[经验分享] 【得捷Follow me第4期】W5500-EVB-Pico PIO UDP收发测试
wo4fisher   2024-3-3 17:53 楼主
1. 新建基础工程并添加Ethernet3库文件到工程目录
2. UDP协议收发代码编辑
Internet 协议集支持一个无连接的传输协议,该协议称为用户数据报协议(UDP,User Datagram Protocol)。UDP 为应用程序提供了一种无需建立连接就可以发送封装的 IP 数据包的方法。
即UDP基于无连接,通过IP地址和端口即可以收发数据。
上代码:
#include <Arduino.h>
#include <SPI.h>         // needed for Arduino versions later than 0018
#include <Ethernet3.h>
#include <EthernetUdp3.h>         // UDP library from: bjoern@cs.stanford.edu 12/30/2008
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 2, 177);
unsigned int localPort = 8888;      // local port to listen on
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
char  ReplyBuffer[] = "acknowledged";       // a string to send back
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
void setup() {
  Ethernet.setCsPin(17);
  Ethernet.setRstPin(20);
  // start the Ethernet and UDP:
  Ethernet.begin(mac, ip);
  Udp.begin(localPort);
  Serial.begin(115200);
void loop() {
  // if there's data available, read a packet
  int packetSize = Udp.parsePacket();
  if (packetSize)
    Serial.print("Received packet of size ");
    Serial.println(packetSize);
    Serial.print("From ");
    IPAddress remote = Udp.remoteIP();
    for (int i = 0; i < 4; i++)
      Serial.print(remote[i], DEC);
      if (i < 3)
        Serial.print(".");
    Serial.print(", port ");
    Serial.println(Udp.remotePort());
    // read the packet into packetBufffer
    Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
    Serial.println("Contents:");
    Serial.println(packetBuffer);
    // send a reply, to the IP address and port that sent us the packet we received
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
    Udp.write(ReplyBuffer);
    Udp.endPacket();
  delay(10);
主要步骤:
第一步:定义mac地址、本机ip地址、端口号和EthernetUDP 实例。
第二步:在setup中
初始化/定义cs引脚和rst引脚,
Ethernet.begin(mac, ip);初始化网络参数
Udp.begin(localPort);启动UDP服务器
第三步:在loop中
监听Udp.parsePacket(),如果有数据,进行解析
Udp.read()读取数据并通过串口输出后,再通过Udp.write()函数进行应答。
other:
UDP客户端实例就会以上例子反过来,因为UDP为无连接协议。因此
大概思路就是:
实例化UDP
封装发送数据
通过
    Udp.endPacket();
进行发送
然后解析、读取应答数据
Udp.parsePacket();
需要的话增加超时判断(可能没有应答)即可。
水不撩不知深浅 人不拼怎知输赢
回复评论 (2)
UDP 测试pc端口
udp.gif 点击上图查看Gif动图
水不撩不知深浅 人不拼怎知输赢
点赞  2024-3-5 12:50
udp rp2040串口打印信息:
udp.gif 点击上图查看Gif动图
水不撩不知深浅 人不拼怎知输赢
点赞  2024-3-5 12:52
    写回复
