无意中看到一个介绍各种语言计算任意精度圆周率的网站,常见的编程语言都有,分享给大家。
https://rosettacode.org/wiki/Pi
10 PRINT CHR$(147)
20 n = 100
30 ln = int(10*n/4)
40 nd = 1
50 dim a(ln)
60 n9 = 0
70 pd = 0 :rem First predigit is a 0
80 :
90 for j = 1 to ln
100 a(j-1) = 2 :rem Start with 2s
110 next j
120 :
130 for j = 1 to n
140 q = 0
150 for i = ln to 1 step -1 :rem Work backwards
160 x = 10*a(i-1) + q*i
170 a(i-1) = x - (2*i-1)*int(x/(2*i-1)) :rem X - INT ( X / Y) * Y
180 q = int(x/(2*i - 1))
190 next i
200 a(0) = q-10*int(q/10)
210 q = int(q/10)
220 if q=9 then n9 = n9 + 1 : goto 450
240 if q<>10 then 350
250 rem q == 10
260 d = pd+1 : gosub 500
270 if n9 < 0 then 320
280 for k = 1 to n9
290 d = 0: gosub 500
300 next k
310 rem end if
320 pd = 0
330 n9 = 0
335 goto 450
340 rem q <> 10
350 d = pd: gosub 500
360 pd = q
370 if n9 = 0 then 450
380 for k = 1 to n9
390 d = 9 : gosub 500
400 next k
410 n9 = 0
450 next j
460 print mid$(str$(pd),2,1)
470 end
480 :
490 rem outputd
500 if nd=0 then print mid$(str$(d),2,1); : return
510 if d=0 then return
520 print mid$(str$(d),2,1);".";
530 nd = 0
550 return
def calcPi():
q, r, t, k, n, l = 1, 0, 1, 1, 3, 3
while True:
if 4*q+r-t < n*t:
yield n
nr = 10*(r-n*t)
n = ((10*(3*q+r))//t)-10*n
q *= 10
r = nr
else:
nr = (2*q+r)*l
nn = (q*(7*k)+2+(r*l))//(t*l)
q *= k
t *= l
l += 2
k += 1
n = nn
r = nr
import sys
pi_digits = calcPi()
i = 0
for d in pi_digits:
sys.stdout.write(str(d))
i += 1
if i == 40: print(""); i = 0
type AnyWriteableObject={write:((textToOutput:string)=>any)};
function calcPi(pipe:AnyWriteableObject) {
let q = 1n, r=0n, t=1n, k=1n, n=3n, l=3n;
while (true) {
if (q * 4n + r - t < n* t) {
pipe.write(n.toString());
let nr = (r - n * t) * 10n;
n = (q * 3n + r) * 10n / t - n * 10n ;
q = q * 10n;
r = nr;
} else {
let nr = (q * 2n + r) * l;
let nn = (q * k * 7n + 2n + r * l) / (t * l);
q = q * k;
t = t * l;
l = l + 2n;
k = k + 1n;
n = nn;
r = nr;
calcPi(process.stdout);
