[分享] 【RPi PICO】使用 PIO 获取更多 Sigma Delta ADC输入
dcexpert   2021-2-19 10:36 楼主
来自:https://forum.micropython.org/viewtopic.php?t=9839&p=55065#p55065
PRP2040上的ADC输入通道比较少,下面的方法可以为提供更多的ADC通道,每个通道需要2个引脚,2个电阻和2个电容。
两个电容的电荷由通过输入电阻R2和反馈电阻R1的电流平衡。PIO尝试将输入引脚上的电压保持在其低/高阈值之间。如果使用合适的输入电阻,则可以测量更高和更低的电压。
title= "pioAdcB" # by CWE
# Adc sigma delta type
from machine import Pin
from rp2 import PIO, StateMachine, asm_pio
from time import sleep
maxTime=1_000_000
@asm_pio(sideset_init=PIO.OUT_LOW)
def cap_prog():
    mov(y, osr) # OSR must be preloaded with max
    mov(x, osr)
    label("test_pin") #
    jmp(pin, "is_set")
    jmp(y_dec, "not_set") # just count it 1
    label("not_set")
    #nop() .side(1)
    jmp(x_dec,"test_pin") .side(1) # 2
    jmp("save_result")
    label("is_set")
    # nop() .side(0)
    nop() # 1
    jmp(x_dec,"test_pin") .side(0) #2
    label("save_result")
    mov(isr, y) #.side(0) # save result; pin low
    push(noblock)
class PIOCAP:
    def __init__(self, sm_id, outPin, inPin, max_count, count_freq):
        self._sm = StateMachine(sm_id, cap_prog, freq=2 * count_freq, sideset_base=Pin(outPin), jmp_pin=Pin(inPin,Pin.IN))
        # Use exec() to load max count into ISR
        self._sm.put(max_count)
        self._sm.exec("pull()")
        #self._sm.exec("mov(isr, osr)")
        self._sm.active(1)
        self._max_count = max_count
    def getCap(self):
        #self._sm.exec("push()")
        return self._sm.get()
cap = PIOCAP(0, 22, 17, max_count=(maxTime), count_freq=50_000_000)
mittel=0
while True:
    onTime= maxTime-cap.getCap()
    mittel=(9*mittel+onTime)/10
    #print(onTime, mittel, (onTime/maxTime))
    print(onTime, 7.309-1.4369e-5*onTime)
    sleep(0.1)
回复评论 (1)
感谢分享,最好把试验的结果也分享出来。
没有什么不可以,我就是我,不一样的烟火!
点赞  2021-2-19 11:51
    写回复
