一:叙述
本来这篇是想做一个总结的,但是因为测评使用过程中出现的问题已经记录,并且在实际开发过程中要用到freertos实时系统,所以不再总结,而是在官方提供的freertos_demo中进行了更改,算是做一个小小的测试!
二:程序
在FreeRTOSConfig.h文件中,将configTICK_RATE_HZ宏定义由500修改为了1000;
* @File main.c
* @brief This is the source file for B91m
* @author Driver Group
* @date 2019
* @par Copyright (c) 2019, Telink Semiconductor (Shanghai) Co., Ltd. ("TELINK")
* All rights reserved.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
#include "app_config.h"
#include "calibration.h"
#include <FreeRTOS.h>
#include <task.h>
#include <queue.h>
#include <timers.h>
#include <stdio.h>
#define timerTick 4
static TaskHandle_t test_handle=NULL;
static TimerHandle_t softWaveTimer=NULL;
static uint32_t MboxValue;
static void test_task(void *pvParameters){
uint32_t notifyValue;
while(1){
if(pdTRUE == xTaskNotifyWait((uint32_t )0x00,(uint32_t)0xffffffff,(uint32_t*)¬ifyValue,0)){
printf("Hello!\r\n");
if(notifyValue >= timerTick){
xTimerStop(softWaveTimer,0);
vTaskDelay(10);
(void)(pvParameters);
extern void vPortRestoreTask();
void pxSoftWaveTimer(TimerHandle_t xTimer)
uint32_t TimerID;
TimerID = (uint32_t)pvTimerGetTimerID(xTimer);//获取定时器ID
if(TimerID == 1){
xTaskNotify((TaskHandle_t )test_handle,(uint32_t )MboxValue,(eNotifyAction)eSetValueWithOverwrite);
MboxValue++;
* @brief This is main function
* @return none
int main (void)
sys_init(LDO_1P4_LDO_1P8, VBAT_MAX_VALUE_GREATER_THAN_3V6);
user_read_flash_value_calib();
CCLK_24M_HCLK_24M_PCLK_24M;
if(0 ){// deepRetWakeUp
vPortRestoreTask();
}else{
xTaskCreate( test_task,"test",configMINIMAL_STACK_SIZE,NULL,0,&test_handle );
softWaveTimer = xTimerCreate("softwaveTimer",1000,pdTRUE,(void*)1,pxSoftWaveTimer);
xTimerStart(softWaveTimer,0);
vTaskStartScheduler();
return 0;
三:现象
这个总结好!
