[MCU] 【ESK32-360测评】+基于MX25L64字库构建与使用
jinglixixi   2020-9-2 12:21 楼主
1.显示Flash ID
1运行效果
LCD屏显示从W25Q64读取的Flash ID,其程序代码如下:
    /* Initialize the SPI_FLASH driver */
    result = SPI_FLASH_Init();
    /* Check the SPI Flash ID    */
    if (result == TRUE)
                   LCD_StringLineDisplay8(Line1, "          W25Q64 TEST OK");
    else
                   LCD_StringLineDisplay8(Line1, "          W25Q64 TEST NO");
         /* Read SPI Flash ID              */
         FLASH_ID = SPI_FLASH_ReadJEDECID();
         gHelloString[0] = (u8) (FLASH_ID>>28);
         gHelloString[1] = (u8) (FLASH_ID>>24)&0x00ff;
         gHelloString[2] = (u8) (FLASH_ID>>20)&0x00ff;
         gHelloString[3] = (u8) (FLASH_ID>>16)&0x00ff;
         gHelloString[4] = (u8) (FLASH_ID>>12)&0x00ff;
         gHelloString[5] = (u8) (FLASH_ID>>8)&0x00ff;
         gHelloString[6] = (u8) (FLASH_ID>>4)&0x00ff;
         gHelloString[7] = (u8) (FLASH_ID&0x00ff);
         LCD_StringLineDisplay8(Line2, "          Flash ID:");
         for(i=0;i<8;i++)
                    u=gHelloString;
                    HEX();
2.显示读取内容
按下K1键,以读取存储字模 或 读取数组以验证读取正确性。
image.png 图2 读取存储内容
显示读取内容的程序如下:
                   /* Read WEAKUP and then output to LED1           */
                   TmpStatus = HT32F_DVB_PBGetState(BUTTON_WAKEUP);
                   if(TmpStatus)
                           HT32F_DVB_LEDOn(HT_LED1);
                           LCD_BackColorSet(Black);
                           LCD_TextColorSet(Yellow);
                           LCD_StringLineDisplay8(Line8, "Read_");
                           L=0;
                           //SPI_FLASH_WriteStatus(0x00);
                           for(i=0;i<8;i++)
                                H=(u8) (ReadDZ>>((7-i)*4)&0x0000000f);
                                if(H<10)
                                   LCD_CharDraw8(Line6, L, H+'0');
                                else
                                   LCD_CharDraw8(Line6, L, H-10+'A');
                                L=L+8;
                           SPI_FLASH_BufferRead(Rx_Buffer, 0x1000,320);  // 256
                           for (i = 0; i <320; i++)
                               gHelloString= Rx_Buffer;
                           l=0;
                           for(i=0;i<8;i++)
                               u=gHelloString[i+j];
                               HEX1();
                           l=0;
                           for(i=0;i<8;i++)
                               u=gHelloString[8+i+j];
                               HEX2();
                           if(j<320)
                               j=j+16;
                               ReadDZ=ReadDZ+16;
                  else
                            HT32F_DVB_LEDOff(HT_LED1);
3.存储字模
按F2读取数组中的字模内容写入W25Q64内
image.png 图3  写字模到字库
将字模写到字库的程序如下:
        /* Read KEY1 and then output to LED2           */
        TmpStatus = HT32F_DVB_PBGetState(BUTTON_KEY1);
		if(! TmpStatus)
			if (result == TRUE)
            else
			/* Clear the Block Protection bit      */
 			SPI_FLASH_SectorErase(0x1000);
   	        for (i = 0; i < 320; i++)
               gHelloString= Hzk[i/16][i%16];
               Tx_Buffer= gHelloString;
			SPI_FLASH_BufferWrite(Tx_Buffer, 0x1000,320 ); //256
			HT32F_DVB_LEDOn(HT_LED2);
            LCD_StringLineDisplay8(Line8, "Write");
			SPI_FLASH_BufferDualRead((u16*)Tx_Buffer,0x1000, 8);
	        for (i = 0; i < 16; i++)
               gHelloString= Tx_Buffer;
			l=0;
			for(i=0;i<8;i++)
		       u=gHelloString;
	           HEX1();
			l=0;
	        for(i=0;i<8;i++)
		       u=gHelloString[8+i];
	           HEX2();
			LCD_StringLineDisplay8(Line8, "OK___");
		 else
		    HT32F_DVB_LEDOff(HT_LED2);
4.验证显示效果
以红色字体显示字模内容
image.png 图4  验证显示
         /* Read KEY2 and then output to LED3    */
         TmpStatus = HT32F_DVB_PBGetState(BUTTON_KEY2);
         if(! TmpStatus)
  		    LCD_StringLineDisplay8(Line8, "dispL");
		    for(i=0;i<10;i++)
				   if(i>4)  LCD_CharDrawHk(Line5, 176+(i-5)*16, i);
				   else    LCD_CharDrawHk(Line4, 176+i*16, i);
至此,本次的测评任务就暂时画上一个句号了,在测评期间出SD卡不支持的原因,超量完成了预期的设定目标,使得开发板用的更加得心应手,ESK32-360开发板是在是一款学习和开发的好工具。再次感谢有这样好的测评活动,也期待能有的HT32F12345测评和使用的机会。
回复评论 (2)
可以试着字库索引和字模文件下发升级,usart或者USB,写入外部flash
点赞  2020-9-2 23:11
引用: 宋元浩 发表于 2020-9-2 23:11 可以试着字库索引和字模文件下发升级,usart或者USB,写入外部flash
是的,正在摸索中,主要是文件大的时候,怕不协调而失控。
点赞  2020-9-3 08:09
    写回复
