BLE超低功耗声纹门锁
作者:xujinxi
一、项目背景
OnSemi提供的RSL10蓝牙模组,应该为业界最小的蓝牙低功耗模组,并且该模组有业界最优的低功耗管理,且开发套件的sensor外设丰富,为各种奇思妙想的实现提供了非常理想的平台。
二、作品简介
RSL10蓝牙模组具有超低功耗以及方便使用的音频接口。搭载传感器以及相关的参考驱动代码,可以可靠、便捷的实现工程师的奇思妙想,深受工程师欢迎。EEWORLD+OnSemi开展的创意设计大赛,为广大工程师朋友提供施展才华的舞台。
本项目构思使用RSL10蓝牙模组搭载的DMIC和IMU单元。用于智能门锁户外敲门的识别和语音拾取,并发送至室内接收端。室内的RSL10蓝牙模组则接收户外传来的语音数据,通过串口传递至PC,PC使用该语音数据访问语音平台,识别语音指令。如果是正确的“开门”指令,则”开门”信号通过串口经室内RSL10蓝牙模组,再通过BLE传输至户外RSL10蓝牙模组,进而发出门锁开启信号。完成整个低功耗语音门锁的实现
三、系统框图和各部分功能说明
整个体统主要由RSL10、IMU、DMIC等传感器接口组成,如下为系统电子系统框图:USB端口连接Jlink,Jlink通过USB CDC建立与PC的通讯路径,RSL10户外语音采集板将采集的语音数据通过蓝牙传至室内RSL10模组,再通过Jlink的串口上传至PC Python代码,用于数据分析和处理。PC将数据推送至百度语音识别引擎,识别结果返回给PC。最后下发至室内和户外RSL10模组做相应操作。
四、作品源码和案例中处理的传感器数据
* Copyright (c) 2015-2017 Semiconductor Components Industries, LLC (d/b/a
* ON Semiconductor), All Rights Reserved
* Copyright (C) RivieraWaves 2009-2016
* This module is derived in part from example code provided by RivieraWaves
* and as such the underlying code is the property of RivieraWaves [a member
* of the CEVA, Inc. group of companies], together with additional code which
* is the property of ON Semiconductor. The code (in whole or any part) may not
* be redistributed in any form without prior written permission from
* ON Semiconductor.
* The terms of use and warranty for this code are covered by contractual
* agreements between ON Semiconductor and the licensee.
* This is Reusable Code.
* app.c
* - Main application file
* $Revision: 1.25 $
* $Date: 2017/12/05 16:02:54 $
//20210626 add dmic support by hhz
#include "app.h"
#include <printf.h>
#define DMIC_DATA_WIDTH_16 //16bit DMIC data-- DMIC_DATA_WIDTH_8 8bit DMIC data
#ifdef DMIC_DATA_WIDTH_8 //FS = 16000hz,data width = int8_t,2 second record data =16000*1 =16000 samples
#define DMIC_BUF_SIZE 16000 //100 sample, equal 200 bytes data(int16_t)
#else
#define DMIC_BUF_SIZE 16000 //FS = 16000hz,data width = int16_t,2 second record data =16000*2 =32000 s
#endif
#define BLE_TX_PACKET_SIZE 100 //200
uint32_t output_flag = 0;
uint32_t data_ready_flag = 0; //init not data ready until interruption receive DMIC_BUF_SIZE data from DMIC
int16_t dmic_value_scope_int16 = 0;
int8_t dmic_value_buf[DMIC_BUF_SIZE] = {0}; //d0_msb,d0_lsb,d1_msb,d1_lsb...
#else
int16_t dmic_value_buf[DMIC_BUF_SIZE] = {0}; //d0_msb,d0_lsb,d1_msb,d1_lsb...
#endif
//dmic_value_buf[0] = lsb, dmic_value_buf[1] = msb
uint8_t* dmic_buf_pointer_uint8 = (uint8_t *)dmic_value_buf;
uint32_t j = 0,k = 0;
uint32_t dmic_packet_num = 0;
uint32_t tx_cnt = 0;
uint32_t record_sample_num = 0;
//+ lsb_num,~,~,msb_num packet num uint32 lsb fist
uint8_t* pointer_record_sample_num_uint8 = (uint8_t *)(&record_sample_num);
uint8_t syn_head_array[4] = {0x55,0x55,0x55,0x55}; //+ lsb_num,~,~,msb_num packet num uint32 lsb fist
uint8_t syn_end_array[4] = {0xaa,0xaa,0xaa,0xaa}; //+ lsb_num,~,~,msb_num packet num uint32 lsb fist
uint8_t head_sended_flag = 0;
uint8_t end_sended_flag = 0;
static uint8_t asr_flag = 0;
void DMIC_OUT_OD_IN_IRQHandler(void)
static int32_t i = 0;
//dmic_value_scope_int32 = (int32_t)AUDIO->DMIC0_DATA;
//dmic_value_scope_int16 = (int16_t)((dmic_value_scope_int32 >> 1) & 0xffff);
//dmic_value_scope_int16 = (int16_t)((dmic_value_scope_int32) & 0xffff);
//dmic_value_scope_int16 = (int16_t)(dmic_value_scope_int32);
//PRINTF("%d = %08x = %d\n",dmic_value_scope_int32,dmic_value_scope_int32,dmic_value_scope_int16);
//dmic_value_scope_int16 = (int16_t)AUDIO->DMIC0_DATA;
dmic_value_scope_int16 = (int16_t)((uint16_t)(AUDIO->DMIC_DATA & 0x0000ffff));
Sys_GPIO_Toggle(3); //test frame frequency
//dmic_value_scope_int16 = dmic_packet_num;
//PRINTF("%d = %08x\n",dmic_value_scope_int16,dmic_value_scope_int16);
if(dmic_packet_num < DMIC_BUF_SIZE)
dmic_value_buf[dmic_packet_num] = (int8_t)dmic_value_scope_int16;
#else
dmic_value_buf[dmic_packet_num] = dmic_value_scope_int16;
//dmic_value_buf[dmic_packet_num] = dmic_packet_num;
#endif
dmic_packet_num++;
else
data_ready_flag = 1;
//asr_flag = 2;
//NVIC_DisableIRQ(DMIC_OUT_OD_IN_IRQn); //close DMIC interrupt
void DIO0_IRQHandler(void)
//static uint8_t ignore_next_dio_int = 1;
PRINTF("DIO0 INTERRUPT\n");
asr_flag ++;
if(asr_flag == 2)
NVIC_EnableIRQ(DMIC_OUT_OD_IN_IRQn);
int main(void)
uint32_t length;
uint8_t temp[BUFFER_SIZE]; //for uart
static uint8_t time_cnt = 0;
/* Initialize the system */
App_Initialize();
//setting dio3 as dmic interrupt toggle output for sample rate conform
Sys_DIO_Config(3, DIO_MODE_GPIO_OUT_0); //CLOCK OUTPUT
//Sys_DIO_Config(3, DIO_MODE_AUDIOCLK);
//Sys_DIO_Config(LED_DIO_GREEN, DIO_MODE_GPIO_OUT_0); //GREEN LED
Sys_GPIO_Toggle(LED_DIO_GREEN);
Sys_GPIO_Set_High(LED_DIO_GREEN);
NVIC_EnableIRQ(DIO0_IRQn);
PRINTF("HARDWARE INIT OK !\n"); //hhz
PRINTF("into main loop !\n"); //hhz
/* Main application loop:
* - Run the kernel scheduler
* - Send notifications for the battery voltage and RSSI values
* - Refresh the watchdog and wait for an interrupt before continuing */
while (1)
Kernel_Schedule();
/*if(asr_flag == 2)
//PRINTF("NVIC_EnableIRQ\n");
else if(asr_flag == 0)
//PRINTF("NVIC_DisableIRQ\n");
if (unhandled_packets != NULL)
if (UART_FillTXBuffer(unhandled_packets->length,
unhandled_packets->data) !=
UART_ERRNO_OVERFLOW)
unhandled_packets = removeNode(unhandled_packets);
if (ble_env.state == APPM_CONNECTED)
if (app_env.send_batt_ntf && bass_support_env.enable)
app_env.send_batt_ntf = 0;
Batt_LevelUpdateSend(0, app_env.batt_lvl, 0);
if (cs_env.sentSuccess)
// Copy data from the UART RX buffer to the TX buffer
length = UART_EmptyRXBuffer(temp);
if (length > 0)
// Split buffer into two packets when it's greater than
// packet size
if (length > PACKET_SIZE)
CustomService_SendNotification(ble_env.conidx,
CS_IDX_TX_VALUE_VAL,
temp,
PACKET_SIZE);
&temp[PACKET_SIZE],
length - PACKET_SIZE);
else
temp,
length);
//test dmic first 0~1000 sample data
if((data_ready_flag == 1) & (tx_cnt < DMIC_BUF_SIZE))
PRINTF("%d\n",dmic_value_buf[tx_cnt]);
tx_cnt++;
//if (cs_env.sentSuccess)
if (cs_env.sentSuccess & (data_ready_flag == 1))
head_sended_flag = 1; //without head test
end_sended_flag = 1; //without end test
if(head_sended_flag == 0)
PRINTF("TX:syn_head_array !\n"); //hhz
syn_head_array,
4);
//CustomService_SendNotification(ble_env.conidx,
// CS_IDX_TX_VALUE_VAL,
// pointer_record_sample_num_uint8,
// 4);
for(tx_cnt=0;tx_cnt < DMIC_BUF_SIZE/BLE_TX_PACKET_SIZE;tx_cnt++)
PRINTF("TX:%d ' DMIC packet !\n",tx_cnt);
dmic_buf_pointer_uint8,
BLE_TX_PACKET_SIZE);
dmic_buf_pointer_uint8 += BLE_TX_PACKET_SIZE;
PRINTF("TX:tx dmic watchdog refresh !\n");
Sys_Watchdog_Refresh();
#else
if((data_ready_flag == 1) & (tx_cnt < DMIC_BUF_SIZE*2/BLE_TX_PACKET_SIZE))
//PRINTF("%d\n",dmic_value_buf[tx_cnt]);
// syn_head_array,
// 2);
// syn_end_array,
// 2);
tx_cnt++;
else if((data_ready_flag == 1) & (tx_cnt >= DMIC_BUF_SIZE*2/BLE_TX_PACKET_SIZE))
//without head test
//head_sended_flag = 0;
//end_sended_flag = 0;
tx_cnt = 0;
asr_flag = 0;
PRINTF("close od interrupt,init all flag\n");
/*for(tx_cnt=0;tx_cnt < DMIC_BUF_SIZE*2/BLE_TX_PACKET_SIZE;tx_cnt++)
#endif
if((end_sended_flag == 0) & (data_ready_flag == 0)) //all dmic data have been sended over BLE
PRINTF("TX:syn_end_array !\n"); //hhz
syn_end_array,
4);
//end_sended_flag = 1;
tx_cnt = 0;
asr_flag = 0;
//PRINTF("TX dmic_value_buf\n");
//for(tx_cnt=0;tx_cnt < DMIC_BUF_SIZE;tx_cnt++)
// PRINTF("%d\n",dmic_value_buf[tx_cnt]);
// Sys_Watchdog_Refresh();
//Sys_Watchdog_Refresh();
} //connected
Sys_GPIO_Toggle(3);
/* Refresh the watchdog timer */
/* Wait for an event before executing the scheduler again */
SYS_WAIT_FOR_EVENT;
} //while(1)
} //main
五、视频演示
1、室内机RSL10模组上电;
2、户外RSL10 sensor板上电;
3、启动PC处理程序,连接室内RSL10模组;
4、通过按键启动户外RSL10 sensor模组录音,录音数据通过BLE传输至室内RSL10模组,RSL10模组转接至PC,PC转百度语音识别引擎识别,识别结果返回PC,并做识别结果演示。
演示视频链接如下:
B站:https://www.bilibili.com/video/BV1Ff4y1j7KW?share_source=copy_web
优酷:https://v.youku.com/v_show/id_XNTE4MzEzNDMwNA==.html
六、项目总结
RSL10开发板撘载的多种sensor:例如IMU,DMIC,温度,湿度等传感器,在简单或者复杂环境下,可以同时采集多种数据用于数据分析,以找出环境与传感器的数据关系,从而方便电子设备辨别环境或者动作,实现电子系统对环境和动作的感知。相关的代码例程和sensor硬件DEMO,方便工程师将传感器集成进原来系统内,进而减少时间浪费,快速评估传感器,赞👍!
本项目只完成了户外RSL10模组DMIC数据采集,DMIC数据BLE传输至室内RSL10模组,RSL10通过串口传输音频数据到PC,并通过百度语音识别引擎完成语音识别,并输出识别结果。剩余功能未完成。另DMIC数据以及传输可靠性还需优化,成功率较低。
头一个用到了音频功能!
引用: cruelfox 发表于 2021-7-19 20:58 语音采样率用的多少?8-bit还是16-bit? 感觉BLE要实时传输音频,带宽很吃紧。
没做实时的,我用16bit 16khz配置。另外我的Python没用好,接收不稳定,要做实时就更不好办了。
引用: xujinxi 发表于 2021-7-19 21:29 没做实时的,我用16bit 16khz配置。另外我的Python没用好,接收不稳定,要做实时就更不好办了。
BLE语音实时传输,RSL10有一套remote mic sample 可以了解一下。时延低至40ms。采样率16kHz使用G722编码
引用: 客户专用 发表于 2021-7-27 11:41 BLE语音实时传输,RSL10有一套remote mic sample 可以了解一下。时延低至40ms。采样率16kHz使用G722编码 ...
那还不错,周末找时间试试
