2440ce5的bsp移植到ce6的SMFLASH问题
zzxxzz   2009-6-24 11:31 楼主
ce5下bsp是好的,移植到ce6下,eboot已经搞好,烧录nk后,打印如下消息:
Error Reporting Memory Reserved, dump size = 00020000
Setting up softlog at 0x83edc000 for 0x800 entries
Booting Windows CE version 6.00 for (ARM)
&pTOC = 81a8ac1c, pTOC = 81a73cf8, pTOC->ulRamFree = 81a8f000, MemForPT = 00001000
Old or invalid version stamp in kernel structures - starting clean!
Configuring: Primary pages: 9286, Secondary pages: 0, Filesystem pages = 1160
Booting kernel with clean memory configuration:
Memory Sections:
[0] : start: 81a91000, extension: 00005000, length: 02446000
NKStartup done, starting up kernel.
Windows CE KernelInit
Reserve VM for kernel XIP DLls, first = c0010000, last = c1290000
g_pprcNK == 0x81a88aa0
Updated eptr->e32_vsize to = 00017000
Initializing Memory Mapped File Support
Scheduling the first thread.
Detecting VFP... VFP Not Found!
LoaderInit: Initialing loader
Updated eptr->e32_vsize to = 000a2000
PGPOOL: Reserved 768 pages for Loader pool
PGPOOL: Reserved 256 pages for File pool
OSAXST0: Platform Name = PLATFORM_TYPE
OSAXST1: >>> Loading Module 'kd.dll' (0x83EB7744) at address 0xC0010000-0xC0045000 in Process 'NK.EXE' (0x81A88AA0)
KD: Starting kernel debugger software probe (KdStub) - KD API version 22
OSAXST1: >>> Loading Module 'NK.EXE' (0x81A88AA0) at address 0x80300000-0x80317000 in Process 'NK.EXE' (0x81A88AA0)
Message Queue support initialized, g_hMsgQHeap = d0080010
OSAXST1: >>> Loading Module 'filesys.dll' (0x83EB7E88) at address 0xC01D0000-0xC0267000 in Process 'NK.EXE' (0x81A88AA0)
OSAXST1: >>> Loading Module 'k.fpcrt.dll' (0x83E92574) at address 0xC01B0000-0xC01C8000 in Process 'NK.EXE' (0x81A88AA0)
OSAXST1: >>> Loading Module 'fsdmgr.dll' (0x83E926BC) at address 0xC05D0000-0xC0616000 in Process 'NK.EXE' (0x81A88AA0)
FSDMGR!DllMain: DLL_PROCESS_ATTACH
CertMod.dll not found, using old OEM Trust Model
FileSystem Starting - starting with clean file system
FSDMGR!STOREMGR_Initialize
FSDMGR!InitializeStoreAPI
FSDMGR!MountTable_t::RegisterVolumeName: Registered "StoreMgr" at index 2FSDMGR!MountTable_t::RegisterVolume: Registered volume at index 2 (Name="StoreMgr", MountFlags=0x1)FSDMGR!InitializeROMFileSystem: File System=ROM
OSAXST1: >>> Loading Module 'romfsd.dll' (0x83E73930) at address 0xC0270000-0xC0277000 in Process 'NK.EXE' (0x81A88AA0)
FSDMGR!MountTable_t::RegisterVolumeName: Registered "ROM" at index 3FSDMGR!MountTable_t::RegisterVolume: Registered volume at index 3 (Name="ROM", MountFlags=0x71)Succeeded on CheckFile
RestoreFile(0x00840003) called fDelete = TRUE
FSDMGR!STOREMGR_StartBootPhase BootPhase=0 (PrevBootPhase=-1)
FSDMGR: File security disabled.
FSDMGR!AutoLoadFileSystems: CurrentBootPhase=0, LoadFlags=1
FSDMGR!AutoLoadFileSystem: CurrentBootPhase=0, RootKey=System\StorageManager\AutoLoad, FileSystem_t=ObjectStore
FILESYFSDMGR!PNPThread: Using PNPUnloadDelay of 4096
FSDMGR!PNPThread: PNPThread starting!
S: RAM File System FSD_MountDisk registering folder "Object Store"
FSDMGR!MountTable_t::RegisterVolumeName: Registered "Object Store" at index 4FSDMGR!MountTable_t::RegisterVolume: Registered volume at index 4 (Name="", MountFlags=0x46)FSDMGR!AutoLoadFileSystem: CurrentBootPhase=0, RootKey=System\StorageManager\AutoLoad, FileSystem_t=SMFLASH
FSDMGR!AutoLoadBlockDevice: Auto-loading block driver from "Drivers\BuiltIn\SMFLASH"FSDMGR!MountStore: Attaching new storage device "SMFLASH"OSAXST1: >>> Loading Module 'smflash.dll' (0x83E6CEC8) at address 0xC10D0000-0xC10F1000 in Process 'NK.EXE' (0x81A88AA0)
ERROR!!! Calling SetKMode
到这里,一直打印 ERROR!!! Calling SetKMode ,做过的弟兄帮忙看看
回复评论 (8)
SetKMode 在wince6.0已经不支持了。所以找个别的东西代替了。
点赞  2009-6-24 11:42
用release 模式编译,这个错误莫名其妙又好了。晕。
现在中文件界面都是下划线显示,把能加的中文组件都加了一遍(GB18030 Data Converter、SimSun & NSimSun什么的),现在怀疑是不是CE6的环境问题?
点赞  2009-6-24 22:36
发现这人的问题一模一样:
(中文字符都被显示成下划线)
http://www.yfeshop.cn/html/NETboke/200811/CE6-0zhichizhongwen_2569.html
点赞  2009-6-24 22:38
又发现一个一样的:
(安装完windows ce 6.0 R2后无法显示中文)
http://social.microsoft.com/Forums/zh-CN/windowsembeddedcezhchs/thread/70af4e7a-0e51-45bb-96a4-b77d8ee8e964/
点赞  2009-6-24 22:44
晕,怎么我的都是好好的,搞了一周 2440 全部跑起来了。
点赞  2009-6-25 00:00
R2居然要求加.NET,中文显示才正常,不知道微软为什么这么设计?难道以后必须把NET的运行包搞到CE的bin里?
另,gooogleman 你的hive 跑起来了吗(CE5的bsp直接过去就能用?支持xip吗)?
点赞  2009-6-25 00:59
引用: 引用 6 楼 njtu_shiyl 的回复:
HIVE 看帮助就可以了。
XIP没有搞。
点赞  2009-6-25 08:39
都跑起来了。
ce6的性能好像比ce5差多了?打开控制面板里的“音量控制”,GUI都有滞后?好像和CE6的官方说法有出入?
点赞  2009-6-27 11:24
    写回复
