我现在做的板用的是64M的SDRAM,32Mnorflash,256Mnandflash
eboot.bib
MEMORY
; Name Start Size Type
STACK 80000000 00010000 RESERVED该物理地址在手册中用的是nSDCS2片选,我用的是nsdcs0片选要改成0xA0000000吗 RAM 80010000 00010000 RAM
EBOOT 80020000 00040000 RAMIMAGE
RSVD 80060000 0009F000 RESERVED
ARGS 80FF0000 00001000 RESERVED
CONFIG
AUTOSIZE=OFF
COMPRESSION=OFF
PROFILE=OFF
KERNELFIXUPS=ON
ROMSTART=80020000
ROMWIDTH=32
ROMSIZE=00040000
ROMOFFSET=3C9E0000
MODULES
; Name Path Memory Type
nk.exe $(_TARGETPLATROOT)\target\$(_TGTCPU)\$(WINCEDEBUG)\eboot.exe EBOOT
config.bib
MEMORY
RSVD 80000000 000FF000 RESERVED
ARGS 800FF000 00001000 RESERVED
NK 80100000 03000000 RAMIMAGE 这边的是在mainstoneii平台下拷贝的用不用修改吗?
RAM 83100000 00F00000 RAM
; Reserve ZBANK virtual block (No physical memory
; is required to back this virtual range).
ZBANK 96500000 00100000 RESERVED
CONFIG
AUTOSIZE=ON
KERNELFIXUPS=ON
; @CESYSGEN IF !NK_NKNOCOMP
COMPRESSION=ON
; @CESYSGEN ENDIF !NK_NKNOCOMP
; @CESYSGEN IF NK_NKNOCOMP
COMPRESSION=OFF
; @CESYSGEN ENDIF NK_NKNOCOMP
IF IMGPROFILER
PROFILE=ON
ELSE
PROFILE=OFF
ENDIF
; ROMFLAGS is a bitmask of options for the kernel
; ROMFLAGS 0x0001 Disallow Paging
; ROMFLAGS 0x0002 Not all KMode
; ROMFLAGS 0x0010 Trust Module only
IF IMGTRUSTROMONLY
IF IMGNOTALLKMODE
ROMFLAGS=12
ELSE
ROMFLAGS=10
ENDIF
ELSE
IF IMGNOTALLKMODE
ROMFLAGS=02
ELSE
ROMFLAGS=00
ENDIF
ENDIF
ALIGN
g_oalAddressTable
DCD 0x80000000, 0xA0000000, 64 ; MAINSTONEII: SDRAM (64MB).
DCD 0x84000000, 0x5C000000, 1 ; BULVERDE: Internal SRAM (64KB bank 0).
DCD 0x84100000, 0x58000000, 1 ; BULVERDE: Internal memory PM registers.
DCD 0x84200000, 0x4C000000, 1 ; BULVERDE: USB host controller.
DCD 0x84300000, 0x48000000, 1 ; BULVERDE: Memory controller.
DCD 0x84400000, 0x44000000, 1 ; BULVERDE: LCD controller.
DCD 0x84500000, 0x40000000, 32 ; BULVERDE: Memory-mapped registers (peripherals).
DCD 0x86500000, 0x3C000000, 64 ; BULVERDE: PCMCIA S1 common memory space.
DCD 0x8A500000, 0x38000000, 64 ; BULVERDE: PCMCIA S1 attribute memory space.
DCD 0x8E500000, 0x30000000, 32 ; BULVERDE: PCMCIA S1 I/O space.
DCD 0x90500000, 0x2C000000, 64 ; BULVERDE: PCMCIA S0 common memory space.
DCD 0x94500000, 0x28000000, 64 ; BULVERDE: PCMCIA S0 attribute memory space.
DCD 0x98500000, 0x20000000, 32 ; BULVERDE: PCMCIA S0 I/O space.
DCD 0x9A500000, 0xE0000000, 1 ; MAINSTONEII: Zero-bank (in reserved slot - no physical memory required).
DCD 0x9A600000, 0x14000000, 1 ; MAINSTONEII: nCS5: eXpansion board header.
DCD 0x9A700000, 0x10000000, 1 ; MAINSTONEII: nCS4: SMSC 91C111 Ethernet controller.
DCD 0x9A800000, 0x0A000000, 1 ; MAINSTONEII: nCS2 (upper half): 2MB SRAM.
DCD 0x9A900000, 0x08000000, 1 ; MAINSTONEII: nCS2 (lower half): Board registers (FPGA).
DCD 0x9AA00000, 0x04000000, 32 ; MAINSTONEII: nCS1: nandflash (32MB).nandflash用32M能实现256M的寻址吗?要是换成cpld可不可以放在ncs2片选上? DCD 0x9CA00000, 0x00000000, 32 ; MAINSTONEII: nCS0: Boot Flash (32MB).
DCD 0x9EA00000, 0x50000000, 1 ; BULVERDE: Camera peripheral interface.
DCD 0x00000000, 0x00000000, 0 ; end of table
END
nsdcs0的物理地址是多少?
这个跟你程序的BOOT里面启动代码定义的地址有关(忘记具体在哪里了)
你得看你的EBOOT
这个不懂
nsdcs0片选端的物理地址在手册上是0xA0000000,我看你以前的贴子上面的sdram在g_oalAddressTable 中是
DCD 0x80000000, 0xA0000000, 64 ; MAINSTONEII: SDRAM (64MB).而在boot.bib中用的是 80000000 这是为什么?
