来自:https://www.hackster.io/amoghsawant2000/morse-code-lamp-e4b7de
参考程序
from boltiot import Bolt
import time
api_key = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx" # your bolt api key
device_id = "xxxxxxxxxx" #your bolt device id
mybolt = Bolt(api_key, device_id)
# morse code dictionary; source: https://en.wikipedia.org/wiki/Morse_code
morse_code_dict = {"A":"._", "B":"_...", "C": "_._.", "D": "_..", "E": ".", "F": ".._.",
"G": "__.", "H": "....", "I": "..", "J": ".___", "K": "_._", "L": "._..",
"M": "__", "N": "_.", "O": "___", "P": ".__.", "Q": "__._", "R": "._.",
"S": "...", "T": "_", "U": ".._", "V": "..._", "W": ".__", "X": "_.._",
"Y": "_..__", "Z": "__..", "1": ".____", "2": "..___", "3": "...__", "4": "...._",
"5": ".....", "6": "_....", "7": "__...", "8": "___..", "9": "____.", "0": "_____", " ": ""}
def list_to_string(s): # helper function to convert list to string
string = ""
for letter in s:
string += letter
return string
def filtered_string(string): # this function filter unnecessary symbols from the important message
ignore = "~`!@#$%^&*()_+{}|[]\:'<>?,./';-="
# converting to list because strings are immutable
string = list(string)
ignore = list(ignore)
for i in range(len(string)):
for j in range(len(ignore)):
if string[i] == ignore[j]:
string[i] = ""
string = (list_to_string(string)).upper()
return string
def morse_code_converter(string): # function to convert main message to morse code
string = filtered_string(string)
morse_code = ""
print("Filtered string: ", string)
for i in string:
morse_code = morse_code + morse_code_dict[i] + " "
return morse_code
def led_blink(code): # function to blink the led on bolt according to dits and dahs in morse code
# time gaps are according to the source: http://www.morsecodeclassnet.com/lesson3/
for i in code:
if i == ".": # dit
mybolt.digitalWrite('0', 'HIGH')
time.sleep(0.1)
mybolt.digitalWrite('0', 'LOW')
elif i == "_": #dah
time.sleep(0.3)
elif i == " ": # space between letters and words
time.sleep(0.3)
string = input("Enter the string (type '-exit' to quit): ")
while string != "-exit":
morse_code = morse_code_converter(string)
print(morse_code)
led_blink(morse_code)
# you can check the output of the code by verifing through this website: https://morsecode.world/international/translator.html
引用: maychang 发表于 2020-4-20 17:39 用个蜂鸣器取代发光管,不是更好? 用发光管 的话,眼睛看着发光管,怎么纪录收到的摩尔斯电码?
航海中是用光发莫尔斯码信号的,声音是在电影中用的,如果做实验用声音,调试时会让其他人受不了的。
原文中也提到了用蜂鸣器代替LED,在电路上是比较容易的。
引用: dcexpert 发表于 2020-4-20 22:55 航海中是用光发莫尔斯码信号的,声音是在电影中用的,如果做实验用声音,调试时会让其他人受不了的。 ...
两船之间若使用声音传递莫尔斯码信号,接收方根本听不见。
实验时戴上耳机就是了。实际上接收莫尔斯码信号也都是用耳机的。
