关于windug虚拟机调试问题(我是新手,请各位高手帮忙,谢谢)
zldzjzldh   2009-8-23 16:09 楼主
Opened \\.\pipe\com_1
Waiting to reconnect...
Connected to Windows XP 2600 x86 compatible target, ptr64 FALSE
Kernel Debugger connection established.  (Initial Breakpoint requested)
Symbol search path is: F:\virtual\chapter01\NT_Driver\1\objchk\i386;srv*d:\mysymbols*http://msdl.microsoft.com/download/symbols
Executable search path is: F:\virtual\chapter01\NT_Driver\1
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for ntoskrnl.exe -
Windows XP Kernel Version 2600 (Service Pack 3) UP Free x86 compatible
Built by: 2600.xpsp.080413-2111
Kernel base = 0x804d8000 PsLoadedModuleList = 0x8055c1c0
System Uptime: not available
Break instruction exception - code 80000003 (first chance)
*   You are seeing this message because you pressed either                    *
*       CTRL+C (if you run kd.exe) or,                                        *
*       CTRL+BREAK (if you run WinDBG),                                       *
*   on your debugger machine's keyboard.                                      *
*                   THIS IS NOT A BUG OR A SYSTEM CRASH                       *
* If you did not intend to break into the debugger, press the "g" key, then   *
* press the "Enter" key now.  This message might immediately reappear.  If it *
* does, press "g" and "Enter" again.                                          *
nt!DbgBreakPointWithStatus+0x5:
804e4593 c20400          ret     4
请问这是什么原因
回复评论 (4)
THIS IS NOT A BUG OR A SYSTEM CRASH   !!!
说明已经连接上了。
但是上面有提示符号表定位有问题。
点赞  2009-8-23 20:25
我都几个月了还没连接上...
点赞  2009-8-24 09:23
引用: 引用 1 楼 pla_007 的回复:
THIS IS NOT A BUG OR A SYSTEM CRASH? !!!
说明已经连接上了。
但是上面有提示符号表定位有问题。
我的符号表定位确实有问题,请问能否指点一下,谢谢
点赞  2009-8-24 10:25
问题已得到解决,谢谢各位
点赞  2009-8-26 10:28
    写回复
