串口读不出数据
xdz123   2009-4-7 15:17 楼主
协议通信格式是:9600bpsd、8位数据位、无校验位的异步通讯方式.通过RS232连接串口.
我发送命令后程序读不出数据,read后显示读的数据字节数为0.调试了两天,还是读不出数据,郁闷.高手帮我看看问题在那,先谢谢了.
int SpeedArr[] = {B115200, B38400, B19200, B9600, B4800, B2400, B1200, B300,
         B38400, B19200, B9600, B4800, B2400, B1200, B300,};
int NameArr[] = {115200, 38400, 19200, 9600, 4800, 2400, 1200, 300,
         38400, 19200, 9600, 4800, 2400, 1200, 300,};
int OpenSerial(char *pDev)
        int fd;
//        fd  = open(pDev, O_RDWR | O_NDELAY);
        fd  = open(pDev, O_RDWR);
        if (-1 == fd)
                perror("open()");
                return -1;
        } else {
                return fd;
int SetSerialSpeed(int fd, int nSpeed)
        int i;
        int Status;
        struct termios Opt;
        tcgetattr(fd, &Opt);
        for (i = 0; i < sizeof(SpeedArr) / sizeof(int); i++)
                if (nSpeed == NameArr)
                        tcflush(fd, TCIOFLUSH);
                        cfsetispeed(&Opt, SpeedArr);
                        cfsetospeed(&Opt, SpeedArr);
                        Status = tcsetattr(fd, TCSANOW, &Opt);
                        if (Status != 0)
                                perror("(tcsetattr)");
                                return -1;
        return 0;
int SetSerialParity(int fd, int nDatabits, int nStopbits, int nParity)
        int Status;
        struct termios Opt;
        if (tcgetattr(fd, &Opt) != 0)
                perror("SetupSerial Fail");
                return -1;
//        Opt.c_cflag &= ~CSIZE;
//        Opt.c_cflag &= ~CRTSCTS;
//        Opt.c_cflag |= CLOCAL;
//        Opt.c_cflag |= CREAD;
//        Opt.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG); //Set Serial Raw
//        Opt.c_cflag &= ~(ICANON | ECHOE); //Set Serial Raw
//        Opt.c_lflag &= ~OPOST;
(怀疑是这里的问题)
        Opt.c_iflag&=~(IGNBRK|IGNCR|INLCR|ICRNL|IUCLC|IXANY|IXON|IXOFF|INPCK|ISTRIP);
        Opt.c_iflag|=(BRKINT|IGNPAR);
        Opt.c_oflag&=~OPOST;
        Opt.c_lflag&=~(XCASE|ECHONL|NOFLSH);
        Opt.c_lflag&=~(ICANON|ISIG|ECHO);
        Opt.c_cflag|=(CLOCAL|CREAD);
        switch (nDatabits)
                case 7:
                        Opt.c_cflag |= CS7;
                        break;
                case 8:
                        Opt.c_cflag |= CS8;
                        break;
                default:
                        fprintf(stderr, "Unsupported data size\n");
                        return -1;
        switch (nParity)
                case 'n':
                case 'N':
                        Opt.c_cflag &= ~PARENB;
                        Opt.c_iflag &= ~INPCK;
                        break;
                case 'o':
                case 'O':
                        Opt.c_cflag |= (PARODD | PARENB);
                        Opt.c_iflag |= INPCK;
                        break;
                case 'e':
                case 'E':
                        Opt.c_cflag |= PARENB;
                        Opt.c_cflag &= ~PARODD;
                        break;
                case 's':
                case 'S':
                        Opt.c_cflag &= ~CSTOPB;
                        break;
                default:
                        fprintf(stderr, "Unsupported parity\n");
                        return -1;
        switch (nStopbits)
                case 1:
                        break;
                case 2:
                        Opt.c_cflag |= CSTOPB;
                        break;
                default:
                        fprintf(stderr, "Unsupported stop bits\n");
                        return -1;
        if (nParity != 'n')
        tcflush(fd, TCIFLUSH);
        Opt.c_cc[VTIME] = 150;
        Opt.c_cc[VMIN]  = 0;
        if (tcsetattr(fd, TCSANOW, &Opt) != 0)
                perror("SetupSerial 3");
                return -1;
        return 0;
int GetAlarmInfoCmd(void)
        int ret;
        BYTE sbuff[14];
        sbuff[0] = 0x48;
        sbuff[1] = 0x4E;
        sbuff[2] = 0x54;
        sbuff[3] = 0x09;
        sbuff[4] = 0x1F;
        sbuff[5] = 0x07;
        sbuff[6] = 0xFF;
        sbuff[7] = 0xFF;
        sbuff[8] = 0xFF;
        sbuff[9] = 0xFF;
        sbuff[10] = 0xFF;
        sbuff[11] = 0x15;
        sbuff[12] = 0x44;
        sbuff[13] = 0x7A;//后面加一个字节0x0D也不行
        ret = write(HDSerialFd,&sbuff,14);
        if(ret < 0)
                PrintMsg("Send get alarm cmd failed!\n");
                return -1;
        return ret;
int main(void)
    fd = OpenSerial(SERIAL_PATH);
    if (fd > 0) {
        SetSerialSpeed(fd, 9600);
        SetSerialParity(fd, 8, 1, 'N');
   while(1)
     GetAlarmInfoCmd();
     sleep(1);
     ret = read(fd,buff,len);//一直读不到数据.ret =0;
用串口调试助手发送命令48 4e 54 09 1f 07 ff ff ff ff ff 15 44 7a可以收到数据,程序却收不到.
回复评论 (20)
先设置断点看看,如果程序没问题(主要是波特率)那就要查查是不是硬件电路的问题了,我前段时间也遇到这个问题,是多接了个232导致的
点赞  2010-4-23 10:14
请问你的问题解决了没,我也遇到了跟你一样的问题
点赞  2010-4-22 08:56
我试了一天就成功了。你太笨,这是根本原因。
点赞  2010-4-24 07:41
你先在网上下个虚拟串口配合proteus仿真下看看就知道了。想深入学习,推荐网站www.pubembed.com,咨询QQ:104262585
点赞  2010-4-26 15:49
你带的是linux系统啊?你下载一个能直接用的调试工具,看看那个系统上的串口驱动是否可用。
点赞  2010-4-27 09:54
周工开发网-淘宝店开张!
三款周立功99元开发板,非常适合初学者,资料丰富价格便宜。
EasyARM1138  (内嵌USB仿真器的Cortex-M3开发板)
EasyARM2103  (arm7内核开发板)
EasyFPGA030  (FPGA开发板)
详情如下:
www.01zg.com
点赞  2009-4-7 16:40
open(MODEMDEVICE, O_RDWR | O_NOCTTY | O_NONBLOCK);
要加一个 NONBLOCK 上去,要不然,你的程序一直等到一整块数据到
点赞  2010-5-10 16:04
UPUPUPUPUPUPUPUPUPUPUPUPUPUPUPUPUPUPUPUPUPUPUPUP
点赞  2010-5-10 19:09
我遇到了收发数据都是乱码的问题
点赞  2010-5-12 09:35
我遇到了收发数据都是乱码的问题
点赞  2010-5-12 09:35
你应该在Windows下用串口测试软件测试先一下,如果你用的是STC的51,还可以直接用
STC的烧写软件进行串口测试,里面有个“串口调试助手”,先保证下位机程序和电路没问
题了再去看你的上位机程序是不是有问题。
点赞  2009-4-8 06:33
13楼 站台的滚 该用户已被删除
提示: 作者被禁止或删除 内容自动屏蔽
点赞  2009-4-7 17:46
在linux下收发数据,打开串口 是成功的,就是向写命令后没有数据返回,读不到数据。
点赞  2009-4-7 18:19
按照仪器厂家提供的通信协议,我用串口调试助手向串口发送命令48 4e 54 09 1f 07 ff ff ff ff ff 15 44 7a后有数据返回,但代码读不到数据。,我想请教下串口设置中termios结构一般怎么设置,和具体硬件相关么?
点赞  2009-4-7 18:25
楼上
如果是32位机,那么一个int是4个字节 sizeof(int) = 4;
有没有超限要看他用的是什么系统,不过,上Linux多半是32位的CPU
点赞  2010-5-12 23:16
为了避免出错,我都是÷100的!
点赞  2010-5-13 08:27
下个断点看看呗.这个东西认真调就可以了.
点赞  2010-5-13 10:38
问题解决了吗
点赞  2010-5-13 10:50
数组超出范围了!
115200=0x1c200
大于定义的INT 的0xffff。
点赞  2010-5-12 15:57
12下一页
    写回复
