MSPM0L1306 LaunchPad开发套件主控为MSPM0L1306器件,提供高达64KB的嵌入式闪存程序存储器和高达4KB的SRAM。它们包含精度为±1%的高速片上振荡器,无需外部晶体。其他特性包括3通道DMA、16位和32位CRC加速器,以及各种高性能模拟外设。如何入手MSPM0L1306 LaunchPad开发套件呢?官方提供了参考短视频。
按照官方推荐的说明文档,①、首先需要准备好TI的官方IDE,即CCS。②、其次下载安装好基于MSPM0L1306的SDK。③、然后需要下载安装好图形化代码生成工具SysConfig。
登录TI官方论坛网站,下载好软件安装包,安装CCS编译工具,具体步骤如下:
void main_blinky(void)
/* Create the queue. */
xQueue = xQueueCreate(mainQUEUE_LENGTH, sizeof(uint32_t));
if (xQueue != NULL) {
* Start the two tasks as described in the comments at the top of this
* file.
xTaskCreate(
prvQueueReceiveTask, /* The function that implements the task. */
"Rx", /* The text name assigned to the task - for debug only as it is not used by the kernel. */
configMINIMAL_STACK_SIZE, /* The size of the stack to allocate to the task. */
(void *)
mainQUEUE_RECEIVE_PARAMETER, /* The parameter passed to the task - just to check the functionality. */
mainQUEUE_RECEIVE_TASK_PRIORITY, /* The priority assigned to the task. */
NULL); /* The task handle is not required, so NULL is passed. */
xTaskCreate(prvQueueSendTask, "TX", configMINIMAL_STACK_SIZE,
(void *) mainQUEUE_SEND_PARAMETER, mainQUEUE_SEND_TASK_PRIORITY,
NULL);
/* Start the tasks. */
vTaskStartScheduler();
* If all is well, the scheduler will now be running, and the following
* line will never be reached. If the following line does execute, then
* there was insufficient FreeRTOS heap memory available for the idle
* and/or timer tasks to be created. See the memory management section on
* the FreeRTOS web site for more details.
for (;;)
static void prvQueueSendTask(void *pvParameters)
TickType_t xNextWakeTime;
const unsigned long ulValueToSend = 100UL;
/* Check the task parameter is as expected. */
configASSERT(((unsigned long) pvParameters) == mainQUEUE_SEND_PARAMETER);
/* Initialize xNextWakeTime - this only needs to be done once. */
xNextWakeTime = xTaskGetTickCount();
for (;;) {
* Place this task in the blocked state until it is time to run again.
* The block time is specified in ticks, the constant used converts
* ticks to ms. While in the Blocked state this task will not consume
* any CPU time.
vTaskDelayUntil(&xNextWakeTime, mainQUEUE_SEND_FREQUENCY_MS);
* Send to the queue - causing the queue receive task to unblock and
* toggle the LED. 0 is used as the block time so the sending operation
* will not block - it shouldn't need to block as the queue should always
* be empty at this point in the code.
xQueueSend(xQueue, &ulValueToSend, 0U);
static void prvQueueReceiveTask(void *pvParameters)
unsigned long ulReceivedValue;
static const TickType_t xShortBlock = pdMS_TO_TICKS(50);
configASSERT(
((unsigned long) pvParameters) == mainQUEUE_RECEIVE_PARAMETER);
for (;;) {
* Wait until something arrives in the queue - this task will block
* indefinitely provided INCLUDE_vTaskSuspend is set to 1 in
* FreeRTOSConfig.h.
xQueueReceive(xQueue, &ulReceivedValue, portMAX_DELAY);
* To get here something must have been received from the queue, but
* is it the expected value? If it is, toggle the LED.
if (ulReceivedValue == 100UL) {
* Blip the LED for a short while so as not to use too much
* power.
DL_GPIO_togglePins(GPIO_LEDS_PORT, GPIO_LEDS_USER_LED_1_PIN);
vTaskDelay(xShortBlock);
ulReceivedValue = 0U;
