[分享] C6678多核应用的cache小测试
Jacktang   2020-12-1 21:34 楼主
C6678多核之间在MSMC中交互数据,默认会用到L1D cache
数据一致性问题是很令人困扰的。
小测试验证了关于L1D cache 的linesize 是64Byte
初始化:
if(DNUM == 0)
(unsigned int)(0x0C330600) = 0x00;
(unsigned int)(0x0C330604) = 0x100;
(unsigned int)(0x0C330644) = 0x100;
WritebackCache((void *)((unsigned int)(0x0C330600)), 128);
然后在多核同步中断程序中:
//test
if(DNUM == 0)
    InvalidCache((void *)(0x0C330600), 64);
    (*(unsigned int*)(0x0C330600))++;
    WritebackCache((void *)((unsigned int)(0x0C330600)), 4);
else
    InvalidCache((void *)(0x0C330640), 64);
    (*(unsigned int*)(0x0C330644))++;
    WritebackCache((void *)((unsigned int)(0x0C330644)), 4);
    (*(unsigned int*)(0x0C330604))++;
    WritebackCache((void *)((unsigned int)(0x0C330604)), 4);
如此测试条件下,两个数据始终相差0x100,但若替换成注释部分的代码,则会破坏数据完整性。
也可以利用XMC来配置SL2,这样不用反复的InvalidCache和WritebackCache操作。
回复评论
暂无评论,赶紧抢沙发吧
    写回复
