WinCE5 C# serialport控件的 接收数据 问题!
chenseawind   2008-5-13 16:49 楼主
问题说明:
    我在WinCE5环境里,使用vs2005(C#)编写串口Demo ,使用serialport控件,现在数据接收不行,查看资料后说需要适用委托,我按照例子更改后仍然不能接收,将接收这一段的代码贴出来,请大家指点!
    using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using System.Runtime.InteropServices;
using System.IO.Ports;
using System.Threading;
namespace DrawList
    public partial class TestCOM : Form
        //[DllImport("kernel32.dll",   EntryPoint="CreateFile")]
        delegate void HandleInterfaceUpdateDelegate(string text); //委托
        HandleInterfaceUpdateDelegate interfaceUpdateHandle;
        public TestCOM()
            InitializeComponent();
            Set_SerialPort(0);
        byte[] WriteBuf = new byte[255];
        byte[] ReadBuf = new byte[255];
        int TimeNum = 0;
        private void button1_Click(object sender, EventArgs e)
            try
                textBox1.Text = "";
                String[] Sendstr = textBox2.Text.Split(' ');
                int writelen = Sendstr.Length;
                for (int i = 0; i < Sendstr.Length; i++)
                    WriteBuf = Convert.ToByte(Sendstr, 16);
                Set_SerialPort(0);
                serialPort1.Open();
                serialPort1.Write(WriteBuf, 0,writelen);
                //serialPort1.WriteLine(textBox2.Text);
                serialPort1.Close();
            catch (Exception ex)
                textBox1.Text = ex.Message.ToString();
        void Set_SerialPort(int bl)
            if (bl == 0)
                //serialPort1.PortName = "COM" + textBox3.Text;
                if (comboBox3.Text != "")
                    serialPort1.PortName = comboBox3.Text;
                else
                    serialPort1.PortName = "COM3";
                if (comboBox1.Text == "")
                    serialPort1.BaudRate = 9600;
                else
                    serialPort1.BaudRate = Convert.ToInt32(comboBox1.Text);
                serialPort1.DataBits = Convert.ToInt32(numericUpDown1.Value);
                if (serialPort1.DataBits == 7)
                    serialPort1.StopBits = System.IO.Ports.StopBits.Two;
                if (serialPort1.DataBits == 8)
                    serialPort1.StopBits = System.IO.Ports.StopBits.One;
                if (serialPort1.DataBits == 9)
                    serialPort1.StopBits = System.IO.Ports.StopBits.None;
                if (comboBox2.Text == "Odd")
                    serialPort1.Parity = System.IO.Ports.Parity.Odd;
                else if (comboBox2.Text == "Even")
                    serialPort1.Parity = System.IO.Ports.Parity.Even;
                else if (comboBox2.Text == "None")
                    serialPort1.Parity = System.IO.Ports.Parity.None;
                else if (comboBox2.Text == "")
                interfaceUpdateHandle = new HandleInterfaceUpdateDelegate(AddText); //实例化委托对象
                serialPort1.DataReceived += new System.IO.Ports.SerialDataReceivedEventHandler(serialPort1_DataReceived);
                serialPort1.ReceivedBytesThreshold = 1;
                serialPort1.WriteBufferSize = 1000;
                serialPort1.WriteTimeout = 1000;
                serialPort1.ReadBufferSize = 1000;
                serialPort1.ReadTimeout = 1000;
            else if (bl == 1)
                serialPort1.DataBits = 8;
                serialPort1.StopBits = StopBits.One;
                serialPort1.Parity = Parity.None;
        #region Get COM number
        private void TestCOM_Load(object sender, EventArgs e)
            timer1.Interval = 1000;
            string[] ports = SerialPort.GetPortNames();
            for (int i=0; i < ports.Length; i++)
                comboBox3.Items.Add(ports.ToString());
        #endregion
        private void button2_Click(object sender, EventArgs e)//Close this Form
            timer1.Enabled = false;
            Close();
        private void serialPort1_DataReceived(object sender, SerialDataReceivedEventArgs e)
            //StringBuilder datatext;
            //datatext = new StringBuilder();
            String datatext = "";
            if (!serialPort1.IsOpen)
                serialPort1.Open();
            if (serialPort1.ReceivedBytesThreshold > 0)
                byte[] tmpbuf = new byte[serialPort1.BytesToRead];
                serialPort1.Read(tmpbuf, 0, serialPort1.BytesToRead);
                Thread.Sleep(50);
                for (int i = 0; i < serialPort1.BytesToRead; i++)
                    //datatext.Append(tmpbuf.ToString() + " " + i.ToString() + " ");
                    datatext = datatext + tmpbuf.ToString() + " " + i.ToString() + " ";
                this.textBox1.Invoke(interfaceUpdateHandle, datatext.ToString());
                //AddText(datatext);
        private void AddText(string text)
            textBox1.Text += text.ToString();
回复评论 (6)
没有人回答?看来悬了
点赞  2008-5-14 15:33
用这个
if (textBox1..InvokeRequired)
                   this.lblMsg.Invoke(new EventHandler(this.AddText), new object[] { datatext.ToString(), EventArgs.Empty });
private void AddText(object sender,eventargs e)
            textBox1.Text += sender.ToString();
good luck
点赞  2008-6-19 07:56
早已解决了,还是谢谢你的回复。
点赞  2008-6-24 13:57
小弟也在学做这方面的,能把代码发一份给我吗?liuxiaobing.aptech@163.com
先谢谢
点赞  2008-6-26 10:36
这位大哥,可以把这份串口的工程发给我吗,我是一个新手,看到您的程序对我很有用,可以把它发给我吗?谢谢您了!我的邮箱:liuzhongwei101@163.com
点赞  2008-7-8 10:34
这位大哥,可以把这份串口的工程发给我吗,我是一个新手,看到您的程序对我很有用,可以把它发给我吗?谢谢您了!我的邮箱:aojingbo888@163.com
点赞  2008-8-1 09:16
    写回复
