[MCU] 【兆易GD32H759I-EVAL】按键输入测试
TL-LED   2024-5-17 20:16 楼主
通过FreeRTOS移植 MultiButton来测试按键的输入。
一、下载源码
下载MultiButton源码地址:https://github.com/0x1abin/MultiButton
二、硬件电路部分
2.1、三个按键电路
2.2、复用端口选择
PF8端口复用触摸屏和按键输入,通过JP42来选择。
三、程序部分
3.1、配置按键输入
void init_key(void)
	rcu_periph_clock_enable(KEY1_GPIO_CLK);
	rcu_periph_clock_enable(KEY2_GPIO_CLK);
	rcu_periph_clock_enable(KEY3_GPIO_CLK);
	gpio_mode_set(KEY1_GPIO_PORT, GPIO_MODE_INPUT, GPIO_PUPD_NONE, KEY1_PIN);
	gpio_mode_set(KEY2_GPIO_PORT, GPIO_MODE_INPUT, GPIO_PUPD_NONE, KEY2_PIN);
	gpio_mode_set(KEY3_GPIO_PORT, GPIO_MODE_INPUT, GPIO_PUPD_NONE, KEY3_PIN);
	button_init(&btn1, read_button_GPIO, 0, btn1_id);
	button_init(&btn2, read_button_GPIO, 0, btn2_id);
	button_init(&btn3, read_button_GPIO, 0, btn3_id);
	button_start(&btn1);
	button_start(&btn2);
	button_start(&btn3);
3.2、按键端口定义
key.h
#ifndef __KEY_H
#define __KEY_H
#include "stdint.h"
enum Button_IDs {
	btn1_id,
	btn2_id,
	btn3_id,
#define 	KEY1_PIN                         GPIO_PIN_0
#define 	KEY1_GPIO_PORT                   GPIOA
#define 	KEY1_GPIO_CLK                    RCU_GPIOA
#define 	KEY2_PIN                         GPIO_PIN_13
#define 	KEY2_GPIO_PORT                   GPIOC
#define 	KEY2_GPIO_CLK                    RCU_GPIOC
#define 	KEY3_PIN                         GPIO_PIN_8
#define 	KEY3_GPIO_PORT                   GPIOF
#define 	KEY3_GPIO_CLK                    RCU_GPIOF
void init_key(void);
void key_hdl(void);
uint8_t read_button_GPIO(uint8_t button_id);
#endif
3.3、按键功能处理
三个按键分别处理的按下、松开和长按动作。
void key_hdl(void)
	//key1
	if(btn1_event_val != get_button_event(&btn1))
		btn1_event_val = get_button_event(&btn1);
		if(btn1_event_val == PRESS_DOWN) {
			printf("KEY1 PRESS_DOWN! \r\n");
		} else if(btn1_event_val == PRESS_UP) {
			//do something
		} else if(btn1_event_val == LONG_PRESS_HOLD) {
			//do something
	//key2
	else if(btn2_event_val != get_button_event(&btn2))
		btn2_event_val = get_button_event(&btn2);
		if(btn2_event_val == PRESS_DOWN) {
			//do something
		} else if(btn2_event_val == PRESS_UP) {
			printf("KEY2 PRESS_UP! \r\n");
			//do something
	//key3
	else if(btn3_event_val != get_button_event(&btn3))
		btn3_event_val = get_button_event(&btn3);
		if(btn3_event_val == PRESS_DOWN) {
			//do something
		} else if(btn3_event_val == PRESS_UP) {
			//do something
		} else if(btn3_event_val == LONG_PRESS_HOLD) {
			printf("KEY3 LONG_PRESS_HOLD! \r\n");
3.4、key.c
#include "main.h"
struct Button btn1;
struct Button btn2;
struct Button btn3;
static PressEvent btn1_event_val;
static PressEvent btn2_event_val;
static PressEvent btn3_event_val;
	// you can share the GPIO read function with multiple Buttons
	switch(button_id)
		case btn1_id:
			return gpio_input_bit_get(KEY1_GPIO_PORT, KEY1_PIN);
		case btn2_id:
			return gpio_input_bit_get(KEY2_GPIO_PORT, KEY2_PIN);
		case btn3_id:
			return gpio_input_bit_get(KEY3_GPIO_PORT, KEY3_PIN);
		default:
			return 0;
void init_key(void)
void key_hdl(void)
	//key1
			//do something
			//do something
	//key2
			//do something
			printf("KEY3 PRESS_UP! \r\n");
			//do something
	//key3
			//do something
			//do something
3.5、fun_task.c
创建按键任务,并处理按键功能。
#include "main.h"
#define START_TASK_PRO		1
#define START_STK_SIZE		128
TaskHandle_t StartTask_Handler;
#define TASK1_PRIO      4
#define TASK1_STK_SIZE  128
static TaskHandle_t            Task1Task_Handler = NULL;
#define TASK2_PRIO      3
#define TASK2_STK_SIZE  128
static TaskHandle_t            Task2Task_Handler = NULL;
#define KEY_PRIO      	6
#define KEY_STK_SIZE  	128
static TaskHandle_t            KeyTask_Handler = NULL;
void start_task(void *pvParameters);
void gui_task(void *pvParameters);
void task1(void *pvParameters);
void task2(void *pvParameters);
void task_key_hdl(void *pvParameters);
void task_create(void)
	//start_task
	xTaskCreate((TaskFunction_t )start_task,
							(const char*    )"start_task",
							(uint16_t       )START_STK_SIZE,
							(void*          )NULL,
							(UBaseType_t    )START_TASK_PRO,
							(TaskHandle_t*  )&StartTask_Handler);
	vTaskStartScheduler();
	taskENTER_CRITICAL();
	//task1
	xTaskCreate((TaskFunction_t )task1,
							(const char*    )"task1",
							(uint16_t       )TASK1_STK_SIZE,
							(void*          )NULL,
							(UBaseType_t    )TASK1_PRIO,
							(TaskHandle_t*  )&Task1Task_Handler);
	//task2
	xTaskCreate((TaskFunction_t )task2,
							(const char*    )"task2",
							(uint16_t       )TASK2_STK_SIZE,
							(void*          )NULL,
							(UBaseType_t    )TASK2_PRIO,
							(TaskHandle_t*  )&Task2Task_Handler);
	//KEY
	xTaskCreate((TaskFunction_t )task_key_hdl,
							(const char*    )"task_key_hdl",
							(uint16_t       )KEY_STK_SIZE,
							(void*          )NULL,
							(UBaseType_t    )KEY_PRIO,
							(TaskHandle_t*  )&KeyTask_Handler);
	taskEXIT_CRITICAL();
	vTaskDelete(StartTask_Handler);
//task1
    while (1)
        //printf("task1 run ...\r\n");
        vTaskDelay(200);
//task2
    while (1)
        //printf("task2 run ...\r\n");
        vTaskDelay(100);
//task_key_hdl
	uint8_t ct=0;
	init_key();
	while (1)
		key_hdl();
		ct++;
		if(ct>4)
			ct=0;
			button_ticks();
		vTaskDelay(1);
四、运行结果
操作按键,串口打印输出内容:
五、附件
源代码:
gd32h759_freertos_prj_20240517.rar (3.15 MB)
(下载次数: 1, 2024-5-17 20:14 上传)
回复评论 (2)
这个开源的按键驱动,非常优秀,感谢楼主的精彩分享!
点赞  2024-5-18 06:35
PF8端口复用触摸屏和按键输入,通过JP42来选择这款感觉开发板规划不太好
在爱好的道路上不断前进,在生活的迷雾中播撒光引
点赞  2024-5-18 11:15
    写回复
