请大侠帮忙分析一下Cortex-m3的启动代码文件
wingslee   2009-7-20 13:53 楼主
大侠好,我最近买了STM3210E-EVAL开发板用来学习,还下载了最新的配套示例程序,用的开发环境是:IAR Embedded Workbench for ARM 5.40
在示例工程里有一些代码不懂,请大侠帮我分析一下,最好对照代码在后面写出一些详细的注释,先谢谢了。
文件名:startup_stm32f10x_hd.s(这个是不是启动代码啊?)
内容:
    MODULE  ?cstartup
  ;; ICODE is the same segment as cstartup. By placing __low_level_init
  ;; in the same segment, we make sure it can be reached with BL. */
    SECTION           CSTACKATA:NOROOT(3)
    SECTION .icode:CODE:NOROOT(2)
    PUBLIC  __low_level_init
       PUBWEAK SystemInit_ExtMemCtl
       SECTION .text:CODE:REORDER(2)
        THUMB
        BX LR
__low_level_init:
  ;;  Initialize hardware.
                LDR  R0, = SystemInit_ExtMemCtl ; initialize external memory controller
                MOV  R11, LR
                BLX  R0
                LDR  R1, =sfe(CSTACK)        ; restore original stack pointer
                MSR  MSP, R1
                MOV  R0,#1
   ;; Return with BX to be independent of mode of caller
                BX    R11
        ;; Forward declaration of sections.
        SECTION .intvec:CODE:NOROOT(2)
        EXTERN  __iar_program_start
        PUBLIC  __vector_table
        DATA
__intial_sp      EQU     0x20000400
__vector_table
        DCD     __intial_sp
        DCD     __iar_program_start
        DCD     NMI_Handler               ; NMI Handler
        DCD     HardFault_Handler         ; Hard Fault Handler
        DCD     MemManage_Handler         ; MPU Fault Handler
        DCD     BusFault_Handler          ; Bus Fault Handler
        DCD     UsageFault_Handler        ; Usage Fault Handler
        DCD     0                         ; Reserved
        DCD     0                         ; Reserved
        DCD     0                         ; Reserved
        DCD     0                         ; Reserved
        DCD     SVC_Handler               ; SVCall Handler
        DCD     DebugMon_Handler          ; Debug Monitor Handler
        DCD     0                         ; Reserved
        DCD     PendSV_Handler            ; PendSV Handler
        DCD     SysTick_Handler           ; SysTick Handler
         ; External Interrupts
        DCD     WWDG_IRQHandler           ; Window Watchdog
        DCD     PVD_IRQHandler            ; PVD through EXTI Line detect
        DCD     TAMPER_IRQHandler         ; Tamper
        DCD     RTC_IRQHandler            ; RTC
        DCD     FLASH_IRQHandler          ; Flash
        DCD     RCC_IRQHandler            ; RCC
        DCD     EXTI0_IRQHandler          ; EXTI Line 0
        DCD     EXTI1_IRQHandler          ; EXTI Line 1
        DCD     EXTI2_IRQHandler          ; EXTI Line 2
        DCD     EXTI3_IRQHandler          ; EXTI Line 3
        DCD     EXTI4_IRQHandler          ; EXTI Line 4
        DCD     DMA1_Channel1_IRQHandler  ; DMA1 Channel 1
        DCD     DMA1_Channel2_IRQHandler  ; DMA1 Channel 2
        DCD     DMA1_Channel3_IRQHandler  ; DMA1 Channel 3
        DCD     DMA1_Channel4_IRQHandler  ; DMA1 Channel 4
        DCD     DMA1_Channel5_IRQHandler  ; DMA1 Channel 5
        DCD     DMA1_Channel6_IRQHandler  ; DMA1 Channel 6
        DCD     DMA1_Channel7_IRQHandler  ; DMA1 Channel 7
        DCD     ADC1_2_IRQHandler         ; ADC1 & ADC2
        DCD     USB_HP_CAN1_TX_IRQHandler  ; USB High Priority or CAN1 TX
        DCD     USB_LP_CAN1_RX0_IRQHandler ; USB Low  Priority or CAN1 RX0
        DCD     CAN1_RX1_IRQHandler       ; CAN1 RX1
        DCD     CAN1_SCE_IRQHandler       ; CAN1 SCE
        DCD     EXTI9_5_IRQHandler        ; EXTI Line 9..5
        DCD     TIM1_BRK_IRQHandler       ; TIM1 Break
        DCD     TIM1_UP_IRQHandler        ; TIM1 Update
        DCD     TIM1_TRG_COM_IRQHandler   ; TIM1 Trigger and Commutation
        DCD     TIM1_CC_IRQHandler        ; TIM1 Capture Compare
        DCD     TIM2_IRQHandler           ; TIM2
        DCD     TIM3_IRQHandler           ; TIM3
        DCD     TIM4_IRQHandler           ; TIM4
        DCD     I2C1_EV_IRQHandler        ; I2C1 Event
        DCD     I2C1_ER_IRQHandler        ; I2C1 Error
        DCD     I2C2_EV_IRQHandler        ; I2C2 Event
        DCD     I2C2_ER_IRQHandler        ; I2C2 Error
        DCD     SPI1_IRQHandler           ; SPI1
        DCD     SPI2_IRQHandler           ; SPI2
        DCD     USART1_IRQHandler         ; USART1
        DCD     USART2_IRQHandler         ; USART2
        DCD     USART3_IRQHandler         ; USART3
        DCD     EXTI15_10_IRQHandler      ; EXTI Line 15..10
        DCD     RTCAlarm_IRQHandler       ; RTC Alarm through EXTI Line
        DCD     USBWakeUp_IRQHandler      ; USB Wakeup from suspend
        DCD     TIM8_BRK_IRQHandler       ; TIM8 Break
        DCD     TIM8_UP_IRQHandler        ; TIM8 Update
        DCD     TIM8_TRG_COM_IRQHandler   ; TIM8 Trigger and Commutation
        DCD     TIM8_CC_IRQHandler        ; TIM8 Capture Compare
        DCD     ADC3_IRQHandler           ; ADC3
        DCD     FSMC_IRQHandler           ; FSMC
        DCD     SDIO_IRQHandler           ; SDIO
        DCD     TIM5_IRQHandler           ; TIM5
        DCD     SPI3_IRQHandler           ; SPI3
        DCD     UART4_IRQHandler          ; UART4
        DCD     UART5_IRQHandler          ; UART5
        DCD     TIM6_IRQHandler           ; TIM6
        DCD     TIM7_IRQHandler           ; TIM7
        DCD     DMA2_Channel1_IRQHandler  ; DMA2 Channel1
        DCD     DMA2_Channel2_IRQHandler  ; DMA2 Channel2
        DCD     DMA2_Channel3_IRQHandler  ; DMA2 Channel3
        DCD     DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 & Channel5
;; Default interrupt handlers.
        THUMB
        PUBWEAK NMI_Handler
        SECTION .text:CODE:REORDER(1)
NMI_Handler
        B NMI_Handler
        PUBWEAK HardFault_Handler
HardFault_Handler
        B HardFault_Handler
        PUBWEAK MemManage_Handler
MemManage_Handler
        B MemManage_Handler
        PUBWEAK BusFault_Handler
BusFault_Handler
        B BusFault_Handler
        PUBWEAK UsageFault_Handler
UsageFault_Handler
        B UsageFault_Handler
        PUBWEAK SVC_Handler
SVC_Handler
        B SVC_Handler
        PUBWEAK DebugMon_Handler
DebugMon_Handler
        B DebugMon_Handler
        PUBWEAK PendSV_Handler
PendSV_Handler
        B PendSV_Handler
        PUBWEAK SysTick_Handler
SysTick_Handler
        B SysTick_Handler
        PUBWEAK WWDG_IRQHandler
WWDG_IRQHandler
        B WWDG_IRQHandler
        PUBWEAK PVD_IRQHandler
PVD_IRQHandler
        B PVD_IRQHandler
        PUBWEAK TAMPER_IRQHandler
TAMPER_IRQHandler
        B TAMPER_IRQHandler
        PUBWEAK RTC_IRQHandler
RTC_IRQHandler
        B RTC_IRQHandler
        PUBWEAK FLASH_IRQHandler
FLASH_IRQHandler
        B FLASH_IRQHandler
        PUBWEAK RCC_IRQHandler
RCC_IRQHandler
        B RCC_IRQHandler
        PUBWEAK EXTI0_IRQHandler
EXTI0_IRQHandler
        B EXTI0_IRQHandler
        PUBWEAK EXTI1_IRQHandler
EXTI1_IRQHandler
        B EXTI1_IRQHandler
        PUBWEAK EXTI2_IRQHandler
(以下还有类似于上面的中断跳转代码,省略)
        END
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
哪位大侠帮我对照源代码写个详细的注释好吗?
我是新手,请大侠指点迷津啊。
谢谢。
回复评论 (5)
等了一天了,怎么没有人回答我呢?
我有急用啊,希望大侠指点迷津哦。
点赞  2009-7-21 08:43
太长了,大家都懒得看
点赞  2009-7-21 17:50
学习!!
点赞  2009-7-21 19:32
..........太长...........
点赞  2009-7-28 13:16
是启动代码。里面注释不是很详细嘛
点赞  2011-2-12 17:07
    写回复
