[经验] 【STM32H5开发板】IIC读取湿温度
meiyao   2023-6-19 22:02 楼主
开发平台:KEIL
开发板:STM32H5
目地:本篇是利用STM32H5通过IIC读取AHT10的值,并显示在OLED上。
1.连接方式:
PC2--SCL
PC3--SDA
OLED看上一个连接。
image.png 2、IIC时序
3.核心代码:
#define AHT10_Delay_us(time)				HAL_Delay(time)	//delay_us(time)
#define AHT10_Delay_ms(time)				HAL_Delay(time)	//delay_ms(time)
#define AHT10_I2C_SCL_PIN      				GPIO_PIN_2
#define AHT10_I2C_SCL_GPIO_PORT   	  GPIOC
#define AHT10_I2C_SCL_GPIO_RCC      	__HAL_RCC_GPIOC_CLK_ENABLE()
#define AHT10_I2C_SDA_PIN      				GPIO_PIN_3
#define AHT10_I2C_SDA_GPIO_PORT   	  GPIOC
#define AHT10_I2C_SDA_GPIO_RCC      	__HAL_RCC_GPIOC_CLK_ENABLE()
#define AHT10_SCL_H         HAL_GPIO_WritePin(AHT10_I2C_SCL_GPIO_PORT, AHT10_I2C_SCL_PIN, GPIO_PIN_SET)
#define AHT10_SCL_L         HAL_GPIO_WritePin(AHT10_I2C_SCL_GPIO_PORT, AHT10_I2C_SCL_PIN, GPIO_PIN_RESET)
#define AHT10_SDA_H         HAL_GPIO_WritePin(AHT10_I2C_SDA_GPIO_PORT, AHT10_I2C_SDA_PIN, GPIO_PIN_SET)
#define AHT10_SDA_L         HAL_GPIO_WritePin(AHT10_I2C_SDA_GPIO_PORT, AHT10_I2C_SDA_PIN, GPIO_PIN_RESET)
#define AHT10_READ_SDA      HAL_GPIO_ReadPin(AHT10_I2C_SDA_GPIO_PORT,AHT10_I2C_SDA_PIN)
初始化:
	AHT10_I2C_SCL_GPIO_RCC;
	AHT10_I2C_SDA_GPIO_RCC;//??GPIO??
	GPIO_InitTypeDef  GPIO_InitStruct;
	GPIO_InitStruct.Mode  = GPIO_MODE_OUTPUT_PP;
  //GPIO_InitStruct.Pull  = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  GPIO_InitStruct.Pin = AHT10_I2C_SCL_PIN;
  HAL_GPIO_Init(AHT10_I2C_SCL_GPIO_PORT, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = AHT10_I2C_SDA_PIN;
  HAL_GPIO_Init(AHT10_I2C_SDA_GPIO_PORT, &GPIO_InitStruct);
	AHT10_SDA_H;
	AHT10_SCL_H;
	AHT10_IIC_Init();
	AHT10_IIC_Start();
	AHT10_IIC_Send_Byte(AHT10_ADDRESS);
	AHT10_IIC_Send_Byte(0xe1);
	AHT10_IIC_Send_Byte(0x08);
	AHT10_IIC_Send_Byte(0x00);
	AHT10_IIC_Stop();
	AHT10_Delay_ms(40);//??20ms??????
		ret=AHT10ReadData(&temperature,&humidity);
		if(ret==0)
			GUI_ShowString(0,0,(unsigned char*)"recv temp fail!",8,1);
		else
			float temp=temperature*0.1;
			float hum=humidity*0.1;
			//printf("temp:%2.1f,sd:%2.1f\r\n",temp,hum);
			char print_temp[64];
			char print_hum[64];
			sprintf(print_temp,"temp:%2.1f du",temp);
			sprintf(print_hum,"hum:%2.1f%%",hum);
			GUI_ShowString(0,0,(unsigned char*)print_temp,16,1);
			GUI_ShowString(0,2,(unsigned char*)print_hum,16,1);
			GUI_ShowString(0,4,(unsigned char*)"hello word!",16,1);
  4、视频
9fadaa328aa1ec2b6ef5a8aeb71868bd
回复评论 (4)
用STM32H5通过IIC读取AHT10的值,并显示在OLED上,这个好好跟着楼主学一下哈
点赞  2023-6-23 20:44
谢谢分享,期待后续!
默认摸鱼,再摸鱼。2022、9、28
点赞  2023-6-24 22:34
引用: 火辣西米秀 发表于 2023-6-23 20:44 用STM32H5通过IIC读取AHT10的值,并显示在OLED上,这个好好跟着楼主学一下哈
我也是摸了好几天才玩通的
点赞  2023-6-25 17:47
引用: freebsder 发表于 2023-6-24 22:34 谢谢分享,期待后续!
在进行中呢
点赞  2023-6-25 17:47
    写回复
