这一篇来进行定时器的实现与测试,因为后面很多功能都需要用到定时器。通过定时器中断中翻转IO使用示波器测量来确定时间准确度。
在前面https://bbs.eeworld.com.cn/thread-1247060-1-1.html的基础上进行。
定时器初始化
void timer_init(void)
cy_rslt_t result;
const cyhal_timer_cfg_t led_blink_timer_cfg =
.compare_value = 0, /* Timer compare value, not used */
.period = LED_BLINK_TIMER_PERIOD, /* Defines the timer period */
.direction = CYHAL_TIMER_DIR_UP, /* Timer counts up */
.is_compare = false, /* Don't use compare mode */
.is_continuous = true, /* Run timer indefinitely */
.value = 0 /* Initial value of counter */
/* Initialize the timer object. Does not use input pin ('pin' is NC) and
* does not use a pre-configured clock source ('clk' is NULL). */
result = cyhal_timer_init(&led_blink_timer, NC, NULL);
/* timer init failed. Stop program execution */
if (result != CY_RSLT_SUCCESS)
CY_ASSERT(0);
/* Configure timer period and operation mode such as count direction,
duration */
cyhal_timer_configure(&led_blink_timer, &led_blink_timer_cfg);
/* Set the frequency of timer's clock source */
cyhal_timer_set_frequency(&led_blink_timer, LED_BLINK_TIMER_CLOCK_HZ);
/* Assign the ISR to execute on timer interrupt */
cyhal_timer_register_callback(&led_blink_timer, isr_timer, NULL);
/* Set the event on which timer interrupt occurs and enable it */
cyhal_timer_enable_event(&led_blink_timer, CYHAL_TIMER_IRQ_TERMINAL_COUNT,
7, true);
/* Start the timer with the configured settings */
cyhal_timer_start(&led_blink_timer);
其中
#define LED_BLINK_TIMER_CLOCK_HZ (10000) 定义定时器时钟频率
#define LED_BLINK_TIMER_PERIOD (99) 定义周期,即多少个时钟产生中断
如果时钟频率为10000则一个时钟1/10000秒, 设置周期99即100个时钟100/10000秒,即1/100秒,10mS。
注册了回调函数isr_timer
中断中翻转IO
static void isr_timer(void *callback_arg, cyhal_timer_event_t event)
(void) callback_arg;
(void) event;
/* Set the interrupt flag and process it from the main while(1) loop */
timer_interrupt_flag = true;
cyhal_gpio_toggle(CYBSP_USER_LED);
IO的初始化如下
result = cyhal_gpio_init(CYBSP_USER_LED, CYHAL_GPIO_DIR_OUTPUT,
CYHAL_GPIO_DRIVE_STRONG, CYBSP_LED_STATE_OFF);
其中CYBSP_USER_LED为P11_1
注释掉以下代码
/* Check if timer elapsed (interrupt fired) and toggle the LED */
//if (timer_interrupt_flag)
/* Clear the flag */
// timer_interrupt_flag = false;
/* Invert the USER LED state */
// cyhal_gpio_toggle(CYBSP_USER_LED);
设置1mS中断
#define LED_BLINK_TIMER_PERIOD (9)
实测0.99mS
设置10mS中断
实测9.92
考虑到测量误差,上述结果可以看到时间是准确的。
使用官方的库函数,HAL接口进行外设操作比较简单,比如定时器几个接口就完成了操作,非常方便。
