提示 “WM_HIBERNATE”:未声明的标识符
代码如下:
// HelloCE - A simple application for Windows CE
// Written for the book Programming Windows CE
// Copyright (C) 1998 Douglas Boling
#include // For all that Windows stuff
#include // Command bar includes
#include "helloce.h" // Program-specific stuff
// Global data
const TCHAR szAppName[] = TEXT ("HelloCE");
HINSTANCE hInst; // Program instance handle
// Message dispatch table for MainWindowProc
const struct decodeUINT MainMessages[] = {
WM_CREATE, DoCreateMain,
WM_PAINT, DoPaintMain,
WM_HIBERNATE, DoHibernateMain,
WM_ACTIVATE, DoActivateMain,
WM_DESTROY, DoDestroyMain,
// Program entry point
int WINAPI WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance,
LPWSTR lpCmdLine, int nCmdShow) {
MSG msg;
int rc = 0;
HWND hwndMain;
// init application
rc = InitApp (hInstance);
if (rc) return rc;
// Initialize this instance.
hwndMain = InitInstance (hInstance, lpCmdLine, nCmdShow);
if (hwndMain == 0)
return 0x10;
// Application message loop
while (GetMessage (&msg, NULL, 0, 0)) {
TranslateMessage (&msg);
DispatchMessage (&msg);
// Instance cleanup
return TermInstance (hInstance, msg.wParam);
// InitApp - Application initialization
int InitApp (HINSTANCE hInstance) {
// Register application main window class.
WNDCLASS wc;
wc.style = 0; // Window style
wc.lpfnWndProc = MainWndProc; // Callback function
wc.cbClsExtra = 0; // Extra class data
wc.cbWndExtra = 0; // Extra window data
wc.hInstance = hInstance; // Owner handle
wc.hIcon = NULL, // Application icon
wc.hCursor = NULL; // Default cursor
wc.hbrBackground = (HBRUSH) GetStockObject (WHITE_BRUSH);
wc.lpszMenuName = NULL; // Menu name
wc.lpszClassName = szAppName; // Window class name
if (RegisterClass (&wc) == 0) return 1;
return 0;
// InitInstance - Instance initialization
HWND InitInstance (HINSTANCE hInstance, LPWSTR lpCmdLine,
int nCmdShow) {
HWND hWnd;
// Save program instance handle in global variable.
hInst = hInstance;
// Create main window.
hWnd = CreateWindow (szAppName, // Window class
TEXT("Hello"), // Window title
WS_VISIBLE, // Style flags
CW_USEDEFAULT, // x position
CW_USEDEFAULT, // y position
CW_USEDEFAULT, // Initial width
CW_USEDEFAULT, // Initial height
NULL, // Parent
NULL, // Menu, must be null
hInstance, // Application instance
NULL); // Pointer to create parameters
// Return fail code if window not created.
if (!IsWindow (hWnd)) return 0;
// Standard show and update calls
ShowWindow (hWnd, nCmdShow);
UpdateWindow (hWnd);
return hWnd;
// TermInstance - Program cleanup
int TermInstance (HINSTANCE hInstance, int nDefRC) {
return nDefRC;
// Message handling procedures for main window
// MainWndProc - Callback function for application window
LRESULT CALLBACK MainWndProc (HWND hWnd, UINT wMsg, WPARAM wParam,
LPARAM lParam) {
INT i;
// Search message list to see if we need to handle this
// message. If in list, call procedure.
for (i = 0; i < dim(MainMessages); i++) {
if (wMsg == MainMessages.Code)
return (*MainMessages.Fxn)(hWnd, wMsg, wParam, lParam);
return DefWindowProc (hWnd, wMsg, wParam, lParam);
// DoCreateMain - Process WM_CREATE message for window.
LRESULT DoCreateMain (HWND hWnd, UINT wMsg, WPARAM wParam,
LPARAM lParam) {
HWND hwndCB;
// Create a command bar.
hwndCB = CommandBar_Create (hInst, hWnd, IDC_CMDBAR);
// Add exit button to command bar.
CommandBar_AddAdornments (hwndCB, 0, 0);
return 0;
// DoPaintMain - Process WM_PAINT message for window.
LRESULT DoPaintMain (HWND hWnd, UINT wMsg, WPARAM wParam,
LPARAM lParam) {
PAINTSTRUCT ps;
RECT rect;
HDC hdc;
// Adjust the size of the client rectangle to take into account
// the command bar height.
GetClientRect (hWnd, &rect);
rect.top += CommandBar_Height (GetDlgItem (hWnd, IDC_CMDBAR));
hdc = BeginPaint (hWnd, &ps);
DrawText (hdc, TEXT ("Hello Windows CE!"), -1, &rect,
DT_CENTER | DT_VCENTER | DT_SINGLELINE);
EndPaint (hWnd, &ps);
return 0;
// DoHibernateMain - Process WM_HIBERNATE message for window.
LRESULT DoHibernateMain (HWND hWnd, UINT wMsg, WPARAM wParam,
LPARAM lParam) {
// If not the active window, nuke the command bar to save memory.
if (GetActiveWindow () != hWnd)
CommandBar_Destroy (GetDlgItem (hWnd, IDC_CMDBAR));
return 0;
// DoActivateMain - Process WM_ACTIVATE message for window.
LRESULT DoActivateMain (HWND hWnd, UINT wMsg, WPARAM wParam,
LPARAM lParam) {
HWND hwndCB;
// If activating and no command bar, create it.
if ((LOWORD (wParam) != WA_INACTIVE) &&
(GetDlgItem (hWnd, IDC_CMDBAR) == 0)) {
return 0;
// DoDestroyMain - Process WM_DESTROY message for window.
LRESULT DoDestroyMain (HWND hWnd, UINT wMsg, WPARAM wParam,
LPARAM lParam) {
PostQuitMessage (0);
return 0;
在线等,我第一次用wince,错了都不知道什么地方有问题,请高手指点一下!
错误提示已经说的很清楚了,WM_HIBERNATE 未定义
群:21665782 开源空间 大家一起交流wince开发
