
#include <ti/drivers/Watchdog.h>
函数
    Watchdog_init();
    /* Open a Watchdog driver instance */
    Watchdog_Params_init(&params);
    params.callbackFxn = (Watchdog_Callback) watchdogCallback;
    params.debugStallMode = Watchdog_DEBUG_STALL_ON;
    params.resetMode = Watchdog_RESET_ON;
    watchdogHandle = Watchdog_open(Board_WATCHDOG0, &params);
    if (watchdogHandle == NULL) {
        /* Error opening Watchdog */
        while (1) {}
还需要一个看门狗回调函数
void watchdogCallback(uintptr_t watchdogHandle)
     * If the Watchdog Non-Maskable Interrupt (NMI) is called,
     * loop until the device resets. Some devices will invoke
     * this callback upon watchdog expiration while others will
     * reset. See the device specific watchdog driver documentation
     * for your device.
    while (1) {}
以上函数就开启了看门狗,使用:
 Watchdog_clear(watchdogHandle);
清楚看门狗计数器,这种模式下的看门狗是重启的,
例如说:想让看门狗报警十次再重启设备,可以修改参数
typedef enum Watchdog_ResetMode_ {
    Watchdog_RESET_OFF, /*!< Timeouts generate interrupts only */
    Watchdog_RESET_ON   /*!< Generates reset after timeout */
} Watchdog_ResetMode;
修改成
params.resetMode = Watchdog_RESET_OFF;
则看门狗就成中断函数,然后在看门狗回调函数里面加上
    Watchdog_init();
    /* Create and enable a Watchdog with resets disabled */
    params.callbackFxn = (Watchdog_Callback)watchdogCallback;
//---------------看门狗回调---------------
void watchdogCallback(uintptr_t unused)
    /* Clear watchdog interrupt flag */
    static int WDT_flag = 0;
    if(WDT_flag++ > 10){
        SystemReset();//重启函数
    /* Insert timeout handling code here. */
回复评论
暂无评论,赶紧抢沙发吧
    写回复
