下面是启动的信息:
VIVI bootloader 0.1.4 (chris@yangchu.com) (gcc version 2.95.3 20010315 (release)
) #0.1.4 一 9月 17 10:54:21 CST 2007
MMU table base address = 0x33DFC000
S3C2410 flash: probing
genprobe_new_chip called with unsupported buswidth 4
CFI: Found no S3C2410 flash device at location zero
NAND device: Manufacture ID: 0xec, Chip ID: 0x76 (Samsung K9D1208V0M)
Found saved vivi parameters.
vga initialized ok!
Press Return to start the OS now, other key for vivi shell
Copy linux ce from 0x00200000 to 0x30200000, size = 0x02000000 ... done
MACH_TYPE = 193
go to 0x30200000
argument 0 = 0x00000000
argument 1?indows CE Kernel for ARM (Thumb Enabled) Built on Mar 13 2003 at 2
2:52:56
ProcessorType=0920 Revision=0
sp_abt=ffff5000 sp_irq=ffff2800 sp_undef=ffffc800 OEMAddressTable = 8c201280
Windows CE Firmware Init
INFO: Initializing system interrupts...
INFO: Initializing system clock(s)...
INFO: Initializing driver globals area...
SDMMC config current rGPGCON: ff95fd3a
SDMMC config set rGPGCON: ff95fdba
SDMMC config Init Done.
OEMInit Done...
Sp=ffffc7cc
OEMSetRealTime: Year: 2003, Month: 9, Day: 1, Hour: 12, Minute: 0, second: 0 rcn
r=1h
OEMSetRealTime(register): Year: 3, Month: 9, Day:
cond: 0 rcnr=1h.. doneentries:
FMD::FMD_Init
Prescaler:2 ... don
384 clock
NAND Written
USB:OhcdPdd_Initivi> part show start the OS
USB:*pIrq=11, *pioPortBase=0x140000
OHCD: MapIrq2SysIntr(11): 27
OHCD: Memory Object
--InitializeOHCI
+CS8900:DriverEntry
charlie::SDIO::SDHOST::XSCSDCardDllEntry::DLL_PROCESS_ATTACH
XSC_Init...dwcontext:0x602ecd4
XSC_Init...SDHCDAllocateContext:0x0
XSC_Init...SDGetRegPathFromInitContext:0x0
XSC_Init...SDHCDSetSlotCapabilities
XSC_Init...SDHCDSetVoltageWindowMask
XSC_Init...SDHCDSetDesiredSlotVoltage
XSC_Init...SDHCDSetMaxClockRate
XSC_Init...SDHCDSetPowerUpDelay
XSC_Init...SDHCDSetHCName
charlie::SDIO::XSCInitialize+
::: SYSINTR_SDMMC OEMInterruptDisable
::: SYSINTR_DMA0 OEMInterruptDisable
::: SYSINTR_SDMMC_CARD_DETECT OEMInterruptEnable
::: SYSINTR_SDMMC_SDIO_INTERRUPT OEMInterruptEnable
charlie::SDIO::XSCInitialize-
XSC_Init...SDHCDRegisterHostController:0x0
--S3C2410DISP::InitializeHardware
卡到哪里了?
--S3C2410DISP::InitializeHardware 这里?
重新编译内核吧,有时候找不出什么原因,重烧下就好了
引用: 引用 4 楼 guopeixin 的回复:
实在不行就kitl
看样子是4.2BSP的。无法KITL。
楼主只能编译一个debug版本的NK多看信息了。
不过为了长远开发,还是移植个KITL的5.0BSP这样以后就容易解决问题了。
很明显,系统是在加载驱动的过程中挂了的,那就先在驱动里面找原因,LCD驱动确定没有问题吗,看样子实在LCD这里停住的
