在Corex-M3开发板上移植.Net Micro Framework系列文章
kk02157882   2010-2-22 15:13 楼主
1、【.Net Micro Framework PortingKit - 01】移植初步:环境搭建
http://blog.eeworld.net/yefanqiu/archive/2010/01/01/5117554.aspx
2、【.Net Micro Framework PortingKit - 02】STM3210E平台构建
http://blog.eeworld.net/yefanqiu/archive/2010/01/02/5119171.aspx
3、【.Net Micro Framework PortingKit - 03】调试初步:点亮LED灯
http://blog.eeworld.net/yefanqiu/archive/2010/01/02/5121851.aspx
4、【.Net Micro Framework PortingKit - 04】修改启动代码&重写向量表
http://blog.eeworld.net/yefanqiu/archive/2010/01/03/5125745.aspx
5、【.Net Micro Framework PortingKit - 05】SRAM初始化&设置NVIC中断表偏移
http://blog.eeworld.net/yefanqiu/archive/2010/01/03/5125769.aspx
6、【.Net Micro Framework PortingKit - 06】设置芯片时钟
http://blog.eeworld.net/yefanqiu/archive/2010/01/03/5125786.aspx
7、【.Net Micro Framework PortingKit - 07】NVIC中断处理
http://blog.eeworld.net/yefanqiu/archive/2010/01/18/5210149.aspx
8、【.Net Micro Framework PortingKit - 08】GPIO驱动
http://blog.eeworld.net/yefanqiu/archive/2010/01/20/5218846.aspx
9、【.Net Micro Framework PortingKit – 09】串口驱动
http://blog.eeworld.net/yefanqiu/archive/2010/01/24/5252018.aspx
10、【.Net Micro Framework PortingKit – 10】世界首款Cortex-M3内核MFV4诞生
http://blog.eeworld.net/yefanqiu/archive/2010/02/13/5308329.aspx
11、【.Net Micro Framework PortingKit – 11】NandFlash驱动开发
http://blog.eeworld.net/yefanqiu/archive/2010/02/15/5309306.aspx
12、【.Net Micro Framework PortingKit – 12】SysTick驱动开发
http://blog.eeworld.net/yefanqiu/archive/2010/02/17/5310050.aspx
13、【.Net Micro Framework PortingKit – 13】LCD驱动开发
http://blog.eeworld.net/yefanqiu/archive/2010/02/17/5310448.aspx
14、【.Net Micro Framework PortingKit – 14】TinyCLR编译与测试
http://blog.eeworld.net/yefanqiu/archive/2010/02/18/5310634.aspx
15、【.Net Micro Framework PortingKit – 15】移植总结(兼谈MF未来发展)
http://blog.eeworld.net/yefanqiu/archive/2010/02/19/5311773.aspx
回复评论 (3)
关注!!
希望楼主多出精品博文!推进.Net Micro Framework 的普及
点赞  2010-5-21 21:15
很好很强大,可惜我还在犹豫要不要玩玩M3
点赞  2010-5-22 06:39
lz很厉害!
点赞  2010-5-22 10:26
    写回复
