[VxWorks] vxworks UDP 组播发送
xjc9837   2010-4-8 15:56 楼主
各位大哥帮忙看看我的组播发送函数,sendto返回老是ERROR,发送失败,是什么原因?谢谢。
struct   sockaddr_in       local;
    struct   sockaddr_in       target;
    struct   ip_mreq           ipMreq;
    int                        localfd;
    int      i,recvbytes,sendbytes;
    char     message[REQUEST_MSG_SIZE];
    struct   ip_mreq mcast;
    client_tx=0;
          client_tx_err=0;
    bzero((char   *)&local,sizeof(local));
    local.sin_family = AF_INET;
    local.sin_addr.s_addr = inet_addr("202.195.114.224");
    local.sin_port = htons(SERVER_PORT_NUM);
    if((localfd = socket( AF_INET, SOCK_DGRAM, 0)) == ERROR)
       printf("frame send Task socket() error:%s\n",strerror(errno));
       return   ERROR;
    if(bind(localfd, (struct sockaddr *)&local, sizeof(struct sockaddr_in))==ERROR)
       printf("frame send Task bind() error:%s\n",strerror(errno));
       return   ERROR;
    ipMreq.imr_multiaddr.s_addr = inet_addr("224.1.0.1");
    ipMreq.imr_interface.s_addr = inet_addr("202.195.114.224");
    if(setsockopt(localfd, IPPROTO_IP, IP_ADD_MEMBERSHIP, (char *)&ipMreq, sizeof(ipMreq)) == ERROR)
       printf("setsockopt   error,   %s.\n", strerror(errno));
    else
       printf("join  group ok.\n");
    bzero((char *)&target,sizeof(target));
    target.sin_family =  AF_INET;
    target.sin_addr.s_addr = inet_addr("224.1.0.1");
    target.sin_port = htons(5002);
    memset(message, 'Z', REQUEST_MSG_SIZE);
    FOREVER
              /*memset(message, client_tx & 0xff, REQUEST_MSG_SIZE);*/
              delays(1250000 / 3);
              /*taskDelay(1);*/
              if((sendbytes=sendto (localfd, (char *) message, length, 0,(struct sockaddr *) &target,
                                sizeof(struct sockaddr_in)) == ERROR))
                  printf("mcastSend sendto errno:0x%x\n", strerror(errno));
                  break;
              if (sendbytes != length)
                  client_tx_err++;
                  break;
              else
                  client_tx++;
              if(client_tx==count)
                  printf("count value is %d\n", count);
                  break;
  close (localfd);
  return OK;
回复评论 (7)
MARK
点赞  2010-4-8 22:29
学习!!!
点赞  2010-4-8 23:14
出错信息代码为0x41
点赞  2010-4-9 16:36
routeAdd本地网关解决此问题。
点赞  2010-4-12 14:11
前加上
routeAdd("224.1.0.1","202.195.114.224");
试试
点赞  2010-4-22 22:30
加上组播路由即可。
routeAdd
点赞  2010-4-22 23:11
多谢5楼,成功了。
点赞  2010-4-30 18:40
    写回复
