我写了个矩阵键盘程序,有点问题,有时按下一个按键,返回两次键值,有时返回0(没有检测到按键)
我调试,返回键值,通过网口发送到网络调试助手。
原理图:
//初始化PA8和PD2为输出口.并使能这两个口的时钟
//LED IO初始化
void KEY_Init(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOE, ENABLE); //使能PA,PD端口时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6; //LED0-->PA.8 端口配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz
GPIO_Init(GPIOE, &GPIO_InitStructure); //根据设定参数初始化GPIOA.8
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 ; //LED0-->PA.8 端口配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //推挽输出
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9; //LED1-->PD.2 端口配置, 推挽输出
GPIO_Init(GPIOB, &GPIO_InitStructure); //推挽输出 ,IO口速度为50MHz
void Hang_Output(void)
void Hang_Input(void)
void Lie_Input(void)
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //推挽输出
void Lie_Output(void)
unsigned char GetKey(void)
unsigned char keyvalue = 0;
uint16_t hangvalue=0,lievalue=0;
// 第1回合第1步
KEY_Init();
delay_us(20);
GPIO_ResetBits(GPIOE,GPIO_Pin_6); //PE.6 输出低
GPIO_ResetBits(GPIOE,GPIO_Pin_5); //PE.5 输出低
GPIO_ResetBits(GPIOE,GPIO_Pin_4); //PE.4 输出低
GPIO_ResetBits(GPIOE,GPIO_Pin_3); //PE.3 输出低
hangvalue=(GPIO_ReadInputData(GPIOE)&0x07)+((GPIO_ReadInputData(GPIOB)&0x0380)>>4);
if (hangvalue != 0x3f)// 从IO口输入,读IO口
// 读出的不是0x0f说明有按键被按下
// 第1回合第2步:读出端口从读出值来判断是哪一行
delay_ms(20);
Hang_Output();
Lie_Input();
delay_us(20);
// 第一回合中算出行号
switch (hangvalue)
case 0x1F:
GPIO_ResetBits(GPIOB,GPIO_Pin_9);
lievalue=((GPIO_ReadInputData(GPIOE)&0x78)>>3);
switch(lievalue)
case 0x07:
keyvalue=4;
break;
case 0x0b:
keyvalue=9;
break;
case 0x0d:
keyvalue=14;
break;
case 0x0e:
keyvalue=20;
break;
default :
break;
break;
case 0x2F:
GPIO_ResetBits(GPIOB,GPIO_Pin_8);
switch(lievalue)
case 0x07:
keyvalue=5;
break;
case 0x0b:
keyvalue=10;
break;
case 0x0d:
keyvalue=15;
break;
case 0x0e:
keyvalue=21;
break;
default :
break;
break;
case 0x37:
GPIO_ResetBits(GPIOB,GPIO_Pin_7);
switch(lievalue)
case 0x07:
keyvalue=6;
break;
case 0x0b:
keyvalue=11;
break;
case 0x0d:
keyvalue=16;
break;
case 0x0e:
keyvalue=22;
break;
default :
break;
break;
case 0x3B:
GPIO_ResetBits(GPIOE,GPIO_Pin_2);
switch(lievalue)
case 0x07:
keyvalue=1;
break;
case 0x0b:
keyvalue=6;
break;
case 0x0d:
keyvalue=11;
break;
case 0x0e:
keyvalue=17;
break;
default :
break;
break;
case 0x3D:
GPIO_ResetBits(GPIOE,GPIO_Pin_1);
switch(lievalue)
case 0x07:
keyvalue=2;
break;
case 0x0b:
keyvalue=7;
break;
case 0x0d:
keyvalue=12;
break;
case 0x0e:
keyvalue=18;
break;
default :
break;
break;
case 0x3E:
GPIO_ResetBits(GPIOE,GPIO_Pin_0);
switch(lievalue)
case 0x07:
keyvalue=3;
break;
case 0x0b:
keyvalue=8;
break;
case 0x0d:
keyvalue=13;
break;
case 0x0e:
keyvalue=19;
break;
default :
break;
break;
default: break;
Hang_Input();
Lie_Output();
delay_us(20);
while (hangvalue != 0x3f)
return keyvalue;
return 0;
return 0;
大神看看,哪里有问题?谢谢!
楼主电路首先设计的不够好。行列数多于一个8位IO口时,尽量行列单独使用某个IO序列,楼主却把列给拆开了,这会导致程序编制时复杂性提高,容易出错。再有就是工作模式问题,楼主所遇问题只有在不断主动轮询时才可能出现且轮询周期设置不合理。键盘尽量不要用主动轮询,太占计时,功耗也比较大,尽量利用中断来启动键盘扫描,扫描时要有消抖处理。
高度简化的流程:有键按下,启动扫描——判断出扫描值与初值不同,说明确实有键按下——消抖后再次判断——与前值相同则返回键值,不同则放弃。消抖周期一般可取50mS左右。
引用: chunyang 发表于 2020-6-18 13:31 楼主电路首先设计的不够好。行列数多于一个8位IO口时,尽量行列单独使用某个IO序列,楼主却把列给拆开了, ...
谢谢!电路不是我设计的。
