GPIO_PinConfig gpioPinConfigs[] = {
/* ADS1261*/
GPIOCC26XX_DIO_30 | GPIO_DO_NOT_CONFIG, /* CS 已100K上拉,输入,低有效,SPI CS pin*/
GPIOCC26XX_DIO_15 | GPIO_DO_NOT_CONFIG, /* PWDN 已100K上拉,输入,低有效 power down */
GPIOCC26XX_DIO_21 | GPIO_DO_NOT_CONFIG, /* STR 已100K上拉,输入,高有效 启动转换*/
GPIOCC26XX_DIO_25 | GPIO_DO_NOT_CONFIG, /* RST 已100K上拉,输入,低有效 复位 */
GPIOCC26XX_DIO_26 | GPIO_DO_NOT_CONFIG, /* DRDY 无上拉,输出,低有效,数据准备就绪*/
const *** ***[CC26X2R1_LAUNCHXL_SPICOUNT] = {
.baseAddr = SSI1_BASE,
.intNum = INT_SSI1_COMB,
.intPriority = ~0,
.swiPriority = 0,
.powerMngrId = PowerCC26XX_PERIPH_SSI1,
.defaultTxBufValue = 0xFF,
.rxChannelBitMask = 1<<UDMA_CHAN_SSI1_RX,
.txChannelBitMask = 1<<UDMA_CHAN_SSI1_TX,
.mosiPin = CC26X2R1_LAUNCHXL_SPI1_MOSI,
.misoPin = CC26X2R1_LAUNCHXL_SPI1_MISO,
.clkPin = CC26X2R1_LAUNCHXL_SPI1_CLK,
.csnPin = PIN_UNASSIGNED, //单独控制 【E2E LINK】
.minDmaTransferSize = 10
/* ADS 1261 */
#define CC26X2R1_LAUNCHXL_SPI1_MISO IOID_27
#define CC26X2R1_LAUNCHXL_SPI1_MOSI IOID_28
#define CC26X2R1_LAUNCHXL_SPI1_CLK IOID_29
#define CC26X2R1_LAUNCHXL_SPI1_CSN IOID_30
#define CC26X2R1_LAUNCHXL_ADS1261_PWDN IOID_15 /* 已100K上拉,输入,低有效 power down */
#define CC26X2R1_LAUNCHXL_ADS1261_STR IOID_21 /* 已100K上拉,输入,高有效 启动转换*/
#define CC26X2R1_LAUNCHXL_ADS1261_RST IOID_25 /* 已100K上拉,输入,低有效 复位 */
#define CC26X2R1_LAUNCHXL_ADS1261_DRDY IOID_26 /* 无上拉,输出,低有效,数据准备就绪*/
新增如下红色项
typedef enum CC26X2R1_LAUNCHXL_GPIOName {
CC26X2R1_LAUNCHXL_GPIO_S1 = 0,
CC26X2R1_LAUNCHXL_GPIO_S2,
CC26X2R1_LAUNCHXL_GPIO_LED_GREEN,
CC26X2R1_LAUNCHXL_GPIO_LED_RED,
CC26X2R1_LAUNCHXL_GPIO_TMP116_EN,
CC26X2R1_LAUNCHXL_GPIO_SPI_FLASH_CS,
CC26X2R1_LAUNCHXL_SDSPI_CS,
CC26X2R1_LAUNCHXL_GPIO_LCD_CS,
CC26X2R1_LAUNCHXL_GPIO_LCD_POWER,
CC26X2R1_LAUNCHXL_GPIO_LCD_ENABLE,
CC26X2R1_LAUNCHXL_GPIO_ADS1261_CS, /* IOID_30 已100K上拉,输入,低有效,SPI CS pin*/
CC26X2R1_LAUNCHXL_GPIO_ADS1261_PWDN,/* IOID_15,已100K上拉,输入,低有效 power down */
CC26X2R1_LAUNCHXL_GPIO_ADS1261_STR, /* IOID_21,已100K上拉,输入,高有效 启动转换*/
CC26X2R1_LAUNCHXL_GPIO_ADS1261_RST, /* IOID_25已100K上拉,输入,低有效 复位 */
CC26X2R1_LAUNCHXL_GPIO_ADS1261_DRDY, /* IOID_26无上拉,输出,低有效,数据准备就绪*/
CC26X2R1_LAUNCHXL_GPIOCOUNT
} CC26X2R1_LAUNCHXL_GPIOName;
GPIO_setConfig(CC26X2R1_LAUNCHXL_GPIO_ADS1261_CS, GPIO_CFG_OUT_OD_NOPULL|GPIO_CFG_OUT_HIGH); GPIO_setConfig(CC26X2R1_LAUNCHXL_GPIO_ADS1261_PWDN, GPIO_CFG_OUT_OD_NOPULL|GPIO_CFG_OUT_HIGH);
GPIO_setConfig(CC26X2R1_LAUNCHXL_GPIO_ADS1261_STR, GPIO_CFG_OUT_OD_NOPULL);
GPIO_setConfig(CC26X2R1_LAUNCHXL_GPIO_ADS1261_RST, GPIO_CFG_OUT_OD_NOPULL|GPIO_CFG_OUT_HIGH);
GPIO_setConfig(CC26X2R1_LAUNCHXL_GPIO_ADS1261_DRDY, GPIO_CFG_IN_PU);
/* Open SPI as master (default) */
SPI_Params_init(&spiParams);
spiParams.frameFormat = SPI_POL0_PHA1;
spiParams.bitRate = 4000000;
masterSpi = SPI_open(CC26X2R1_LAUNCHXL_SPI1, &spiParams);
if (masterSpi == NULL) {
Display_printf(display, 0, 0, "Error initializing master SPI\n");
while (1);
else {
Display_printf(display, 0, 0, "Master SPI initialized\n");
其它改动这里不进一步赘述,请通过link获得代码工程,自行编译测试。
测试代码会循环读写ADS1261内部寄存器,并会在最后读取ADS1261内u,其中“T:”表示CC2652 SPI口发送的数据,“R:”表示CC2652 SPI口接收到的数据,均为十六进。
Starting the SPI master example
T:4100
R:FF41
T:4224
R:FF42
T:4301
R:FF43
T:4400
R:FF44
T:4520
R:FF45
T:4605E900
R:FF4605E9
T:4700E700
R:FF4700E7
T:48002400
R:FF480024
T:49003100
R:FF490031
T:4A000E00
R:FF4A000E
T:4B001B00
R:FF4B001B
T:4C40B700
R:FF4C40B7
T:4DFF9600
R:FF4DFF96
T:4E005A00
R:FF4E005A
T:4F004F00
R:FF4F004F
T:5000DB00
R:FF5000DB
T:51FF3D00
R:FF51FF3D
T:5200F100
R:FF5200F1
T:21006C000000
R:FF21006C00F3
T:220053000000
R:FF220053240F
T:230046000000
R:FF23004601F4
T:24002D000000
R:FF24002D00F3
T:250038000000
R:FF2500382013
T:260007000000
R:FF26000705E8
T:270012000000
R:FF27001200F3
T:2800D1000000
R:FF2800D100F3
T:2900C4000000
R:FF2900C400F3
T:2A00FB000000
R:FF2A00FB00F3
T:2B00EE000000
R:FF2B00EE00F3
T:2C0085000000
R:FF2C00854034
T:2D0090000000
R:FF2D0090FF00
T:2E00AF000000
R:FF2E00AF00F3
T:2F00BA000000
R:FF2F00BA00F3
T:30002E000000
R:FF30002E00F3
T:31003B000000
R:FF31003BFF00
T:320004000000
R:FF32000400F3
T:46108200
R:FF461082
T:5200F100
R:FF5200F1
T:5000DB00
R:FF5000DB
T:51BBE600
R:FF51BBE6
T:08007F00
R:FF08007F
T:0A005500
R:FF0A0055
T:1200AA0000000000
R:FF1200AA0654B219
Tmp:27.9743
void writeMultipleRegisters(uint8_t addr, uint8_t count, const uint8_t data[])
/* Check that register map address range is not exceeded */
assert( (addr + count) <= NUM_REGISTERS );
uint8_t i;
for (i = addr; i < (addr + count); i++)
writeSingleRegister(addr + i, data[i]); // 第一个值将是addr+addr
修改为:
uint8_t i;
writeSingleRegister(i, data[i]);
