关于eboot下flash的问题
1235421   2009-7-13 14:41 楼主
最近在修改eboot,(ep9315的cpu)现在发现有个擦flash的问题,运行到
Continue to Erase the rest of Flash.
*pFlash        = EA0003FF .
ERROR: Error while erasing flash
就发生错误
不是硬件的问题,因为用自带的就可以,不过没源码
这个是源码
BOOL  FinishEraseFlashJ3_2x16 (void)
    BOOL    bSuccess;
    // Check to see if the flash has been completely erased. If so just
    // return.
    if(gbFlashEraseComplete)
        return TRUE;
    // Wait for the Flash block command to succed.
    bSuccess = WaitForReady(gpulCurAddr, 10000, EXT_STATUS_WBUFFER_READY);
    if(bSuccess == FALSE)
        return FALSE;
    *gpulCurAddr  = FLASH_CLEAR_STATUS;
    // Erase the block before unlocking the next block.
    if(gbUnlocked)
        // Erase the flash block
        *gpulCurAddr = FLASH_BLOCK_ERASE;
        *gpulCurAddr = FLASH_BLOCK_ERASE_RESUME;
        // Read erase status.
        *gpulCurAddr = FLASH_READ_STATUS;
            return FALSE;
        gbUnlocked      = FALSE;
        // Increment to the next block.
        gpulCurAddr += FLASH_BLOCK_SIZE>>2;
    // Erase the Flash
    while((DWORD)gpulCurAddr < (gdwStartAddr + gdwLength))
        // Clear the lock bits if the flash block was locked.
        *gpulCurAddr = FLASH_LOCK_BIT;
        *gpulCurAddr = FLASH_LOCK_CLEAR;
        if(!bSuccess)
            break;
        if(!bSuccess)
            break;
        // Occasionally write out a dot so they don't think
        // the system is dead.
        EdbgOutputDebugString(".");
    return bSuccess;
主要是WaitForReady()函数卡住
static int  WaitForReady
    volatile ULONG *pFlash,
    ULONG ulTimeoutInMsec,
    ULONG ulBitField
    ULONG       ulStart;
    ULONG       ulCurrent;
    BOOL        bSuccess = FALSE;
    ulStart = GetSystemTimeInMsec();
    do
        // See if there are errors.
        if((*pFlash & ulBitField)== ulBitField)
            bSuccess = TRUE;
            break;
        // Get the current time.
        ulCurrent = GetSystemTimeInMsec();
    } while(ulCurrent
    if(!bSuccess)
        EdbgOutputDebugString("*pFlash        = %x .\n",(ULONG)*pFlash);
    return bSuccess;
我也问了下别人,说是可能ep9315对flash的读写时间有问题,不知道怎么解决..
回复评论 (2)
一些相关参数
define     FLASH_BLOCK_SIZE            0x40000
#define     FLASH_BLOCK_MASK            ~(FLASH_BLOCK_SIZE - 1)
#define     FLASH_BUFFER_SIZE           64
#define     FLASH_READ_MODE             0x00FF00FF
#define     FLASH_BLOCK_ERASE           0x00200020
#define     FLASH_CLEAR_STATUS          0x00500050
#define     FLASH_BLOCK_ERASE_RESUME    0x00d000d0
#define     FLASH_BLOCK_PROGRAM_RESUME  0x00d000d0
#define     FLASH_WRITE_TO_BUFFER       0x00E800E8
#define     FLASH_READ_STATUS           0x00700070
#define     FLASH_LOCK_BIT              0x00600060
#define     FLASH_LOCK_SET              0x00010001
#define     FLASH_LOCK_CLEAR            0x00d000d0
#define     STATUS_WRITE_READY          0x00800080
#define     EXT_STATUS_WBUFFER_READY    0x00800080
static DWORD    gdwStartAddr            = 0;
static DWORD    gdwLength               = 0;
static volatile PULONG  gpulCurAddr     = 0;
static BOOL     gbFlashEraseComplete    = FALSE;
static BOOL     gbUnlocked              = TRUE;
点赞  2009-7-13 14:43
顶一下,比较急啊
点赞  2009-7-13 15:33
    写回复
