import ustruct
class UartTrans:
def __init__(self, uart):
self.uart = uart
self.orders = {}
self.args = {}
CRC16_TABLE = (
0x0000, 0xC0C1, 0xC181, 0x0140, 0xC301, 0x03C0, 0x0280, 0xC241, 0xC601,
0x06C0, 0x0780, 0xC741, 0x0500, 0xC5C1, 0xC481, 0x0440, 0xCC01, 0x0CC0,
0x0D80, 0xCD41, 0x0F00, 0xCFC1, 0xCE81, 0x0E40, 0x0A00, 0xCAC1, 0xCB81,
0x0B40, 0xC901, 0x09C0, 0x0880, 0xC841, 0xD801, 0x18C0, 0x1980, 0xD941,
0x1B00, 0xDBC1, 0xDA81, 0x1A40, 0x1E00, 0xDEC1, 0xDF81, 0x1F40, 0xDD01,
0x1DC0, 0x1C80, 0xDC41, 0x1400, 0xD4C1, 0xD581, 0x1540, 0xD701, 0x17C0,
0x1680, 0xD641, 0xD201, 0x12C0, 0x1380, 0xD341, 0x1100, 0xD1C1, 0xD081,
0x1040, 0xF001, 0x30C0, 0x3180, 0xF141, 0x3300, 0xF3C1, 0xF281, 0x3240,
0x3600, 0xF6C1, 0xF781, 0x3740, 0xF501, 0x35C0, 0x3480, 0xF441, 0x3C00,
0xFCC1, 0xFD81, 0x3D40, 0xFF01, 0x3FC0, 0x3E80, 0xFE41, 0xFA01, 0x3AC0,
0x3B80, 0xFB41, 0x3900, 0xF9C1, 0xF881, 0x3840, 0x2800, 0xE8C1, 0xE981,
0x2940, 0xEB01, 0x2BC0, 0x2A80, 0xEA41, 0xEE01, 0x2EC0, 0x2F80, 0xEF41,
0x2D00, 0xEDC1, 0xEC81, 0x2C40, 0xE401, 0x24C0, 0x2580, 0xE541, 0x2700,
0xE7C1, 0xE681, 0x2640, 0x2200, 0xE2C1, 0xE381, 0x2340, 0xE101, 0x21C0,
0x2080, 0xE041, 0xA001, 0x60C0, 0x6180, 0xA141, 0x6300, 0xA3C1, 0xA281,
0x6240, 0x6600, 0xA6C1, 0xA781, 0x6740, 0xA501, 0x65C0, 0x6480, 0xA441,
0x6C00, 0xACC1, 0xAD81, 0x6D40, 0xAF01, 0x6FC0, 0x6E80, 0xAE41, 0xAA01,
0x6AC0, 0x6B80, 0xAB41, 0x6900, 0xA9C1, 0xA881, 0x6840, 0x7800, 0xB8C1,
0xB981, 0x7940, 0xBB01, 0x7BC0, 0x7A80, 0xBA41, 0xBE01, 0x7EC0, 0x7F80,
0xBF41, 0x7D00, 0xBDC1, 0xBC81, 0x7C40, 0xB401, 0x74C0, 0x7580, 0xB541,
0x7700, 0xB7C1, 0xB681, 0x7640, 0x7200, 0xB2C1, 0xB381, 0x7340, 0xB101,
0x71C0, 0x7080, 0xB041, 0x5000, 0x90C1, 0x9181, 0x5140, 0x9301, 0x53C0,
0x5280, 0x9241, 0x9601, 0x56C0, 0x5780, 0x9741, 0x5500, 0x95C1, 0x9481,
0x5440, 0x9C01, 0x5CC0, 0x5D80, 0x9D41, 0x5F00, 0x9FC1, 0x9E81, 0x5E40,
0x5A00, 0x9AC1, 0x9B81, 0x5B40, 0x9901, 0x59C0, 0x5880, 0x9841, 0x8801,
0x48C0, 0x4980, 0x8941, 0x4B00, 0x8BC1, 0x8A81, 0x4A40, 0x4E00, 0x8EC1,
0x8F81, 0x4F40, 0x8D01, 0x4DC0, 0x4C80, 0x8C41, 0x4400, 0x84C1, 0x8581,
0x4540, 0x8701, 0x47C0, 0x4680, 0x8641, 0x8201, 0x42C0, 0x4380, 0x8341,
0x4100, 0x81C1, 0x8081, 0x4040)
def crc16(self, data):
crc = 0xFFFF
for char in data:
crc = (crc >> 8) ^ self.CRC16_TABLE[((crc) ^ char) & 0xFF]
crc = ustruct.pack('<H', crc)
crc = crc[0] << 8 | crc[1]
return crc
# brief: register cmd
# cmd: strng, cmd name
# fun: the function will be execute
# args: parameter of the fun
def reg_cmd(self, cmd, fun, *args):
hcmd = hash(cmd)
self.orders[hcmd] = fun
self.args[hcmd] = args
# brief: unregister cmd
# cmd: string
def unreg_cmd(self, cmd):
hcmd = hash(cmd)
try:
del self.orders[hcmd]
except:
print("unreg order {} failed".format(cmd))
try:
del self.args[hcmd]
except:
pass
# brief: pack data,
# data: data will be packed
# return: packed data(packed data format: 0xddff(head) len data crc16 0xaaff(end))
def pack_data(self, data, cmd = 0):
head = 0xddff
end = 0xaaff
data = bytearray(data)
crc = self.crc16(data)
fmt = '>HBH'+str(len(data))+'sHH'
is_cmd = 1 if cmd else 0
data = ustruct.pack(fmt, head, is_cmd, len(data), data, crc, end)
return data
# brief: unpack data
# data: the rawdata will be unpacked(rawdata format: 0xddff len data crc16 0xaaff)
# return: unpacked data
def unpack_data(self, data, size):
ra = size - 4
ret = []
for i in range(ra):
try:
(head, is_cmd, len) = ustruct.unpack('>HBH', data[i:i+5])
if(head == 0xddff): # check head
try:
fmt = '>'+str(len)+'sHH'
(s, crc, end) = ustruct.unpack(
fmt, data[i+5:])
if s != None:
crc_check = self.crc16(s)
if crc == crc_check:
ret.append((is_cmd, s))
else:
print("receive crc check failed: ", data)
continue
except:
continue
except:
continue
return ret
def read(self):
read_data = self.uart.read()
if read_data:
udatas = self.unpack_data(read_data, len(read_data))
return udatas
def write(self, s, is_cmd = 0):
s = self.pack_data(s, is_cmd)
return self.uart.write(s)
# execute cmd
# cmd: string
def exec_cmd(self, cmd):
hcmd = hash(cmd)
try:
args = self.args[hcmd]
try:
self.orders[hcmd](*args) # execute cmd fun
except:
print("can't find cmd: ", cmd)
except:
try:
self.orders[hcmd]() # execute cmd fun
except:
def bytes_to_nums(self, b):
ret = []
i = 0
while i < len(b):
try:
t = ustruct.unpack('>s', b[i:i+1]) # type
t = t[0].decode('utf-8')
fmt = '>' + t
try:
num = ustruct.unpack(fmt, b[i+1:])
ret.append(num[0])
i = i + 1 + ustruct.calcsize(str(t))
except:
i = i + 1
except:
i = i + 1
return ret
# fl: uint8_t(B),int8_t(b), uint16_t(H), int16_t(h), uint32_t(I), int32_t(i), double(d), str(s)
def pack_num(self, n, fl):
return ustruct.pack(">s"+fl,fl,n)
# read data, parse to cmd and execute
def parse(self, udatas):
ret = []
if udatas:
for udata in udatas:
is_cmd = udata[0]
if udata[0]: # cmd
self.exec_cmd(udata[1])
else: # data
nums = self.bytes_to_nums(udata[1])
if len(nums) > 0:
ret.append(nums) # is nums
try:
s = udata[1].decode('utf-8') # is string
ret.append(s)
except:
pass
return ret
# 同时开启两个 uartTrans 例程
from fpioa_manager import fm
import time
from machine import UART
import ustruct
from uart_protocol import UartTrans
def cus_cmd(uart, str):
print("execute cus cmd {}".format(str))
uart.write("execute cus cmd {}".format(str))
# read cmd from uart and execute cmd fun
if __name__ == "__main__":
fm.register(22, fm.fpioa.UART1_TX, force=True)
fm.register(21, fm.fpioa.UART1_RX, force=True)
fm.register(24, fm.fpioa.UART2_TX, force=True)
fm.register(23, fm.fpioa.UART2_RX, force=True)
uart1 = UART(UART.UART1, 115200, 8, 1, 0, timeout=1000, read_buf_len=4096)
uart2 = UART(UART.UART2, 115200, 8, 1, 0, timeout=1000, read_buf_len=4096)
uart_TA = UartTrans(uart1)
uart_TB = UartTrans(uart2)
# pack cus cmd and send
print("send the packed 'cus' cmd to uart1")
uart_TA.write('cus', 1)
# register cus cmd
uart_TA.reg_cmd("cus", cus_cmd, uart1, "cus1")
uart_TB.reg_cmd("cus", cus_cmd, uart2, "cus2")
# start to parse the receive cmd
while True:
uart_TA.parse(uart_TA.read())
uart_TB.parse(uart_TB.read())
time.sleep_ms(100)
'''output
pc send:
DD FF 01 00 03 63 75 73 E6 AB AA FF
analysis:
DD FF: head
01: cmd type
00 03: cmd len
63 75 73: 'cus'
E6 AB: crc16
AA FF: end
output:
recv cmd: b'cus'
execute cus cmd 1
'''packed data: cmd: b'cus'
到这一步,大家都觉得完全没有难度,可是用PC下发以上格式的数据包,采用了CRC16的校验和,如果每次通过上位机手动发送命令时候,都是手工计算组包,那不是效率非常低?
引用: lugl4313820 发表于 2022-8-21 18:06 LoRa的通信速度可以达到多少列,好象这个板子匹配115200.
LoRa速率比较慢的,用来传结果是够的,传图像参数不适合! 。。。计划跑500K速率
