引用: 引用 2 楼 amorous 的回复:
pxa3xx是什么内核的,求教的说
Xscale架构,说到底就是基于ARM11的架构。
High-performance processor:
? XScale? microarchitecture with Intel? Wireless MMX? 2 media enhancement technology
? 7-8 stage pipeline
? 32 Kbytes instruction cache
? 32 Kbytes data cache
? 2 Kbytes “mini” data cache
? Extensive data buffering
Up to 768 Kbytes of internal SRAM for high speed code or data storage preserved during low-power states Rich serial peripheral set:
? AC ’97 audio port
? USB v. 2.0 client controller
? USB v. 1.1 client controller
? Up to 3 USB v. 1.1 host controller
? USB on-the-go controller
? Three high-speed UARTs with hardware flow control
? SIR and Consumer IR infrared communications ports
Hardware debug features — IEEE JTAG interface with boundary scan
Hardware performance-monitoring features with on-chip trace buffer
Real-time clock
Operating-system timers
LCD controller
Quick Capture Interface Controller
Low power:
? Dynamic voltage management support
? Less than 500 mW typical internal power dissipation
? Core supply voltage may be reduced to 0.95 V
? Five low-power modes
High-performance memory controller:
? Mobile DDR SDRAM interface
? EMPI and Data Flash interface
? Up to four static chip selects
? Companion-chip interface
Mini-LCD controller
Two Universal Subscriber Identity
Module (USIM) interface
Flexible clocking:
? CPU clock from 104 to 806 MHz
? Flexible memory clock ratios
? Frequency change capability
? Functional clock gating
Additional peripherals for system connectivity:
? SD/SDIO/MMC Controller (with SPI mode support)
? Four SSP controllers
? Two I2C controllers (one targeted for PMIC control)
? Four pulse-width modulators (PWMs)
? Keypad interface with both direct and matrix keys, rotary encoder support
? Most peripheral pins double as GPIOs
