手上有一个从天嵌买的ov9650摄像头,天嵌也提供驱动了,程序可以调用的驱动函数如下:
CIS_Close
CIS_Deinit
CIS_Init
CIS_IOControl
CIS_Open
CIS_PowerDown
CIS_PowerUp
CIS_Read
CIS_Seek
CIS_Write
但是,看了下驱动源代码,这几个函数的实现如下:
DWORD CIS_Open(DWORD hDeviceContext, DWORD AccessCode, DWORD ShareMode)
RETAILMSG(1,(TEXT("CAMERA: CIS_Open\r\n")));
RETAILMSG(1,(TEXT("CAMERA: CIS_Open---------\r\n")));
RETAILMSG(1,(TEXT("CAMERA: CIS_Open----------\r\n")));
RETAILMSG(1,(TEXT("CAMERA: CIS_Open-----------\r\n")));
DRIVER_PREVIEW_ENABLE = 2;
return TRUE;
BOOL CIS_Close(DWORD hOpenContext)
RETAILMSG(1,(TEXT("CAMERA: CIS_Close\r\n")));
return TRUE;
void CIS_PowerDown(DWORD hDeviceContext)
RETAILMSG(1,(TEXT("CAMERA: CIS_PowerDown\r\n")));
m_Dx = (_CEDEVICE_POWER_STATE)D4;
Camif_Capture(CAPTURE_OFF, CAPTURE_OFF);
CamClockOn(FALSE);
//RETAILMSG(1,(TEXT("CAMERA: CIS_PowerDown, m_Dx = D%u, init %d \r\n"), m_Dx, mInitialized));
void CIS_PowerUp(DWORD hDeviceContext)
RETAILMSG(1,(TEXT("CAMERA: CIS_PowerUp\r\n")));
m_Dx = (_CEDEVICE_POWER_STATE)D0;
// 1. Camera IO setup
CamGpioInit();
// 2. Camera Clock setup
CamClockOn(TRUE);
// 3. Camera i/f reset
CAM_IF_Reset();
if (image_size == 1)
CamInit(QCIF_XSIZE, QCIF_YSIZE, QCIF_XSIZE, QCIF_YSIZE, 112, 20, COPIFRAMEBUFFER_B, COPIFRAMEBUFFER_A);
else if (image_size == 2)
CamInit(CIF_XSIZE, CIF_YSIZE, QCIF_XSIZE, QCIF_YSIZE, 112, 20, COPIFRAMEBUFFER_B, COPIFRAMEBUFFER_A);
RETAILMSG(1,(TEXT("CAMERA: CIS_PowerUp, m_Dx = D%u\r\n"), m_Dx));
DWORD CIS_Read(DWORD hOpenContext, LPVOID pBuffer, DWORD Count)
RETAILMSG(1,(TEXT("CAMERA: CIS_Read\r\n")));
return TRUE;
DWORD CIS_Seek(DWORD hOpenContext, long Amount, DWORD Type)
RETAILMSG(1,(TEXT("CAMERA: CIS_Seek\r\n")));
return 0;
DWORD CIS_Write(DWORD hOpenContext, LPCVOID pSourceBytes, DWORD NumberOfBytes)
RETAILMSG(1,(TEXT("CAMERA: CIS_Write\r\n")));
return 0;
这几个函数实际根本没对camera做实际操作,不知道大家用过ov9650吗,能不能给提供点资料
我现在就在弄这个,它是在CIS_IOControl里面有一个
case IOCTL_CAM_CONT :
RETAILMSG(1,(TEXT("CAMERA:IOCTL_CAM_CONT\r\n")));
// Charlie.MSG_EN_1 Play
//DisplayEnable = 1;
// Enable camera interrupt
s2450INT->INTMSK1 &= ~BIT_CAM;
s2450INT->INTSUBMSK &= ~(BIT_SUB_CAM_P|BIT_SUB_CAM_C);
Camif_Capture(CAPTURE_ON, CAPTURE_ON);
//DisplayTime = DISPLAY_SCHEDULE; // polling mode
//SetEvent(CameraEvent);
//#ifndef YL_2440_SUPPORT
// s2450IOP->GPGCON &= ~(0x3<<24);
// s2450IOP->GPGCON |= (0x1<<24); // EINT20
//#endif
frame_count = 0; // for MPEG4
break;
这个需要通过应用程序来调用,调用完就会显示图像
板子上自带cameratest.exe程序也不能显示图像,是程序还是摄像头有问题呢?
都有可能,实在不行,你自己写一个打开的程序 就知道哪的问题了
在IOcontrol函数打开camera中断,然后在中断IST调用显示函数的。
楼主多加打印信息,并且确定你的camera初始化寄存器正确,比较好弄的。
请问,模拟sccb总线时,为什么在发送完一个字节的8位数据后,还要主机发送一位(第9位)“don't care”?“don't care”不应该是从机发给主机的吗?
void __inline ov7620_sccb_writechar(unsigned char data)
int i = 0;
/* data */
for (i = 0; i < 8; i++ ) {
ov7620_sccb_write_bit(data & 0x80);
data <<= 1;
/* 9th bit - Don't care */
ov7620_sccb_write_bit(1);
以下是厂家给的配置:共有三个VGA,CIF,SXVGA,输出都是YUV模式,如是时钟是24M,帧率是15fps,我只验证了VGA模式的,效果还可以!
;09032004
;OV9650
;VGA YUV
;15fps when 24MHz input clock
;Device Address(Hex)/Register(Hex)/Value(Hex)
60 12 80
60 11 81
60 6b 0a
60 6a 3e
60 3b 09
60 13 e0
60 01 80
60 02 80
60 00 00
60 10 00
60 13 e5
60 39 43 ;50 for 30fps
60 38 12 ;92 for 30fps
60 37 00
60 35 91 ;81 for 30fps
60 0e 20
60 1e 04
60 A8 80
60 12 40
60 04 00
60 0c 04
60 0d 80
60 18 c6
60 17 26
60 32 ad
60 03 00
60 1a 3d
60 19 01
60 3f a6
60 14 2e
60 15 02
60 41 02
60 42 08
60 1b 00
60 16 06
60 33 e2 ;c0 for internal regulator
60 34 bf
60 96 04
60 3a 00
60 8e 00
60 3c 77
60 8B 06
60 94 88
60 95 88
60 40 c1
60 29 3f ;2f for internal regulator
60 0f 42
60 3d 92
60 69 40
60 5C b9
60 5D 96
60 5E 10
60 59 c0
60 5A af
60 5B 55
60 43 f0
60 44 10
60 45 68
60 46 96
60 47 60
60 48 80
60 5F e0
60 60 8c ;0c for advanced AWB (related to lens)
60 61 20
60 a5 d9
60 a4 74
60 8d 02
60 13 e7
60 4f 3a
60 50 3d
60 51 03
60 52 12
60 53 26
60 54 38
60 55 40
60 56 40
60 57 40
60 58 0d
60 8C 23
60 3E 02
60 a9 b8
60 aa 92
60 ab 0a
60 8f df
60 90 00
60 91 00
60 9f 00
60 a0 00
60 3A 01
60 24 70
60 25 64
60 26 c3
60 2a 00 ;10 for 50Hz
60 2b 00 ;40 for 50Hz
;gamma
60 6c 40
60 6d 30
60 6e 4b
60 6f 60
60 70 70
60 71 70
60 72 70
60 73 70
60 74 60
60 75 60
60 76 50
60 77 48
60 78 3a
60 79 2e
60 7a 28
60 7b 22
60 7c 04
60 7d 07
60 7e 10
60 7f 28
60 80 36
60 81 44
60 82 52
60 83 60
60 84 6c
60 85 78
60 86 8c
60 87 9e
60 88 bb
60 89 d2
60 8a e6
;09032004
;OV9650
;CIF YUV
60 12 80
60 11 83
60 6b 0a
60 6a 30
60 3b 09
60 13 e0
60 01 80
60 02 80
60 00 00
60 10 00
60 13 e5
60 39 43
60 38 12
60 37 00
60 35 91
60 0e a0
60 1e 04
60 A8 80
60 12 20
60 04 00
60 0c 04
60 0d 80
60 18 7e
60 17 26
60 32 24
60 03 36
60 1a 24
60 19 00
60 14 2e
60 15 02
60 3f a6
60 41 02
60 42 08
60 1b 00
60 16 06
60 34 bf
60 96 04
60 3a 00
60 8e 00
60 3c 77
60 8B 06
60 94 88
60 95 88
60 40 c1
60 0f 42
60 3d 92
60 69 40
60 5C b9
60 5D 96
60 5E 10
60 59 c0
60 5A af
60 5B 55
60 43 f0
60 44 10
60 45 68
60 46 96
60 47 60
60 48 80
60 5F e0
60 61 20
60 a5 d9
60 a4 74
60 8d 02
60 13 e7
60 4f 3a
60 50 3d
60 51 03
60 52 12
60 53 26
60 54 38
60 55 40
60 56 40
60 57 40
60 58 0d
60 8C 23
60 3E 02
60 a9 b8
60 aa 92
60 ab 0a
60 8f df
60 90 00
60 91 00
60 9f 00
60 a0 00
60 3A 01
60 24 70
60 25 64
60 26 c3
60 2a 00 ;00 for 50Hz
60 2b 00 ;D2 for 50Hz
;gamma
60 6c 40
60 6d 30
60 6e 4b
60 6f 60
60 70 70
60 71 70
60 72 70
60 73 70
60 74 60
60 75 60
60 76 50
60 77 48
60 78 3a
60 79 2e
60 7a 28
60 7b 22
60 7c 04
60 7d 07
60 7e 10
60 7f 28
60 80 36
60 81 44
60 82 52
60 83 60
60 84 6c
60 85 78
60 86 8c
60 87 9e
60 88 bb
60 89 d2
60 8a e6
;09032004
;OV9650
;SXGA YUV
;7.5fps when 24MHz input clock
60 12 80
60 11 80
60 6b 0a
60 6a 41
60 3b 09
60 13 e0
60 01 80
60 02 80
60 00 00
60 10 00
60 13 e5
60 39 43 ;50 for 15fps
60 38 12 ;93 for 15fps
60 37 00
60 35 91 ;81 for 15fps
60 0e 20
60 1e 04
60 A8 80
60 12 00
60 04 00
60 0c 00
60 0d 00
60 18 bd
60 17 1d
60 32 ad
60 03 12
60 1a 81
60 19 01
60 14 2e
60 15 00
60 3f a6
60 41 02
60 42 08
60 1b 00
60 16 06
60 34 bf
60 96 04
60 3a 00
60 8e 00
60 3c 77
60 8B 06
60 94 88
60 95 88
60 40 c1
60 0f 42
60 3d 92
60 69 40
60 5C b9
60 5D 96
60 5E 10
60 59 c0
60 5A af
60 5B 55
60 43 f0
60 44 10
60 45 68
60 46 96
60 47 60
60 48 80
60 5F e0
60 60 8C ;0c for advanced AWB (Related to lens)
60 61 20
60 a5 d9
60 a4 74
60 8d 02
60 13 e7
60 4f 3a
60 50 3d
60 51 03
60 52 12
60 53 26
60 54 38
60 55 40
60 56 40
60 57 40
60 58 0d
60 8C 23
60 3E 02
60 a9 b8
60 aa 92
60 ab 0a
60 8f df
60 90 00
60 91 00
60 9f 00
60 a0 00
60 3A 01
60 24 70
60 25 64
60 26 c3
60 2b 00 ;34 for 50Hz
;gamma
60 6c 40
60 6d 30
60 6e 4b
60 6f 60
60 70 70
60 71 70
60 72 70
60 73 70
60 74 60
60 75 60
60 76 50
60 77 48
60 78 3a
60 79 2e
60 7a 28
60 7b 22
60 7c 04
60 7d 07
60 7e 10
60 7f 28
60 80 36
60 81 44
60 82 52
60 83 60
60 84 6c
60 85 78
60 86 8c
60 87 9e
60 88 bb
60 89 d2
60 8a e6
