[原创] 【VisionFive 2:集成3D GPU RISC-V单板计算机】打造NES游戏机——USB手柄按键采集
qinyunti   2023-7-20 22:44 楼主
前言
本板运行debian系统,可以直接在板上构建开发环境,直接在板上进行开发。
从现在开始的几篇就以从源码开始,基于C实现,NES游戏机,体验板上直接C开发。
输入设备
插入USB手柄,可以看到多了/dev/input文件夹,多了event0设备
代码
vi key.c添加如下代码
/* 单独测试:#define KEY_TEST 1
 * 作为接口:#define KEY_TEST 0
 * 编译 aarch64-linux-gnu-gcc key.c -o key -lpthread
 * 运行 chmod +x key
 *      ./key /dev/input/event8
#include<stdint.h>
#include<stdio.h>
#include<stdlib.h>
#include<string.h>
#include<unistd.h>
#include<pthread.h>
#include <linux/input.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#define KEY_TEST 1
int s_keys_fd = -1;
uint32_t s_keys_state = 0;
void key_setstate(int code , int vaule, uint32_t* key)
    if(vaule == 0)
        switch(code)
            case 296:
                *key &= ~(1u<<3);
            break;
            case 297:
                *key &= ~(1u<<4);
            break;
            case 288:
                *key &= ~(1u<<5);
            break;
            case 289:
                *key &= ~(1u<<8);
            break;
            case 290:
                *key &= ~(1u<<6);
            break;
            case 291:
                *key &= ~(1u<<7);
            break;
            case 292:
                *key &= ~(1u<<1);
            break;
            case 294:
                *key &= ~(1u<<2);
            break;
            default:
            break;
    else
        switch(code)
            case 296:
                *key |= (1u<<3);
            break;
            case 297:
                *key |= (1u<<4);
            break;
            case 288:
                *key |= (1u<<5);
            break;
            case 289:
                *key |= (1u<<8);
            break;
            case 290:
                *key |= (1u<<6);
            break;
            case 291:
                *key |= (1u<<7);
            break;
            case 292:
                *key |= (1u<<1);
            break;
            case 294:
                *key |= (1u<<2);
            break;
            default:
            break;
 * SELECT 296   SELECT   3
 * START  297   START    4
 * UP     288   右上     5
 * RIGHT  289   右右     8
 * DOWN   290   右下     6
 * LEFT   291   右左     7
 * A      292   左前上    1
 * B      294   左前下    2
int key_getstate(int key)
    if(s_keys_state & (1u<<key))
        return 1;
    else
        return 0;
void* key_poll(void* arg)
    char ret[2];
    struct input_event t;
    while(1)
        if(read(s_keys_fd, &t, sizeof(t)) == sizeof(t))
            if(t.type==EV_KEY)
                if(t.value==0 || t.value==1)
                    key_setstate(t.code, t.value, &s_keys_state);
                    printf("key %d %s\n", t.code, (t.value) ? "Pressed" : "Released");
                    //if(t.code == KEY_ESC)
                    //  break;
            else
                ///printf("type %d code %d value %d\n", t.type, t.code, t.value);
        usleep(10000);
    return 0;
void key_init(void* arg)
    pthread_t id;
    s_keys_fd = open((char*)arg, O_RDONLY);
    if(s_keys_fd <= 0)
        printf("open %s device error!\n",(char*)arg);
        //return 0;
    /* 创建函数线程,并且指定函数线程要执行的函数 */
    int res = pthread_create(&id,NULL,key_poll,arg);
    if(res !=0 )
        printf("pthread_create err\r\n");
#if KEY_TEST
int main(int argc, char* argv[])
    key_init(argv[1]);
    while(1);
#endif
编译
gcc key.c -o key
测试
按不同的按键,打印如下
总结
可以看到直接在板上开发非常方便,免去了交叉编译的繁琐。
回复评论 (1)
不错的分享,学习一下楼住户的开发编写程序的思路。
点赞  2023-7-21 09:45
    写回复
