驱动 起 应用层EXE
starliu   2009-9-13 22:05 楼主
各位高手,帮帮忙,急死了,本人刚接触驱动,调试了一星期,都无法成功,在硬编码的时候,可以成功启动,但是改成动态获取的时候,无论如何都启动不起来,有哪位大侠帮忙调试的加我QQ 454419771 在此感谢各位了,心急如焚啊!!!!
__declspec(naked) void ApcCreateProcess(PVOID NormalContext, PVOID  SystemArgument1, PVOID SystemArgument2)
        __asm{
        push ebp
        mov     ebp,esp
        push ebx
        push esi
        push edi
        jmp  __startup;                   ; these are just functions.... skip
__find_kernel32:
        push  esi                         ; Save esi
        push  0x30
        pop   ecx
        mov   eax, fs:[ecx]               ; Extract the PEB
        mov   eax, [eax + 0x0c]           ; Extract the PROCESS_MODULE_INFO pointer from the PEB
        mov   esi, [eax + 0x1c]           ; Get the address of flink in the init module list
        lodsd                             ; Load the address of blink into eax
        mov   eax, [eax + 0x8]            ; Grab the module base address from the list entry
        pop   esi                         ; Restore esi
        ret                               ; Return
__find_function:
        pushad                            ; Save all registers
        mov   ebp, [esp + 0x24]           ; Store the base address in eax
        mov   eax, [ebp + 0x3c]           ; PE header VMA
        mov   edx, [ebp + eax + 0x78]     ; Export table relative offset
        add   edx, ebp                    ; Export table VMA
        mov   ecx, [edx + 0x18]           ; Number of names
        mov   ebx, [edx + 0x20]           ; Names table relative offset
        add   ebx, ebp                    ; Names table VMA
__find_function_loop:
        jecxz __find_function_finished    ; Jump to the end if ecx is 0
        dec   ecx                         ; Decrement our names counter
        mov   esi, [ebx + ecx * 4]        ; Store the relative offset of the name
        add   esi, ebp                    ; Set esi to the VMA of the current name
        xor   edi, edi                    ; Zero edi
        xor   eax, eax                    ; Zero eax
        cld                               ; Clear direction
__compute_hash_again:
        lodsb                             ; Load the next byte from esi into al
        test  al, al                      ; Test ourselves.
        jz    __compute_hash_finished     ; If the ZF is set, we've hit the null term.
        ror   edi, 0xd                    ; Rotate edi 13 bits to the right
        add   edi, eax                    ; Add the new byte to the accumulator
        jmp   __compute_hash_again        ; Next iteration
__compute_hash_finished:
        cmp   edi, [esp + 0x28]           ; Compare the computed hash with the requested hash
        jnz   __find_function_loop        ; No match, try the next one.
        mov   ebx, [edx + 0x24]           ; Ordinals table relative offset
        add   ebx, ebp                    ; Ordinals table VMA
        mov   cx, [ebx + 2 * ecx]         ; Extrapolate the function's ordinal
        mov   ebx, [edx + 0x1c]           ; Address table relative offset
        add   ebx, ebp                    ; Address table VMA
        mov   eax, [ebx + 4 * ecx]        ; Extract the relative function offset from its ordinal
        add   eax, ebp                    ; Function VMA
        mov   [esp + 0x1c], eax           ; Overwrite stack version of eax from pushad
__find_function_finished:
        popad                             ; Restore all registers
        ret 8
__begin:
        nop
        pop edi                        ; Pop address
        mov ebx, __execute
        sub ebx, [CommendLine]
        sub edi, ebx                ; filename offset
        mov esi,edi                 ; filename to edi
        call __find_kernel32        ; Find kernel32 address
        mov ebx, eax                ; Save address in ebx
        jmp short __execute         ; Skip data
__startup:
        call __begin                ; Fetch our data address
__execute:
        push 0x0e8afe98             ; WinExec hash
        push ebx                   ; kernel32 base address
        call __find_function        ; find address
        xor ecx,ecx
        inc ecx                 ; ecx = 1
        push ecx                ; uCmdShow
        push esi                ; lpCmdLine. We already have the exe path in esi
        call eax                ; call WinExec
        pop edi        ; restore registers
        pop esi
        pop ebx
        pop ebp
        ret 0x0c
void __declspec(naked)  CommendLine()
        __asm{
                        //在这里300个nop
void __declspec(naked)  ApcCreateProcessEnd(){}
这段就是动态获取WinExec函数地址的代码,拜托各位大虾了
回复评论 (1)
期待高手。。。。
点赞  2009-9-13 23:31
    写回复
