我用的是MPC8280。上面跑vxworks5.5.
采用bootRom + vxworks image的方式。
一种方法是bootrom起来后从网络加载vxworks映像的方式进行调试。调试串口和已经打通。
但是,在boot的过程中,选择从FCC1下载vxworks映像运行到bootConfig.c的ipAttach()这个函数后,该函数的返回值始终错误,当然串口就打印出错信息(Failed to attach TCP/IP to device) 之后就退出加载VXWORKS映像了.
于是采用串口的方式加载vxworks映像成功后在shell中用ifShow(如下)发现系统仍然没有加载FCC1这个网口.
-> ifShow
lo (unit number 0):
Flags: (0x8069) UP LOOPBACK RUNNING ARP MULTICAST
Type: SOFTWARE_LOOPBACK
Internet address: 127.0.0.1
Netmask 0xff000000 Subnetmask 0xff000000
Metric is 0
Maximum Transfer Unit size is 32768
0 packets received; 0 packets sent
0 multicast packets received
0 multicast packets sent
0 input errors; 0 output errors
0 collisions; 0 dropped
value = 0 = 0x0
-> muxShow
Current mode: NORMAL
Device: motfcc Unit: 0 END_OBJ: 0x3bb9998
Description: Motorola FCC Ethernet Enhanced Network Driver 2.1
Device: motfcc Unit: 1 END_OBJ: 0x3b73da0
Device: motfcc Unit: 2 END_OBJ: 0x3b2e1a0
value = 0 = 0x0
接着在shell中用ipAttach()命令和usrNetIfConfig()命令加载好FCC1网口后与计算机通信发现该网口又可以正常稳定的工作.
问题是目前需要用该网口来加载vxworks映像,为何在bootROM.bin无法正常加载ipAttach()函数,请各位高手给点宝贵意见,不胜感激!!!
-> ipAttach(2,"motfcc")
value = 0 = 0x0
-> usrNetIfConfig("motfcc",2,"192.168.0.11","fcc1",0xffffff00);
value = 0 = 0x0
-> ifShow
lo (unit number 0):
Metric is 0
motfcc (unit number 2):
Flags: (0x8063) UP BROADCAST RUNNING ARP MULTICAST
Type: ETHERNET_CSMACD
Internet address: 192.168.0.11
Broadcast address: 192.168.0.255
Netmask 0xffffff00 Subnetmask 0xffffff00
Ethernet address is 00:00:00:00:00:00
Metric is 0
Maximum Transfer Unit size is 1500
0 packets received; 1 packets sent
value = 0 = 0x0
-> muxShow
Protocol: IP 4.4 TCP/IP Type: 0x0800 Recv 0x6f8fc Shutdown 0x6fd08
Protocol: IP 4.4 ARP Type: 0x0806 Recv 0x6f8fc Shutdown 0x6fdec
value = 0 = 0x0
检查一下你的启动参数,看是否是因为传入的参数不对而导致加载驱动错误
两个建议:
1.看BSP中关于MOTFCC方面的配置有无问题
2.是否给板卡分配MAC地址了?
楼主问题解决了吗?我也遇到了类似的情况,请高手解答
还没有解决!
我检查了MAC等配置,基本没有发现异常;
我又用串口跟踪:发现启动参数到ipAttach()时也没有错,
不过vxworks5.5的ipAttach()函数没有开放源码,仅返回个error(-1)所以只能跟踪到这了.
请问还有没有办法得到ipAttach()里的出错细节呢??
各位高手还有没有什么见解呢?
检查你编译bootrom和vxworks镜像是不是相同的bsp(可能你的bootrom中缺少一些include组件,)你这个问题一般都是这个问题造成的。
两种可能:
1, 你的bootrom中没有定义可用的网络接口。在config.h和confignet.h中查找mccfcc,打开相应的宏定义。
2, 你的板卡在启动时需要插上网线,如果没有,则需要使用ipAttach进行添加。
另外,bootrom和VIP之间没有联系,也就是说不需要版本对应才能启动。
