#define pISR (*(unsigned *)(0x30000000+0x18))
//#define pISR (*(unsigned *)(0x00000000+0x18)) 这里应该填什么?
// Virtual Address 0x0 is mapped to 0x30000000, ISR Address is VA 0x18
void Isr_Init(void)
volatile S3C2440A_INTR_REG *s2440INT = (S3C2440A_INTR_REG *)OALPAtoVA(S3C2440A_BASE_REG_PA_INTR, FALSE);
s2440INT->INTMOD=0x0; // All=IRQ mode
s2440INT->INTMSK=BIT_ALLMSK; // All interrupt is masked.
EdbgOutputDebugString("INFO: (unsigned)IsrUsbd : 0x%x\r\n", (unsigned)IsrUsbd);
EdbgOutputDebugString("INFO: (unsigned)IsrHandler : 0x%x\r\n", (unsigned)IsrHandler);
// make value to assemble code "b IsrHandler"
pISR =(unsigned)(0xEA000000)+(((unsigned)IsrHandler - (0x80000000 + 0x18 + 0x8) )>>2);
0x80000000 这个地方对了吗
我的中断总是跳不到IsrHandler函数里,为什么?
USB.S里
LEAF_ENTRY IsrHandler
; sub sp,sp,#4 ;decrement sp(to store jump address)
sub lr, lr, #4
stmfd sp!, {r0-r12,lr}
mov r0, lr
bl IsrUsbd
ldmfd sp!, {r0-r12,lr}
movs pc, lr
ENDP ; |IsrHandler|
startup.s里的MMU开启,里面不知道啥意思, (VA == 0) to (PA == 0x30000000).不确定是不是这样映射
; Compute physical address of the OEMAddressTable.
20 add r11, pc, #g_oalAddressTable - (. + 8)
ldr r10, =PTs ; (r10) = 1st level page table
; Setup 1st level page table (using section descriptor)
; Fill in first level page table entries to create "un-mapped" regions
; from the contents of the MemoryMap array.
; (r11) = ptr to MemoryMap array
add r10, r10, #0x2000 ; (r10) = ptr to 1st PTE for "unmapped space"
mov r0, #0x0E ; (r0) = PTE for 0: 1MB cachable bufferable
orr r0, r0, #0x400 ; set kernel r/w permission
25 mov r1, r11 ; (r1) = ptr to MemoryMap array
30 ldr r2, [r1], #4 ; (r2) = virtual address to map Bank at
ldr r3, [r1], #4 ; (r3) = physical address to map from
ldr r4, [r1], #4 ; (r4) = num MB to map
cmp r4, #0 ; End of table?
beq %f40
ldr r5, =0x1FF00000
and r2, r2, r5 ; VA needs 512MB, 1MB aligned.
ldr r5, =0xFFF00000
and r3, r3, r5 ; PA needs 4GB, 1MB aligned.
add r2, r10, r2, LSR #18
add r0, r0, r3 ; (r0) = PTE for next physical page
35 str r0, [r2], #4
add r0, r0, #0x00100000 ; (r0) = PTE for next physical page
sub r4, r4, #1 ; Decrement number of MB left
cmp r4, #0
bne %b35 ; Map next MB
bic r0, r0, #0xF0000000 ; Clear Section Base Address Field
bic r0, r0, #0x0FF00000 ; Clear Section Base Address Field
b %b30 ; Get next element
40 tst r0, #8
bic r0, r0, #0x0C ; clear cachable & bufferable bits in PTE
add r10, r10, #0x0800 ; (r10) = ptr to 1st PTE for "unmapped uncached space"
bne %b25 ; go setup PTEs for uncached space
sub r10, r10, #0x3000 ; (r10) = restore address of 1st level page table
; Setup mmu to map (VA == 0) to (PA == 0x30000000).
ldr r0, =PTs ; PTE entry for VA = 0
ldr r1, =0x3000040E ; uncache/unbuffer/rw, PA base == 0x30000000
str r1, [r0]
; uncached area.
add r0, r0, #0x0800 ; PTE entry for VA = 0x0200.0000 , uncached
ldr r1, =0x30000402 ; uncache/unbuffer/rw, base == 0x30000000
str r1, [r0]
; Comment:
; The following loop is to direct map RAM VA == PA. i.e.
; VA == 0x30XXXXXX => PA == 0x30XXXXXX for S3C2400
; Fill in 8 entries to have a direct mapping for DRAM
ldr r10, =PTs ; restore address of 1st level page table
ldr r0, =PHYBASE
add r10, r10, #(0x3000 / 4) ; (r10) = ptr to 1st PTE for 0x30000000
add r0, r0, #0x1E ; 1MB cachable bufferable
mov r1, #0
mov r3, #64
45 mov r2, r1 ; (r2) = virtual address to map Bank at
cmp r2, #0x20000000:SHR:BANK_SHIFT
add r2, r10, r2, LSL #BANK_SHIFT-18
strlo r0, [r2]
subs r3, r3, #1
add r1, r1, #1
bgt %b45
ldr r10, =PTs ; (r10) = restore address of 1st level page table
; The page tables and exception vectors are setup.
; Initialize the MMU and turn it on.
mov r1, #1
mcr p15, 0, r1, c3, c0, 0 ; setup access to domain 0
mcr p15, 0, r10, c2, c0, 0
mcr p15, 0, r0, c8, c7, 0 ; flush I+D TLBs
mov r1, #0x0071 ; Enable: MMU
orr r1, r1, #0x0004 ; Enable the cache
ldr r0, =VirtualStart
cmp r0, #0 ; make sure no stall on "mov pc,r0" below
mcr p15, 0, r1, c1, c0, 0
mov pc, r0 ; & jump to new virtual address
nop
; MMU & caches now enabled.
; (r10) = physcial address of 1st level page table
VirtualStart
mov sp, #0x80000000
add sp, sp, #0x30000 ; arbitrary initial super-page stack pointer
b main
ENTRY_END
LTORG
g_oalAddressTable
; DCD 0x80000000, 0x30000000, 128 ; 128 MB SDRAM-1 BANK 6
DCD 0x80000000, 0x30000000, 64 ; 64 MB SDRAM-1 BANK 6
DCD 0x88000000, 0x18000000, 32 ; 32 MB SROM(SRAM/ROM) BANK 3
DCD 0x8A000000, 0x20000000, 32 ; 32 MB SROM(SRAM/ROM) BANK 4
DCD 0x8C000000, 0x08000000, 32 ; 32 MB SROM(SRAM/ROM) BANK 1
DCD 0x90000000, 0x10000000, 8 ; nGCS2: PCMCIA/PCCARD
DCD 0x90800000, 0x48000000, 1 ; Memory control register
DCD 0x90900000, 0x49000000, 1 ; USB Host register
DCD 0x90A00000, 0x4A000000, 1 ; Interrupt Control register
DCD 0x90B00000, 0x4B000000, 1 ; DMA control register
DCD 0x90C00000, 0x4C000000, 1 ; Clock & Power register
DCD 0x90D00000, 0x4D000000, 1 ; LCD control register
DCD 0x90E00000, 0x4E000000, 1 ; NAND flash control register
DCD 0x90F00000, 0x4F000000, 1 ; Camera control register
DCD 0x91000000, 0x50000000, 1 ; UART control register
DCD 0x91100000, 0x51000000, 1 ; PWM timer register
DCD 0x91200000, 0x52000000, 1 ; USB device register
DCD 0x91300000, 0x53000000, 1 ; Watchdog Timer register
DCD 0x91400000, 0x54000000, 1 ; IIC control register
DCD 0x91500000, 0x55000000, 1 ; IIS control register
DCD 0x91600000, 0x56000000, 1 ; I/O Port register
DCD 0x91700000, 0x57000000, 1 ; RTC control register
DCD 0x91800000, 0x58000000, 1 ; A/D convert register
DCD 0x91900000, 0x59000000, 1 ; SPI register
DCD 0x91A00000, 0x5A000000, 1 ; SD Interface register
; DCD 0x92000000, 0x00000000, 32 ; 32 MB SROM(SRAM/ROM) BANK 0
DCD 0x00000000, 0x00000000, 0 ; end of table
END
引用: 引用 2 楼 veabol 的回复:
这段中断的初始化没错,但是这个中断只能处理USB DEVICE中断,
你的中断没成功吗?是不是中断的MASK位设置问题?或者是USB模块初始化不对?
没有成功哦,就是不进那个中断,跳不到IsrHandler函数里
void Isr_Init(void)
pISR =(unsigned)(0xEA000000)+(((unsigned)IsrHandler - (0x80038000 + 0x18 + 0x8) )>>2);
// pISR = (unsigned)IsrHandler;
// pISRUSBD = (unsigned)IsrUsbd;
EdbgOutputDebugString("INFO: (unsigned)pISR : 0x%x\r\n", (unsigned)pISR);
s2440INT->SRCPND = BIT_USBD;
if (s2440INT->INTPND & BIT_USBD)
s2440INT->INTPND = BIT_USBD;
s2440INT->INTMSK &= ~BIT_USBD; // USB Interrupt enable.
s2440INT->SRCPND = BIT_DMA2;
if (s2440INT->INTPND & BIT_DMA2)
s2440INT->INTPND = BIT_DMA2;
s2440INT->INTMSK &= ~BIT_DMA2; // DMA Interrupt enable.
