首先大概看下独立按键的硬件资源:
EVB 配置 5 个独立按键,分别为 1 个复位按键和 4 个用户按键。复位按键作为芯片的硬件复位;
用户按键则作为预留的外设连接到 MCU GPIO。通过下表中的引脚连接到 MCU:
丝印 | 管脚/功能 |
SW1 | RESET/复位按键 |
SW2 | PD3/用户按键 |
SW3 | PD4/用户按键 |
SW4 | PD5/用户按键 |
SW5 | PD6/用户按键 |
从原理图可知,该独立按键使用硬件消抖的方式,按键按下时(以SW4为例),
电阻R121和电容C83放电进行消抖操作,
这个实验还需要使用到LED的硬件资源:
EVB 配置 5 个指示灯,分别为电源指示灯和用户指示灯。电源指示灯用于显示是否正常通电,
用户指示灯作为预留的外设连接到 MCU GPIO。 管脚分配请参考下表:
丝印 | 管脚/功能 |
D1 | 3V3 电源指示灯 |
D23 | PE6/红色指示灯 |
D26 | PA7/绿色指示灯 |
D27 | PB5/黄色指示灯 |
D30 | PB9/蓝色指示灯 |
以下是具体代码:
led.c
/** \file wm8731.c
** \brief I2S codec WM8731 driver API functions
** - 2018-11-13 1.0 Wangmin First version for Device Driver Library
* Include files
#include "hc32_ddl.h"
#include "led.h"
* Local type definitions ('typedef')
* Local pre-processor symbols/macros ('#define')
* Global variable definitions (declared in header file with 'extern')
* Local function prototypes ('static')
* Local variable definitions ('static')
* Function implementation - global ('extern') and local ('static')
** \brief Initialize LED0 for indicate recoder status
** \param None
** \retval None
void IniLedPort(void)
stc_port_init_t stcPortInit;
/*initiallize LED port*/
MEM_ZERO_STRUCT(stcPortInit);
stcPortInit.enPinMode = Pin_Mode_Out;
stcPortInit.enExInt = Enable;
stcPortInit.enPullUp = Enable;
/* LED0 Port/Pin initialization */
PORT_Init(LED0_PORT, LED0_PIN, &stcPortInit);
/* LED1 Port/Pin initialization */
PORT_Init(LED1_PORT, LED1_PIN, &stcPortInit);
/* LED2 Port/Pin initialization */
PORT_Init(LED2_PORT, LED2_PIN, &stcPortInit);
/* LED3 Port/Pin initialization */
PORT_Init(LED3_PORT, LED3_PIN, &stcPortInit);
* EOF (not truncated)
led.h
/** \file led.h
** A detailed description is available at
** @link led Series description @endlink
** - 2021-4-15 1.0 First version for i2s Series Functions description
** Library.
#ifndef __LED_H__
#define __LED_H__
* Include files
/* LED0 Port/Pin definition */
#define LED0_PORT PortE
#define LED0_PIN Pin06
/* LED0~1 toggle definition */
#define LED0_TOGGLE() PORT_Toggle(LED0_PORT, LED0_PIN)
#define LED1_PORT PortA
#define LED1_PIN Pin07
#define LED1_TOGGLE() PORT_Toggle(LED1_PORT, LED1_PIN)
#define LED2_PORT PortB
#define LED2_PIN Pin05
#define LED2_TOGGLE() PORT_Toggle(LED2_PORT, LED2_PIN)
#define LED3_PORT PortB
#define LED3_PIN Pin09
#define LED3_TOGGLE() PORT_Toggle(LED3_PORT, LED3_PIN)
void IniLedPort(void);
#endif /* __LED_H__ */
* End of file
key.c
/** \file key.c
** \brief Key functions
** - 2021-04-15 1.0 First version for Key
* Include files
#include "key.h"
#include "led.h"
** \brief Initialize keys
** \param None
** \retval None
void IniKey(void)
/*initiallize KEY port*/
/* KEY0 Port/Pin initialization */
PORT_Init(KEY2_PORT, KEY2_PIN, &stcPortInit);
/* KEY1 Port/Pin initialization */
PORT_Init(KEY3_PORT, KEY3_PIN, &stcPortInit);
/* KEY2 Port/Pin initialization */
PORT_Init(KEY4_PORT, KEY4_PIN, &stcPortInit);
/* KEY3 Port/Pin initialization */
PORT_Init(KEY5_PORT, KEY5_PIN, &stcPortInit);
** \brief keyscan
** \param None
** \retval None
void KeyScan(void)
if(KEY2 == 0)
LED0_TOGGLE();
Ddl_Delay1ms(10);
LED0_TOGGLE();
if(KEY3 == 0)
LED1_TOGGLE();
Ddl_Delay1ms(10);
LED1_TOGGLE();
if(KEY4 == 0)
LED2_TOGGLE();
Ddl_Delay1ms(10);
LED2_TOGGLE();
if(KEY5 == 0)
LED3_TOGGLE();
Ddl_Delay1ms(10);
LED3_TOGGLE();
key.h
/** \file key.h
** @link key Series description @endlink
** - 2021-4-15 1.0 First version for Key Functions description
** Library.
#ifndef __KEY_H__
#define __KEY_H__
* Include files
/* KEY0 Port/Pin definition *///SW2
#define KEY2_PORT (PortD)
#define KEY2_PIN (Pin03)
#define KEY2 PORT_GetBit(PortD,Pin03)
/* KEY2 Port/Pin definition *///SW3
#define KEY3_PORT PortD
#define KEY3_PIN Pin05
#define KEY3 PORT_GetBit(PortD,Pin05)
/* KEY1 Port/Pin definition *///SW4
#define KEY4_PORT (PortD)
#define KEY4_PIN (Pin04)
#define KEY4 PORT_GetBit(PortD,Pin04)
/* KEY3 Port/Pin definition *///SW5
#define KEY5_PORT PortD
#define KEY5_PIN Pin06
#define KEY5 PORT_GetBit(PortD,Pin06)
void IniKey(void);
void KeyScan(void);
#endif /* __KEY_H__ */
* End of file
main.c
* @file main.c
* @brief Main program template.
@verbatim
Change Logs:
Date Author Notes
2020-06-30 Zhangxl First version
@endverbatim
* Copyright (C) 2016, Huada Semiconductor Co., Ltd. All rights reserved.
* This software is owned and published by:
* Huada Semiconductor Co., Ltd. ("HDSC").
* BY DOWNLOADING, INSTALLING OR USING THIS SOFTWARE, YOU AGREE TO BE BOUND
* BY ALL THE TERMS AND CONDITIONS OF THIS AGREEMENT.
* This software contains source code for use with HDSC
* components. This software is licensed by HDSC to be adapted only
* for use in systems utilizing HDSC components. HDSC shall not be
* responsible for misuse or illegal use of this software for devices not
* supported herein. HDSC is providing this software "AS IS" and will
* not be responsible for issues arising from incorrect user implementation
* of the software.
* Disclaimer:
* HDSC MAKES NO WARRANTY, EXPRESS OR IMPLIED, ARISING BY LAW OR OTHERWISE,
* REGARDING THE SOFTWARE (INCLUDING ANY ACCOMPANYING WRITTEN MATERIALS),
* ITS PERFORMANCE OR SUITABILITY FOR YOUR INTENDED USE, INCLUDING,
* WITHOUT LIMITATION, THE IMPLIED WARRANTY OF MERCHANTABILITY, THE IMPLIED
* WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE OR USE, AND THE IMPLIED
* WARRANTY OF NONINFRINGEMENT.
* HDSC SHALL HAVE NO LIABILITY (WHETHER IN CONTRACT, WARRANTY, TORT,
* NEGLIGENCE OR OTHERWISE) FOR ANY DAMAGES WHATSOEVER (INCLUDING, WITHOUT
* LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS, BUSINESS INTERRUPTION,
* LOSS OF BUSINESS INFORMATION, OR OTHER PECUNIARY LOSS) ARISING FROM USE OR
* INABILITY TO USE THE SOFTWARE, INCLUDING, WITHOUT LIMITATION, ANY DIRECT,
* INDIRECT, INCIDENTAL, SPECIAL OR CONSEQUENTIAL DAMAGES OR LOSS OF DATA,
* SAVINGS OR PROFITS,
* EVEN IF Disclaimer HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
* YOU ASSUME ALL RESPONSIBILITIES FOR SELECTION OF THE SOFTWARE TO ACHIEVE YOUR
* INTENDED RESULTS, AND FOR THE INSTALLATION OF, USE OF, AND RESULTS OBTAINED
* FROM, THE SOFTWARE.
* This software may be replicated in part or whole for the licensed use,
* with the restriction that this Disclaimer and Copyright notice must be
* included with each copy of this software, whether used in part or whole,
* at all times.
* Include files
#include "led.h"
#include "key.h"
* @brief Main function of template project
* @param None
* @retval int32_t return value, if needed
int32_t main(void)
while(1)
/* Initialize Key */
IniKey();
/* Initialize LED0 */
IniLedPort();
while(1)
KeyScan();
该实验,按下一个按键对应一个灯闪烁,一共四个按键对应四个灯闪烁。
这里发现一个小问题,独立按键虽然使用了硬件消抖,但好像有时不是很好用,
刚开始该实验室按键按一下对应的灯状态取反一次,验证的时候会存在按键按完等的状态还是与初始的状态一致,
说明按“一次”按键灯的状态连续取反了两次,消抖不是那么干净(可以将RC增大,提高时间常数应该会有改善),
也有可能是个人按按键的方式问题,不知道其他小伙伴是否有遇到过这种问题。
下面是实验的效果:
板子的电源指示灯被我用胶带粘住了,灯有点亮晃眼睛
引用: 火辣西米秀 发表于 2021-4-20 17:39 下面整个自动跑马灯程序,不用手按键了
跑马灯之前有玩过
引用: 逃之之夭夭 发表于 2021-7-17 12:19 有hc32f460 kcta的led源程序吗
另一个帖子有,不过是PBTE的程序
