public class Sound
private byte[] m_soundBytes;
private string m_fileName;
private enum Flags
SND_SYNC = 0x0000, /* play synchronously (default) */
SND_ASYNC = 0x0001, /* play asynchronously */
SND_NODEFAULT = 0x0002, /* silence (!default) if sound not found */
SND_MEMORY = 0x0004, /* pszSound points to a memory file */
SND_LOOP = 0x0008, /* loop the sound until next sndPlaySound */
SND_NOSTOP = 0x0010, /* don't stop any currently playing sound */
SND_NOWAIT = 0x00002000, /* don't wait if the driver is busy */
SND_ALIAS = 0x00010000, /* name is a registry alias */
SND_ALIAS_ID = 0x00110000, /* alias is a predefined ID */
SND_FILENAME = 0x00020000, /* name is file name */
SND_RESOURCE = 0x00040004 /* name is resource name or atom */
[DllImport("CoreDll.DLL",EntryPoint="WCE_PlaySound", SetLastError = true)]
private extern static int WCE_PlaySound(string szSound, IntPtr hMod, int flags);
[DllImport("CoreDll.DLL", EntryPoint = "WCE_PlaySound", SetLastError = true)]
private extern static int WCE_PlaySoundBytes(byte[] szSound, IntPtr hMod, int flags);
/// Construct the Sound object to play sound data from the specified file.
public Sound(string fileName)
m_fileName = fileName;
/// Construct the Sound object to play sound data from the specified stream.
public Sound(Stream stream)
// read the data from the stream
m_soundBytes = new byte[stream.Length];
stream.Read(m_soundBytes, 0, (int)stream.Length);
/// Play the sound
public void Play()
// if a file name has been registered, call WCE_PlaySound,
// otherwise call WCE_PlaySoundBytes
if (m_fileName != null)
WCE_PlaySound(m_fileName, IntPtr.Zero, (int)(Flags.SND_ASYNC | Flags.SND_FILENAME));
else
WCE_PlaySoundBytes(m_soundBytes, IntPtr.Zero, (int)(Flags.SND_ASYNC | Flags.SND_MEMORY));
按照网友说的做的,调试出错。
无法找到 PInvoke DLL“CoreDll.DLL”中的入口点“WCE_PlaySound”
请教高手解答!
我把EntryPoint="WCE_PlaySound",
改成EntryPoint="PlaySound", 后不报错了。
调试通过,但是没有播放,没有声音。
private void btn1_Click(object sender, System.EventArgs e)
Sound sound = new Sound(@"ResidentFlash\002.wav");
sound.Play();
来人呢!!
好像和音频文件有关,改用wince系统自带的wav文件就能播放。。奇怪了
