PB Debugger Warning: Debugger service map is set to none. If your image has debugging support it may not boot properly.
PB Debugger Cannot initialize the Kernel Debugger.
PB Debugger Debugger could not initialize connection.
PB Debugger The Kernel Debugger is waiting to connect with target.
PB Debugger The Kernel Debugger has been disconnected successfully.
没人回答,快沉下去了,帮顶。。。
问的问题估计是太概括了,所以没人回答。。。
还有就是警告不用管他。。。
从打印信息,楼主设置了debugger ,楼主如果不使用KITL,应该把这个选项设置为NONE的
现在没有在编译设置使能KITL,所以会有这种打印信息,出现
楼主检查一下。不懂得再跟帖,。
