[原创] 【ST NUCLEO-U575ZI-Q 测评 】串口收发测试
qinyunti   2022-12-15 21:33 楼主
前言
串口作为最常用的通讯接口,我们先实现串口的收发,后面标准输入输出,但因调试等都依赖于传口。
串口模块
参见《58 Low-power universal asynchronous receiver transmitter (LPUART)》
引脚
使用PG7-PG8  LPUART1-TX LPUART1-RX,对应AF8
LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOG);
  /* PG7 TX */
LL_GPIO_InitTypeDef GPIO_InitStruct;
//LL_GPIO_StructInit(&GPIO_InitStruct);
GPIO_InitStruct.Pin = LL_GPIO_PIN_7;
GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
GPIO_InitStruct.Pull = LL_GPIO_PULL_UP;
GPIO_InitStruct.Alternate = LL_GPIO_AF_8;
LL_GPIO_Init(GPIOG, &GPIO_InitStruct);
  /* PG8 RX */
GPIO_InitStruct.Pin = LL_GPIO_PIN_8;
时钟
从时钟树可以看到LPUART1时钟可以来源于SYSCLK->AHB->APB3->PCLK3
也可以来源于MSIK,HSI16,LSE。我们选择PCLK3。
AHB和APB3分频之前在RCC配置时设置
RCC_ClkInitTypeDef pRCC_ClkInitStruct;
pRCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK;
pRCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
pRCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
pRCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
pRCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
pRCC_ClkInitStruct.APB3CLKDivider = RCC_HCLK_DIV2;
HAL_RCC_ClockConfig(&pRCC_ClkInitStruct, FLASH_LATENCY_4);
这里分别是分频1和2所以 LPUART的输入时钟是160MHz/2=80MHz
使能时钟
LL_APB3_GRP1_EnableClock(LL_APB3_GRP1_PERIPH_LPUART1);
串口配置
LL_LPUART_InitTypeDef LPUART_InitStruct;
LPUART_InitStruct.BaudRate = 115200;
LPUART_InitStruct.DataWidth = LL_LPUART_DATAWIDTH_8B;
LPUART_InitStruct.HardwareFlowControl = LL_LPUART_HWCONTROL_NONE;
LPUART_InitStruct.Parity = LL_LPUART_PARITY_NONE;
LPUART_InitStruct.PrescalerValue = LL_LPUART_PRESCALER_DIV1;
LPUART_InitStruct.StopBits = LL_LPUART_STOPBITS_1;
LPUART_InitStruct.TransferDirection = LL_LPUART_DIRECTION_TX_RX;
LL_LPUART_Init(LPUART1, &LPUART_InitStruct);
中断配置
使能接收非空中断,发送非空中断暂时不使能(否则使能后马上回进入中断,后续实现中断发送再讲)
LL_LPUART_EnableIT_RXNE_RXFNE(LPUART1);
//LL_LPUART_EnableIT_TXE_TXFNF(LPUART1);
__NVIC_EnableIRQ(LPUART1_IRQn);
__NVIC_SetPriority(LPUART1_IRQn, 3);
LPUART_ISR中中断标志
RXNE中断时读RDR清除标志
TXE中断时写TDR清除标志。
中断处理
收到数据后原样返回
void LPUART1_IRQHandler(void)
if(LL_LPUART_IsActiveFlag_RXNE_RXFNE(LPUART1) == SET)
LL_LPUART_TransmitData8(LPUART1,LL_LPUART_ReceiveData8(LPUART1));
if(LL_LPUART_IsActiveFlag_TXE_TXFNF(LPUART1))
串口使能
LL_LPUART_Enable(LPUART1);
测试
添加uart.c
#include "stm32u575xx.h"
#include "stm32u5xx_ll_gpio.h"
#include "stm32u5xx_ll_bus.h"
#include "stm32u5xx_ll_lpuart.h"
void uart_init(void)
  /* PG7 TX */
  /* PG8 RX */
uart.h
#ifndef UART_H
#define UART_H
void uart_init(void);
#endif
main.c
main中调用uart_init即可
#include "uart.h"
void SysTick_Handler(void)
    static volatile uint32_t num = 0;
    if(num++ >= 1000)
        LL_GPIO_TogglePin(GPIOB, 1u<<7);
        LL_GPIO_TogglePin(GPIOG, 1u<<2);
        LL_GPIO_TogglePin(GPIOC, 1u<<7);
        num=0;
    HAL_IncTick();
void delay(uint32_t t)
    volatile uint32_t timeout = t;
    while(t--);
int main(void)
    HAL_Init();
    LL_AHB3_GRP1_EnableClock(LL_AHB3_GRP1_PERIPH_PWR);
    HAL_PWREx_EnableVddIO2();
    HAL_PWREx_ConfigSupply(PWR_SMPS_SUPPLY);
#if 1
    HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
    RCC_OscInitTypeDef pRCC_OscInitStruct;
    pRCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
    pRCC_OscInitStruct.HSIState = RCC_HSI_ON;
    pRCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
    pRCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
    pRCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
    pRCC_OscInitStruct.PLL.PLLM = 1;
    pRCC_OscInitStruct.PLL.PLLMBOOST = RCC_PLLMBOOST_DIV1;
    pRCC_OscInitStruct.PLL.PLLN = 20;
    pRCC_OscInitStruct.PLL.PLLP = 1;
    pRCC_OscInitStruct.PLL.PLLQ = 1;
    pRCC_OscInitStruct.PLL.PLLR = 2;
    pRCC_OscInitStruct.PLL.PLLRGE = RCC_PLLVCIRANGE_0;
    pRCC_OscInitStruct.PLL.PLLFRACN = 0;  /* */
    HAL_RCC_OscConfig(&pRCC_OscInitStruct);
#endif
    LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOB);
    LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOC);
    GPIO_InitStruct.Mode = LL_GPIO_MODE_OUTPUT;
    GPIO_InitStruct.Alternate = LL_GPIO_AF_0;
    LL_GPIO_Init(GPIOB, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = LL_GPIO_PIN_2;
    GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_HIGH;
    LL_GPIO_Init(GPIOC, &GPIO_InitStruct);
    uart_init();
    while(1)
串口调试助手发送数据,原样收到说明测试OK。
也可以查看外设寄存器
总结
使用库进行外设操作比较简单,一般外设操作就是时钟,引脚,外设参数,中断,使能等几个步骤,得益于完善的库操作起来都比较简单。不过也需要了解外设的基本操作逻辑,有问题查看手册,最需要注意的是,先要使能相应时钟,先清标志最后使能中断,使能模块等。
回复评论 (2)
U系列主打安全?
默认摸鱼,再摸鱼。2022、9、28
点赞  2022-12-27 14:17
测评汇总:免费申请|ST NUCLEO-U575ZI-Q https://bbs.eeworld.com.cn/thread-1228653-1-1.html
玩板看这里: https://bbs.eeworld.com.cn/elecplay.html EEWorld测评频道众多好板等你来玩,还可以来频道许愿树许愿说说你想要玩的板子,我们都在努力为大家实现!
点赞  2023-1-12 09:42
    写回复
