GPIO驱动程序
linwei1234   2010-4-14 21:17 楼主
// GPIOBeep.cpp : Defines the class behaviors for the application.
#include "stdafx.h"
#include "GPIOBeep.h"
#include "GPIOBeepDlg.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// CGPIOBeepApp
BEGIN_MESSAGE_MAP(CGPIOBeepApp, CWinApp)
        //{{AFX_MSG_MAP(CGPIOBeepApp)
                // NOTE - the ClassWizard will add and remove mapping macros here.
                //    DO NOT EDIT what you see in these blocks of generated code!
        //}}AFX_MSG
END_MESSAGE_MAP()
// CGPIOBeepApp construction
CGPIOBeepApp::CGPIOBeepApp()
        : CWinApp()
        // TODO: add construction code here,
        // Place all significant initialization in InitInstance
// The one and only CGPIOBeepApp object
CGPIOBeepApp theApp;
// CGPIOBeepApp initialization
BOOL CGPIOBeepApp::InitInstance()
        // Standard initialization
        // If you are not using these features and wish to reduce the size
        //  of your final executable, you should remove from the following
        //  the specific initialization routines you do not need.
        CGPIOBeepDlg dlg;
        m_pMainWnd = &dlg;
        int nResponse = dlg.DoModal();
        if (nResponse == IDOK)
                // TODO: Place code here to handle when the dialog is
                //  dismissed with OK
        else if (nResponse == IDCANCEL)
                //  dismissed with Cancel
        // Since the dialog has been closed, return FALSE so that we exit the
        //  application, rather than start the application's message pump.
        return FALSE;
这是周立功的GPIO的输出控制实验
BOOL CGPIOBeepApp::InitInstance()类似这种语句看不懂
各位大侠有没有哪里有注解
可以看的懂些
回复评论 (1)
BOOL ::InitInstance()
类里面的函数定义,查查CGPIOBeepApp这个类,C++的东西
点赞  2010-4-15 10:17
    写回复
