【迪文串口屏】核酸采样登记系统之一 - 国产芯片交流 - 电子工程世界-论坛 (eeworld.com.cn)
【迪文串口屏】核酸采样登记系统之二:准备背景图片 - 国产芯片交流 - 电子工程世界-论坛 (eeworld.com.cn)
【迪文串口屏】核酸采样登记系统之三 连上迪文云 - 国产芯片交流 - 电子工程世界-论坛 (eeworld.com.cn)
接上面的继续:
今天要实现的功能是输入身份证号号码或者手机号码查询出资料,并显示在迪云屏上面:
实现思路是输入手机号码或者身份证号,点击查询,然后通过串口上传到PC,PC接收到命令后读取存储手机或身份证的地址上取回数据,读取excel的数据进行对比。
【python代码】
import time
import serial #导入模块
import threading
from win32com.client import Dispatch
import pythoncom
from excel import *
STRGLO="" #读取的数据
BOOL=True #读取标志位
import win32com.client
cmd_read_phone = bytes([0x5a, 0xa5, 0x04, 0x83, 0x10, 0x60, 0x13])
cmd_read_ID_number = bytes([0x5a, 0xa5, 0x04, 0x83, 0x10, 0x20, 0x18])
cmd_write_to_enter_page = bytes([0x5a, 0xa5, 0x07, 0x82, 0x00, 0x84, 0x5a, 0x01, 0x00, 0x03])
send_list = [0x5a, 0xa5, 0x00, 0x00, 0x00, 0x00]
# 姓名数据组装
def creat_gbk_list(mydata, my_commad, H_address,L_address):
# 发送的list
send_len = 1 + 2 + 2 + len(mydata)*2
send_list[2] = send_len
# 添加 命令
send_list[3] = my_commad
send_list[4] = H_address
send_list[5] = L_address
mysend_list = bytes(send_list) + mydata.encode("gbk") + b'\xFF\xFF'
print(mysend_list)
DWritePort(ser, mysend_list)
def ReadData(ser):
while BOOL:
if ser.in_waiting:
#STRGLO = ser.read(ser.in_waiting).decode("gbk")
# print(STRGLO)
# print("长度为:" + str(len(STRGLO)))
if STRGLO[0] == 0x5a and STRGLO[1] == 0xa5:
#获取地址
addres = STRGLO[4] << 8 | STRGLO[5]
commd = STRGLO[3]
recv_len = STRGLO[2]
print("地址为:" + hex(addres) + " 长度为:" + str(recv_len) + " 命令为:" + hex(commd))
if recv_len == 0x06 and commd == 0x83:
if addres == 0x1080:
print("按身手机号码查询")
# 读取手机号码数据
DWritePort(ser, cmd_read_phone)
elif addres == 0x1090:
print("按身份证查询")
DWritePort(ser, cmd_read_ID_number)
elif commd == 0x83 and recv_len == 42 and addres == 0x1060:
# print("接收到手机号码")
recv_phone_len = STRGLO[6]
if(recv_phone_len == 0x13):
str_ph = STRGLO[7:18]
phone_code = str_ph.decode()
# 开始查找是否有手机号存在
pythoncom.CoInitialize()
try:
xls = easyExcel(r'H:\疫情登记项目\pythonpro\核酸数据库.xlsx')
xls_phone_code = str(int(xls.getCell('Sheet1', 2, 3)))
if xls_phone_code == phone_code:
#获取身份证号码
# 写性别
my_xb = xls.getCell('Sheet1', 2, 5)
creat_gbk_list(my_xb, 0x82, 0x11, 0x20)
my_sh = str(int(xls.getCell('Sheet1', 2, 4)))
creat_gbk_list(my_sh, 0x82, 0x10, 0x20)
# 写职业
my_job = xls.getCell('Sheet1', 2, 6)
creat_gbk_list(my_job, 0x82, 0x11, 0x40)
# 写姓名
my_name = xls.getCell('Sheet1', 2, 2)
creat_gbk_list(my_name, 0x82, 0x11, 0x60)
# 写职业
# 页面转移到确认页面
# 写姓名
DWritePort(ser, cmd_write_to_enter_page)
xls.close()
except Exception as e:
print("出错啦:" + str(e))
xls.close()
pythoncom.CoUninitialize()
else:
print("接收到的电话号码长度不对 长度为:" + str((recv_phone_len-8)))
# 查找手机号
elif commd == 0x83 and recv_len == 52 and addres == 0x1020:
print("接收到手机号码")
recv_ID_len = STRGLO[6]
if(recv_ID_len == 0x18):
str_ID = STRGLO[7:25]
str_ID = str_ID.decode()
# 开始查找是否有手机号存在
try:
ID_code = str(int(xls.getCell('Sheet1', 2, 4)))
if ID_code == str_ID:
# 写性别
#获取手机号码
my_phone = str(int(xls.getCell('Sheet1', 2, 3)))
creat_gbk_list(my_phone, 0x82, 0x10, 0x60)
# 写职业
# 写职业
# 写姓名
# 页面转移到确认页面
xls.close()
xls.close()
else:
# 查找手机号码
else:
print("非法数据")
#打开串口
# 端口,GNU / Linux上的/ dev / ttyUSB0 等 或 Windows上的 COM3 等
# 波特率,标准值之一:50,75,110,134,150,200,300,600,1200,1800,2400,4800,9600,19200,38400,57600,115200
# 超时设置,None:永远等待操作,0为立即返回请求结果,其他值为等待超时时间(单位为秒)
def DOpenPort(portx,bps,timeout):
ret=False
try:
# 打开串口,并得到串口对象
ser = serial.Serial(portx, bps, timeout=timeout)
#判断是否打开成功
if(ser.is_open):
ret=True
threading.Thread(target=ReadData, args=(ser,)).start()
print("---异常---:", e)
return ser, ret
#关闭串口
def DColsePort(ser):
global BOOL
BOOL=False
ser.close()
#写数据
def DWritePort(ser,text):
result = ser.write(text) # 写数据
return result
#读数据
def DReadPort():
global STRGLO
str=STRGLO
STRGLO="" #清空当次读取
return str
def reade_excel():
global STRGLO,BOOL
# 循环接收数据,此为死循环,可用线程实现
try:
xls.close()
return xls_phone_code
if __name__=="__main__":
ser,ret=DOpenPort("COM18",115200,None)
if(ret==True):#判断串口是否成功打开
print("打开串口成功1")
reade_excel()
# count=DWritePort(ser,"我是东小东,哈哈")
# print("写入字节数:",count)
#DReadPort() #读串口数据
#DColsePort(ser) #关闭串口
excel文件:
引用: okhxyyo 发表于 2022-4-28 09:07 赞!另外报告一个发现:数据确认界面那里第一个框没有图标呀?
恩,还得慢慢改,我感觉还是用文字算了。
引用: Fred_1977 发表于 2022-4-28 08:54 非常不错,楼主很用心,代码写的很工整,很清析,点赞!
谢谢,一直在努力中,希望一切顺利!
