[MCU] 【 HC32F4A0开发板】外部SRAM存储器读写测试
TL-LED   2023-2-20 00:07 楼主
    测试下开发板上外部SRAM存储器,将读取写入外部SRAM的数据在显示屏上刷新显示。
一、硬件部分
1.1、外部SRAM存储器部分电路图
1.2、手册中外部存储器空间地址分配
20230219234647.png SMC地址范围:0x60000000~0x7FFFFFFF
地址空间的大小可自定设置,通过片选控制寄存器设定
二、程序部分
2.1、SRAM驱动部分
SRAM驱动程序在官方的SDK中已经有了,包含了SMC的端口初始化和芯片时序的配置。
ev_hc32f4a0_lqfp176_is62wv51216.c
 * [url=home.php?mod=space&uid=1307177]@File[/url]  ev_hc32f4a0_lqfp176_is62wv51216.c
 * [url=home.php?mod=space&uid=159083]@brief[/url]  This file provides configure functions for is62wv51216 of the board
 *        EV_HC32F4A0_LQFP176.
 @verbatim
   Change Logs:
   Date             Author          Notes
   2022-03-31       CDT             First version
   2022-10-31       CDT             Add timing comments.
 @endverbatim
 * Copyright (C) 2022-2023, Xiaohua Semiconductor Co., Ltd. All rights reserved.
 * This software component is licensed by XHSC under BSD 3-Clause license
 * (the "License"); You may not use this file except in compliance with the
 * License. You may obtain a copy of the License at:
 *                    opensource.org/licenses/BSD-3-Clause
 * Include files
#include <string.h>
#include "hc32_ll_fcg.h"
#include "ev_hc32f4a0_lqfp176_is62wv51216.h"
 * @addtogroup BSP
 * @addtogroup EV_HC32F4A0_LQFP176
 * @defgroup EV_HC32F4A0_LQFP176_IS62WV51216 EV_HC32F4A0_LQFP176 IS62WV51216
#if ((DDL_ON == BSP_IS62WV51216_ENABLE) && (BSP_EV_HC32F4A0_LQFP176 == BSP_EV_HC32F4XX))
 * Local type definitions ('typedef')
 * Local pre-processor symbols/macros ('#define')
 * @defgroup EV_HC32F4A0_LQFP176_IS62WV51216_Local_Macros  EV_HC32F4A0_LQFP176 IS62WV51216 Local Macros
 * @defgroup SMC_Max_Timeout SMC Max Timeout
#define SMC_MAX_TIMEOUT                 (0x100000UL)
 * Global variable definitions (declared in header file with 'extern')
 * Local function prototypes ('static')
 * Local variable definitions ('static')
 * @addtogroup EV_HC32F4A0_LQFP176_IS62WV51216_Local_Functions
static void BSP_SMC_PortInit(void);
 * Function implementation - global ('extern') and local ('static')
 * @defgroup EV_HC32F4A0_LQFP176_IS62WV51216_Global_Functions EV_HC32F4A0_LQFP176 IS62WV51216 Global Functions
 * @brief  Initialize SMC for IS62WV51216.
 * @param  None
 * @retval int32_t:
 *           - LL_OK:                   Initialize successfully.
 *           - LL_ERR:                  Initialize unsuccessfully.
int32_t BSP_IS62WV51216_Init(void)
    __IO uint32_t u32To = 0UL;
    int32_t i32Ret = LL_OK;
    stc_exmc_smc_init_t stcSmcInit;
    stc_exmc_smc_chip_config_t stcChipConfig;
    stc_exmc_smc_timing_config_t stcTimingConfig;
    en_flag_status_t enChipStatus = RESET;
    en_flag_status_t enTimingStatus = RESET;
    /* Initialize SMC port. */
    BSP_SMC_PortInit();
    /* Enable SMC clock */
    FCG_Fcg3PeriphClockCmd(FCG3_PERIPH_SMC, ENABLE);
    /* Enable SMC. */
    EXMC_SMC_Cmd(ENABLE);
    EXMC_SMC_ExitLowPower();
    while (EXMC_SMC_READY != EXMC_SMC_GetStatus()) {
        if (u32To > SMC_MAX_TIMEOUT) {
            i32Ret = LL_ERR;
            break;
        u32To++;
    if (LL_OK == i32Ret) {
        /* Configure SMC width && CS &chip & timing. */
        (void)EXMC_SMC_StructInit(&stcSmcInit);
        stcSmcInit.stcChipConfig.u32ReadMode = EXMC_SMC_READ_ASYNC;
        stcSmcInit.stcChipConfig.u32ReadBurstLen = EXMC_SMC_READ_BURST_1BEAT;
        stcSmcInit.stcChipConfig.u32WriteMode = EXMC_SMC_WRITE_ASYNC;
        stcSmcInit.stcChipConfig.u32WriteBurstLen = EXMC_SMC_WRITE_BURST_1BEAT;
        stcSmcInit.stcChipConfig.u32MemoryWidth = EXMC_SMC_MEMORY_WIDTH_16BIT;
        stcSmcInit.stcChipConfig.u32BAA = EXMC_SMC_BAA_PORT_DISABLE;
        stcSmcInit.stcChipConfig.u32ADV = EXMC_SMC_ADV_PORT_DISABLE;
        stcSmcInit.stcChipConfig.u32BLS = EXMC_SMC_BLS_SYNC_CS;
        stcSmcInit.stcChipConfig.u32AddrMatch = BSP_IS62WV51216_MATCH_ADDR;
        stcSmcInit.stcChipConfig.u32AddrMask = BSP_IS62WV51216_MASK_ADDR;
        /* EXCLK bus frequency@60MHz: 3.3V */
        stcSmcInit.stcTimingConfig.u8RC = 4U;   /* tRC: min=55ns */
        stcSmcInit.stcTimingConfig.u8WC = 4U;   /* tWC: min=55ns */
        stcSmcInit.stcTimingConfig.u8CEOE = 1U;
        stcSmcInit.stcTimingConfig.u8WP = 3U;   /* tWP: min=40ns */
        stcSmcInit.stcTimingConfig.u8PC = 1U;
        stcSmcInit.stcTimingConfig.u8TR = 1U;
        (void)EXMC_SMC_Init(BSP_IS62WV51216_CHIP, &stcSmcInit);
        /* Set command: updateregs */
        EXMC_SMC_SetCommand(BSP_IS62WV51216_CHIP, EXMC_SMC_CMD_UPDATEREGS, 0UL, 0UL);
        /* Check timing status */
        u32To = 0UL;
        while ((enChipStatus != SET) || (enTimingStatus != SET)) {
            (void)EXMC_SMC_GetTimingConfig(BSP_IS62WV51216_CHIP, &stcTimingConfig);
            if (0 == memcmp(&stcTimingConfig, &stcSmcInit.stcTimingConfig, sizeof(stcTimingConfig))) {
                enTimingStatus = SET;
            (void)EXMC_SMC_GetChipConfig(BSP_IS62WV51216_CHIP, &stcChipConfig);
            if (0 == memcmp(&stcChipConfig, &stcSmcInit.stcChipConfig, sizeof(stcChipConfig))) {
                enChipStatus = SET;
                i32Ret = LL_ERR;
                break;
            u32To++;
    return i32Ret;
 * @brief  Get memory information.
 * @param  [out] pu32MemoryStartAddr    Pointer to memory start address
 * @param  [out] pu32MemoryByteSize     Pointer to memory size(unit: Byte)
 * @retval None
void BSP_IS62WV51216_GetMemInfo(uint32_t *pu32MemoryStartAddr, uint32_t *pu32MemoryByteSize)
    if (NULL != pu32MemoryStartAddr) {
        *pu32MemoryStartAddr = BSP_IS62WV51216_START_ADDR;
    if (NULL != pu32MemoryByteSize) {
        *pu32MemoryByteSize = BSP_IS62WV51216_SIZE;
 * @defgroup EV_HC32F4A0_LQFP176_IS62WV51216_Local_Functions EV_HC32F4A0_LQFP176 IS62WV51216 Local Functions
 * @brief  Initialize SMC port.
 * @param  None
 * @retval None
    stc_gpio_init_t stcGpioInit;
    /************************* Set pin drive capacity *************************/
    (void)GPIO_StructInit(&stcGpioInit);
    stcGpioInit.u16PinDrv = PIN_HIGH_DRV;
    /* SMC_CS */
    (void)GPIO_Init(BSP_IS62WV51216_CS_PORT, BSP_IS62WV51216_CS_PIN, &stcGpioInit);
    /* SMC_WE */
    (void)GPIO_Init(BSP_IS62WV51216_WE_PORT, BSP_IS62WV51216_WE_PIN, &stcGpioInit);
    /* SMC_BLS[0:1] */
    (void)GPIO_Init(BSP_IS62WV51216_BLS0_PORT, BSP_IS62WV51216_BLS0_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_BLS1_PORT, BSP_IS62WV51216_BLS1_PIN, &stcGpioInit);
    /* SMC_OE */
    (void)GPIO_Init(BSP_IS62WV51216_OE_PORT, BSP_IS62WV51216_OE_PIN, &stcGpioInit);
    /* SMC_DATA[0:15] */
    (void)GPIO_Init(BSP_IS62WV51216_DATA0_PORT, BSP_IS62WV51216_DATA0_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA1_PORT, BSP_IS62WV51216_DATA1_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA2_PORT, BSP_IS62WV51216_DATA2_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA3_PORT, BSP_IS62WV51216_DATA3_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA4_PORT, BSP_IS62WV51216_DATA4_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA5_PORT, BSP_IS62WV51216_DATA5_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA6_PORT, BSP_IS62WV51216_DATA6_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA7_PORT, BSP_IS62WV51216_DATA7_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA8_PORT, BSP_IS62WV51216_DATA8_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA9_PORT, BSP_IS62WV51216_DATA9_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA10_PORT, BSP_IS62WV51216_DATA10_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA11_PORT, BSP_IS62WV51216_DATA11_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA12_PORT, BSP_IS62WV51216_DATA12_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA13_PORT, BSP_IS62WV51216_DATA13_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA14_PORT, BSP_IS62WV51216_DATA14_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_DATA15_PORT, BSP_IS62WV51216_DATA15_PIN, &stcGpioInit);
    /* SMC_ADD[0:18]*/
    (void)GPIO_Init(BSP_IS62WV51216_ADD0_PORT, BSP_IS62WV51216_ADD0_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD1_PORT, BSP_IS62WV51216_ADD1_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD2_PORT, BSP_IS62WV51216_ADD2_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD3_PORT, BSP_IS62WV51216_ADD3_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD4_PORT, BSP_IS62WV51216_ADD4_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD5_PORT, BSP_IS62WV51216_ADD5_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD6_PORT, BSP_IS62WV51216_ADD6_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD7_PORT, BSP_IS62WV51216_ADD7_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD8_PORT, BSP_IS62WV51216_ADD8_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD9_PORT, BSP_IS62WV51216_ADD9_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD10_PORT, BSP_IS62WV51216_ADD10_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD11_PORT, BSP_IS62WV51216_ADD11_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD12_PORT, BSP_IS62WV51216_ADD12_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD13_PORT, BSP_IS62WV51216_ADD13_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD14_PORT, BSP_IS62WV51216_ADD14_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD15_PORT, BSP_IS62WV51216_ADD15_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD16_PORT, BSP_IS62WV51216_ADD16_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD17_PORT, BSP_IS62WV51216_ADD17_PIN, &stcGpioInit);
    (void)GPIO_Init(BSP_IS62WV51216_ADD18_PORT, BSP_IS62WV51216_ADD18_PIN, &stcGpioInit);
    /************************** Set EXMC pin function *************************/
    /* SMC_CS */
    GPIO_SetFunc(BSP_IS62WV51216_CS_PORT, BSP_IS62WV51216_CS_PIN, GPIO_FUNC_12);
    /* SMC_WE */
    GPIO_SetFunc(BSP_IS62WV51216_WE_PORT, BSP_IS62WV51216_WE_PIN, GPIO_FUNC_12);
    /* SMC_BLS[0:1] */
    GPIO_SetFunc(BSP_IS62WV51216_BLS0_PORT, BSP_IS62WV51216_BLS0_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_BLS1_PORT, BSP_IS62WV51216_BLS1_PIN, GPIO_FUNC_12);
    /* SMC_OE */
    GPIO_SetFunc(BSP_IS62WV51216_OE_PORT, BSP_IS62WV51216_OE_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA0_PORT, BSP_IS62WV51216_DATA0_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA1_PORT, BSP_IS62WV51216_DATA1_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA2_PORT, BSP_IS62WV51216_DATA2_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA3_PORT, BSP_IS62WV51216_DATA3_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA4_PORT, BSP_IS62WV51216_DATA4_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA5_PORT, BSP_IS62WV51216_DATA5_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA6_PORT, BSP_IS62WV51216_DATA6_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA7_PORT, BSP_IS62WV51216_DATA7_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA8_PORT, BSP_IS62WV51216_DATA8_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA9_PORT, BSP_IS62WV51216_DATA9_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA10_PORT, BSP_IS62WV51216_DATA10_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA11_PORT, BSP_IS62WV51216_DATA11_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA12_PORT, BSP_IS62WV51216_DATA12_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA13_PORT, BSP_IS62WV51216_DATA13_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA14_PORT, BSP_IS62WV51216_DATA14_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_DATA15_PORT, BSP_IS62WV51216_DATA15_PIN, GPIO_FUNC_12);
    /* SMC_ADD[0:18]*/
    GPIO_SetFunc(BSP_IS62WV51216_ADD0_PORT, BSP_IS62WV51216_ADD0_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD1_PORT, BSP_IS62WV51216_ADD1_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD2_PORT, BSP_IS62WV51216_ADD2_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD3_PORT, BSP_IS62WV51216_ADD3_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD4_PORT, BSP_IS62WV51216_ADD4_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD5_PORT, BSP_IS62WV51216_ADD5_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD6_PORT, BSP_IS62WV51216_ADD6_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD7_PORT, BSP_IS62WV51216_ADD7_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD8_PORT, BSP_IS62WV51216_ADD8_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD9_PORT, BSP_IS62WV51216_ADD9_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD10_PORT, BSP_IS62WV51216_ADD10_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD11_PORT, BSP_IS62WV51216_ADD11_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD12_PORT, BSP_IS62WV51216_ADD12_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD13_PORT, BSP_IS62WV51216_ADD13_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD14_PORT, BSP_IS62WV51216_ADD14_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD15_PORT, BSP_IS62WV51216_ADD15_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD16_PORT, BSP_IS62WV51216_ADD16_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD17_PORT, BSP_IS62WV51216_ADD17_PIN, GPIO_FUNC_12);
    GPIO_SetFunc(BSP_IS62WV51216_ADD18_PORT, BSP_IS62WV51216_ADD18_PIN, GPIO_FUNC_12);
#endif /* BSP_IS62WV51216_ENABLE && BSP_EV_HC32F4A0_LQFP176 */
 * EOF (not truncated)
2.2、sram.c
在驱动程序的基础上,参考之前的学习修改了下内存的读写程序
#include "main.h"
#include "hc32_ll.h"
#include "ev_hc32f4a0_lqfp176_bsp.h"
#include "lcd.h"
#define SMC_SRAM3_ADDR    ((uint32_t)(0x70000000))
uint32_t testsram[250000] __attribute__((at(0X70000000)));
typedef __IO uint8_t  vu8;
void SMC_SRAM_WriteBuffer(uint8_t* pBuffer,uint32_t WriteAddr,uint32_t n)
	for(;n!=0;n--)
		*(vu8*)(SMC_SRAM3_ADDR+WriteAddr)=*pBuffer;
		WriteAddr++;
		pBuffer++;
void SMC_SRAM_ReadBuffer(uint8_t* pBuffer,uint32_t ReadAddr,uint32_t n)
	for(;n!=0;n--)
		*pBuffer++=*(vu8*)(SMC_SRAM3_ADDR+ReadAddr);
		ReadAddr++;
void init_sram(void)
	BSP_IS62WV51216_Init();
void smc_sram_test(uint16_t x,uint16_t y)
	uint32_t i=0;
	uint8_t temp=0;
	uint8_t sval=0;
  LCD_ShowString(x,y,400,y+24,24,"SRAM Test:     KB");
	for(i=0;i<1024*1024;i+=4096)
		SMC_SRAM_WriteBuffer(&temp,i,1);
		temp++;
  	SMC_SRAM_ReadBuffer(&temp,i,1);
		if(i==0)
			sval=temp;
 		else if(temp<=sval)
			break;
		LCD_ShowxNum(x+16*8,y,(u16)(temp-sval+1)*4,4,24,0);
void sram_test(void)
	uint32_t ts=0;
	for(ts=0;ts<250000;ts++)
		testsram[ts]=ts;
	smc_sram_test(0,0);
	DDL_DelayMS(500UL);
		LCD_ShowxNum(0,48,testsram[ts],6,24,0);//显示测试数据
	LCD_ShowString(0,72,400,24,24,"test finish!");
2.3、main.c
int32_t main(void)
	uint16_t u=0;
	uint16_t cord[6]={WHITE, BLUE, BRED, GBLUE, RED, YELLOW};
    /* Register write enable for some required peripherals. */
    LL_PERIPH_WE(LL_PERIPH_GPIO | LL_PERIPH_FCG | LL_PERIPH_PWC_CLK_RMU | LL_PERIPH_EFM | LL_PERIPH_SRAM);
	BSP_CLK_Init();
	/* EXCLK 60MHz */
    CLK_SetClockDiv(CLK_BUS_EXCLK, CLK_EXCLK_DIV4);
	DDL_PrintfInit(BSP_PRINTF_DEVICE, BSP_PRINTF_BAUDRATE, BSP_PRINTF_Preinit);
	BSP_IO_Init();
    BSP_LCD_IO_Init();
	BSP_GT9XX_Init();
	init_lcd();
	init_sram();
	LL_PERIPH_WP(LL_PERIPH_GPIO | LL_PERIPH_FCG | LL_PERIPH_PWC_CLK_RMU | LL_PERIPH_EFM | LL_PERIPH_SRAM);
	POINT_COLOR=RED;
	LCD_Clear(WHITE);
	sram_test();
    while(1);
三、程序运行
屏幕刷新读取外部SRAM存储器的数据,测试时间较长,截取一段视频。
20230220000217
回复评论 (2)
您的LCD屏是什么屏呀,我用原子屏,好象驱动不起来。
点赞  2023-2-20 12:59
引用: lugl4313820 发表于 2023-2-20 12:59 您的LCD屏是什么屏呀,我用原子屏,好象驱动不起来。
4.3寸的电容屏
点赞  2023-2-20 13:51
    写回复
