帮忙看以下 这个GPIO驱动。。为什么我测不到波形了?
xag1980   2009-11-6 11:57 楼主
#include
#include "GpioDriver.h"
#include "stdafx.h"
typedef struct _GPIO{
        volatile unsigned int        PORTCFG0;                // 0x000 R/W Port Configuration Register 0
        volatile unsigned int        PORTCFG1;                 // 0x004 R/W Port Configuration Register 1
        volatile unsigned int        PORTCFG2;                // 0x008 R/W Port Configuration Register 2
        volatile unsigned int        PORTCFG3;                // 0x00C R/W Port Configuration Register 3
        volatile unsigned int        PORTCFG4;                // 0x010 R/W Port Configuration Register 4
        volatile unsigned int        PORTCFG5;                // 0x014 R/W Port Configuration Register 5
        volatile unsigned int        PORTCFG6;                // 0x018 R/W Port Configuration Register 6
        volatile unsigned int        PORTCFG7;                // 0x01C R/W Port Configuration Register 7
        volatile unsigned int        PORTCFG8;                // 0x020 R/W Port Configuration Register 8
        volatile unsigned int        PORTCFG9;                // 0x024 R/W Port Configuration Register 9
        volatile unsigned int        PORTCFG10;        // 0x028 R/W Port Configuration Register 10
        volatile unsigned int        PORTCFG11;        // 0x02C R/W Port Configuration Register 11
        volatile unsigned int        PORTCFG12;        // 0x030 R/W Port Configuration Register 12
        volatile unsigned int        PORTCFG13;        // 0x034 R/W Port Configuration Register 13
        volatile unsigned int        NOTDEFINE0;        // 0x038 -
        volatile unsigned int        NOTDEFINE1;        // 0x03C -
        volatile unsigned int        GPADAT;                // 0x040 R/W 0x00000000 GPA Data Register
        volatile unsigned int        GPAEN;                // 0x044 R/W 0x00000000 GPA Output Enable Register
        volatile unsigned int        GPASET;                // 0x048 W - OR function on GPA Output Data
        volatile unsigned int        GPACLR;                // 0x04C W - BIC function on GPA Output Data
        volatile unsigned int        GPAXOR;                // 0x050 W - XOR function on GPA Output Data
        volatile unsigned int        NOTDEFINE2;        // 0x054
        volatile unsigned int        NOTDEFINE3;        // 0x058
        volatile unsigned int        NOTDEFINE4;        // 0x05C
        volatile unsigned int        GPBDAT;                // 0x060 R/W 0x00000000 GPB Data Register
        volatile unsigned int        GPBEN;                // 0x064 R/W 0x00000000 GPB Output Enable Registe
        volatile unsigned int        GPBSET;                // 0x068 W - OR function on GPB Output Data
        volatile unsigned int        GPBCLR;                // 0x06C W - BIC function on GPB Output Data
        volatile unsigned int        GPBXOR;                // 0x070 W - XOR function on GPB Output Data
        volatile unsigned int        NOTDEFINE5;        // 0x074
        volatile unsigned int        NOTDEFINE6;        // 0x078
        volatile unsigned int        NOTDEFINE7;        // 0x07C
        volatile unsigned int        GPCDAT;                // 0x080 R/W 0x00000000 GPC Data Register
        volatile unsigned int        GPCEN;                // 0x084 R/W 0x00000000 GPC Output Enable Register
        volatile unsigned int        GPCSET;                // 0x088 W - OR function on GPC Output Data
        volatile unsigned int        GPCCLR;                // 0x08C W - BIC function on GPC Output Data
        volatile unsigned int        GPCXOR;                // 0x090 W - XOR function on GPC Output Data
        volatile unsigned int        NOTDEFINE8;        // 0x094
        volatile unsigned int        NOTDEFINE9;       // 0x098
        volatile unsigned int        NOTDEFINE10;        // 0x09C
        volatile unsigned int        GPDDAT;                // 0x0A0 R/W 0x00000000 GPD Data Register
        volatile unsigned int        GPDEN;                // 0x0A4 R/W 0x00000000 GPD Output Enable Register
        volatile unsigned int        GPDSET;                // 0x0A8 W - OR function on GPD Output Data
        volatile unsigned int        GPDCLR;                // 0x0AC W - BIC function on GPD Output Data
        volatile unsigned int        GPDXOR;                // 0x0B0 W - XOR function on GPD Output Data
        volatile unsigned int        NOTDEFINE11;        // 0x0B4
        volatile unsigned int        NOTDEFINE12;        // 0x0B8
        volatile unsigned int        NOTDEFINE13;        // 0x0BC
        volatile unsigned int        GPEDAT;                // 0x0C0 R/W 0x00000000 GPE Data Register
        volatile unsigned int        GPEEN;                // 0x0C4 R/W 0x00000000 GPE Output Enable Register
        volatile unsigned int        GPESET;                // 0x0C8 W - OR function on GPE Output Data
        volatile unsigned int        GPECLR;                // 0x0CC W - BIC function on GPE Output Data
        volatile unsigned int        GPEXOR;                // 0x0D0 W - XOR function on GPE Output Data
        volatile unsigned int        NOTDEFINE14[3];   //        0x0D4,0x0D8,0x0DC
        volatile unsigned int        GPFDAT;                  // 0x0E0 R/W 0x00000000 GPF Data Register
        volatile unsigned int        GPFEN;                 //0x0E4 R/W 0x00000000 GPF Output Enable Register
        volatile unsigned int        GPFSET;                 //0x0E8 W - OR function on GPF Output Data
        volatile unsigned int        GPFCLR;                 //0x0EC W - BIC function on GPF Output Data
        volatile unsigned int        GPFXOR;                 //0x0F0 W - XOR function on GPF Output Data
        volatile unsigned int        NOTDEFINE15[3];        //RESERVED 0x0F4 0x0F8 0x0FC
        volatile unsigned int        CPUD0 ;                //0x100 R/W Pull-Up/Down Control Register 0
        volatile unsigned int        CPUD1;                // 0x104 R/W Pull-Up/Down Control Register 1
        volatile unsigned int        CPUD2 ;                //0x108 R/W Pull-Up/Down Control Register 2
        volatile unsigned int        CPUD3 ;                //0x10C R/W Pull-Up/Down Control Register 3
        volatile unsigned int        CPUD4;                // 0x110 R/W Pull-Up/Down Control Register 4
        volatile unsigned int        CPUD5;                // 0x114 R/W Pull-Up/Down Control Register 5
        volatile unsigned int        CPUD6;                // 0x118 R/W Pull-Up/Down Control Register 6
        volatile unsigned int        CPUD7;                 // 0x11C R/W Pull-Up/Down Control Register 7
        volatile unsigned int        CPUD8;                 // 0x120 R/W Pull-Up/Down Control Register 8
        volatile unsigned int        CPUD9 ;                //0x124 R/W Pull-Up/Down Control Register 9
        volatile unsigned int        CPDRV0;                // 0x128 R/W Driver strength Control Register 0
        volatile unsigned int        CPDRV1;                // 0x12C R/W
        volatile unsigned int        AINCFG;                // 0x130 R/W 0x00000000 Analog Input Pad Control Register
        volatile unsigned int        EINTSEL0;                // 0x134 R/W 0x00000000 External Interrupt Select Register 0
        volatile unsigned int        EINTSEL1;                // 0x138 R/W 0x00000000 External Interrupt Select Register 1
        volatile unsigned int        IRQSEL;                // 0x13C R/W 0x00000000 Interrupt Select Register
}GPIO, *PGPIO;
#define IOCTL_GPIO_SET_PIN   0x0000050
#define IOCTL_GPIO_CLR_PIN   0x0000070
#define IOCTL_GPIO_DIS_PIN   0x0000090
//?????÷???????á????
static volatile GPIO * v_pIOPregs;
static int  g_OpenCount = 0;                                      // ?????ò???????÷
#define  BASE_ADDRESS               0xF005A000
#define  ADDRESS_INTERVAL_GPIO                0x04
#define  GPx_GPA                                        0
static BOOL MyGPIO_InitAddresses(void)
        BOOL        RetValue = TRUE;
        //        IO Register Allocation
        v_pIOPregs = (volatile GPIO *)VirtualAlloc(0, sizeof(GPIO), MEM_RESERVE, PAGE_NOACCESS);
        if (v_pIOPregs == NULL)
                ERRORMSG(1,(TEXT("For IOPregs : VirtualAlloc failed!\r\n")));
                RetValue = FALSE;
        else
                if (!VirtualCopy((PVOID)v_pIOPregs, (PVOID)(BASE_ADDRESS >> 8), sizeof(GPIO), PAGE_PHYSICAL | PAGE_READWRITE | PAGE_NOCACHE))
                        ERRORMSG(1,(TEXT("For IOPregs: VirtualCopy failed!\r\n")));
                        RetValue = FALSE;
        if (!RetValue)
                RETAILMSG (1, (TEXT("::: PIO_InitializeAddresses - Fail!!\r\n") ));
                if (v_pIOPregs)
                        VirtualFree((PVOID) v_pIOPregs, 0, MEM_RELEASE);
                v_pIOPregs = NULL;
                RetValue = FALSE;
                return RetValue;
        //?????????÷????GPIOE8
        v_pIOPregs->PORTCFG10 &= ~(0x0f << 12);
        v_pIOPregs->PORTCFG10 |= (0x01 << 12);
        v_pIOPregs->GPEEN |= (0x01 << 8);
        return(RetValue);
DWORD PIO_Init(DWORD dwContext)
        MyGPIO_InitAddresses();
        g_OpenCount = 0;
        return (DWORD)1;
BOOL DllEntry(HINSTANCE hinst_dll, DWORD reason, LPVOID reserved)
    switch (reason) {
    case DLL_PROCESS_ATTACH:
        RETAILMSG(1, (TEXT("[GPIO] Process Attach\r\n")));
        break;
    case DLL_PROCESS_DETACH:
        RETAILMSG(1, (TEXT("[GPIO] Process Detach\r\n")));
        break;
    return TRUE;
BOOL PIO_Close(DWORD Handle)
        g_OpenCount = 0;
    return TRUE;
BOOL PIO_Deinit(DWORD dwContext)
        g_OpenCount = 0;
        if (v_pIOPregs)
                VirtualFree((PVOID) v_pIOPregs, 0, MEM_RELEASE);        /* ??·??ê?????é?????? */
    return TRUE;
DWORD PIO_Open(DWORD dwData, DWORD dwAccess, DWORD dwShareMode)
        if (g_OpenCount > 0)
                return 0;
        g_OpenCount++;
    return g_OpenCount;                                                        /* ·????????????????? */
BOOL GPIO_SetPin(DWORD dwIoControlCode, BYTE PinNum)
        //?è???????????÷??1
        v_pIOPregs->GPESET |=  (0x01 << 8);
        v_pIOPregs->CPUD7 &= ~(0x03 << 30);
        v_pIOPregs->CPUD7 |= (0x01 << 30);
        return TRUE;
BOOL GPIO_ClrPin(DWORD dwIoControlCode, BYTE PinNum)
        //?è???????????÷??0
    v_pIOPregs->GPECLR |=  (0x01 << 8);
        v_pIOPregs->CPUD7 |= (0x02 << 30);
        return TRUE;
BOOL GPIO_Display(DWORD dwIoControlCode, BYTE PinNum)
   v_pIOPregs->PORTCFG10 &= ~(0x01 << 12);
   return TRUE;
BOOL
PIO_IOControl(
    DWORD Handle,
    PBYTE pInBuf,
    DWORD nInBufSize,
    PBYTE pOutBuf,
    DWORD nOutBufSize,
    PDWORD pBytesReturned
        BOOL bErr = FALSE;
        switch(dwIoControlCode)
                case IOCTL_GPIO_SET_PIN:
                    GPIO_SetPin(dwIoControlCode, *pInBuf);
                        break;
                case IOCTL_GPIO_CLR_PIN:
                    GPIO_ClrPin(dwIoControlCode, *pInBuf);
                        break;
                case IOCTL_GPIO_DIS_PIN:
                        GPIO_Display(dwIoControlCode, *pInBuf);
                        break;
    return true;
回复评论 (13)
在PIO_IOControl,GPIO_SetPin, GPIO_ClrPin, GPIO_Display, 这几个函数都加下打印信息,看看调用是否正常
点赞  2009-11-6 12:03
用示波器看看有电平变化没?
点赞  2009-11-6 12:20
引用: 引用 2 楼 cfanlwn 的回复:
用示波器看看有电平变化没?
对哦。。。就是示波器没变化。
点赞  2009-11-6 12:28
引用: 引用 1 楼 veabol 的回复:
USB连接的 用什么函数打印哦?
点赞  2009-11-6 12:29
呵呵,你小子真的很热 啊
点赞  2009-11-6 12:42
首先要确认驱动是否加载成功
点赞  2009-11-6 13:52
1.加载成功了吗?
2.你做测试,总得有一个应用程序来调用驱动吧,是怎么写的?
点赞  2009-11-6 14:02
引用: 引用 4 楼 luocan1986 的回复:
引用 1 楼 veabol 的回复:
USB连接的 用什么函数打印哦?
没有串口向PC发送数据吗?串口输出和KITL总得有种方式来调试驱动吧,否则。。。。难啊
点赞  2009-11-6 14:24
引用: 引用 8 楼 veabol 的回复:
引用 1 楼 veabol 的回复:
USB连接的 用什么函数打印哦?
有串口哈。。
测试程序写了。。。通过IOCONTROL向底层发送信息。。。我发现 GPEDAT对应的值已经改变了。但是波形还是为高,把GPEDAT设为0  无法拉低!
点赞  2009-11-6 14:32
GPE设置成输出了吗?
点赞  2009-11-6 14:44
引用: 引用 10 楼 veabol 的回复:
GPE设置成输出了吗?
设了。。不然改变不了数据寄存器的值啊。
点赞  2009-11-6 14:50
引用: 引用 9 楼 luocan1986 的回复:
引用 8 楼 veabol 的回复:
引用 1 楼 veabol 的回复:
USB连接的 用什么函数打印哦?
有串口哈。。
测试程序写了。。。通过IOCONTROL向底层发送信息。。。我发现 GPEDAT对应的值已经改变了。但是波形还是为高,把GPEDAT设为0? 无法拉低!
晕菜啊,要有波形必须设置为输出。
但是输出之后GPEDAT是不能读的,只能写
所以你说值已经改变,说明你要么没有设置输出,要么读入的是随机值!
点赞  2009-11-6 15:25
找到原因了,是因为我再Init里面对配置寄存器做的初始化,然后有可能其他驱动修改了这个值。
感谢大家。。。结贴给分!
点赞  2009-11-6 15:25
    写回复
