Windows Mobile 5.0 Pocket PC SDK不支持EVC吗?
smjw9186   2009-2-11 23:19 楼主
Windows Mobile 5.0 Pocket PC SDK只支持VS2005,不支持EVC?是不是这么回事啊,我安装的时候哦出现这样的提示
Software development tools required to use this SDK for application development are not installed on this workstation. Before trying to run the Setup Wizard again, verify that the required software is installed. To determine which software development tools are required, see the Microsoft Web site at http://go.microsoft.com/fwlink/?linkid=21615&clcid=0x409,which you can open in an external browser window by clicking the Open Browser button.
回复评论 (3)
你可能有别的东西没装,比如.NET Framework,或者已经装了但是版本不够,比如XP的SP包,以及eVC的SP包
点赞  2009-2-12 09:11
一楼分析的正确!
可能是WINCE 的某个补丁没有装,记得在装EVC之前要到微软网站上下个补丁(名字很长,不好意思现在不记得了)。
点赞  2009-2-12 09:39
从mobile5.0以后,以及wince6.0以后,所有的应用程序开发都要使用vs2005或者vs2008,evc产品线,微软已经停止更新。
点赞  2009-2-12 10:17
    写回复
