任务总览
1.获取SHT40的温湿度数据
先使用官方例程测试一下SHT40传感器
This is an example for the SHT4x Humidity & Temp Sensor
Designed specifically to work with the SHT4x sensor from Adafruit
----> https://www.adafruit.com/products/4885
These sensors use I2C to communicate, 2 pins are required to
interface
#include <Wire.h>
#include "Adafruit_SHT4x.h"
#define SDA_PIN 27
#define SCL_PIN 26
Adafruit_SHT4x sht4 = Adafruit_SHT4x();
void setup() {
Serial.begin(115200);
while (!Serial)
delay(10); // will pause Zero, Leonardo, etc until serial console opens
TwoWire i2cWire = TwoWire(SCL_PIN, SDA_PIN);
Serial.println("Adafruit SHT4x test");
if (! sht4.begin(&i2cWire)) {
Serial.println("Couldn't find SHT4x");
while (1) delay(1);
Serial.println("Found SHT4x sensor");
Serial.print("Serial number 0x");
Serial.println(sht4.readSerial(), HEX);
// You can have 3 different precisions, higher precision takes longer
sht4.setPrecision(SHT4X_HIGH_PRECISION);
switch (sht4.getPrecision()) {
case SHT4X_HIGH_PRECISION:
Serial.println("High precision");
break;
case SHT4X_MED_PRECISION:
Serial.println("Med precision");
break;
case SHT4X_LOW_PRECISION:
Serial.println("Low precision");
break;
// You can have 6 different heater settings
// higher heat and longer times uses more power
// and reads will take longer too!
sht4.setHeater(SHT4X_NO_HEATER);
switch (sht4.getHeater()) {
case SHT4X_NO_HEATER:
Serial.println("No heater");
break;
case SHT4X_HIGH_HEATER_1S:
Serial.println("High heat for 1 second");
break;
case SHT4X_HIGH_HEATER_100MS:
Serial.println("High heat for 0.1 second");
break;
case SHT4X_MED_HEATER_1S:
Serial.println("Medium heat for 1 second");
break;
case SHT4X_MED_HEATER_100MS:
Serial.println("Medium heat for 0.1 second");
break;
case SHT4X_LOW_HEATER_1S:
Serial.println("Low heat for 1 second");
break;
case SHT4X_LOW_HEATER_100MS:
Serial.println("Low heat for 0.1 second");
break;
void loop() {
sensors_event_t humidity, temp;
uint32_t timestamp = millis();
sht4.getEvent(&humidity, &temp);// populate temp and humidity objects with fresh data
timestamp = millis() - timestamp;
Serial.print("Temperature: "); Serial.print(temp.temperature); Serial.println(" degrees C");
Serial.print("Humidity: "); Serial.print(humidity.relative_humidity); Serial.println("% rH");
Serial.print("Read duration (ms): ");
Serial.println(timestamp);
delay(1000);
串口打印出来的数据:
Adafruit SHT4x test
Found SHT4x sensor
Serial number 0x10C60BD0
High precision
No heater
Temperature: 30.67 degrees C
Humidity: 70.80% rH
Read duration (ms): 11
2. 搭建HomeAssistant平台
推荐使用SDFormatter(内存卡修复工具),经常在Linux和Windwos下使用的SD卡通常会有着不同的分区,在不能操作系统下识别出来的可能都不太一样,因此为了保险起见可以先格式化一下,若没有问题的可以跳过这一步
推荐使用balenaEtcher,这是一个开源的、跨平台的工具,用于将操作系统镜像文件(如 ISO 和 IMG 文件)烧录到 SD 卡和 USB 驱动器中,支持的格式非常的多
选择镜像文件。我是用的是树莓派4,因此选择的是haos_rpi4-64-6.4.img.xz,大家根据自己的设备在附件中选择对应的型号即可。
选择SD卡、U盘等设备
Flash!等待烧写完成
插入烧写好的镜像SD卡到树莓派
接网线到路由器
将电脑通过WiFi或者网线接入到上面树莓派接入的路由器
接HDMI到显示屏等能够显示的设备(有条件的最后接上,没有问题也不是很大)
上电!
若插上HDMI,稍稍稍微的登上那么一段时间,等待系统启动完成就可以看到这个界面了,若没有显示屏,不要捉急,在网站上输入http://homeassistant.local:8123/
等待网页显示。若成功启动了,恭喜你完成了第一步!!!
能成功进入网站上,会显示这个界面准备,我一开始信了这个鬼(这最多可能需要20分钟),结果等了一个多小时都没有进去……
第二天起来看到已经到了Home Assistant 的欢迎界面,按照步骤一步步下去就可以了
点击FINISH之后,恭喜你现在已经启动并运行了 Home Assistant!!!
设置
加载项
加载项商店
搜索ssh
设置
加载项
加载项商店
搜索Samba
安装
配置:用户名和密码
使用:
Win+R
输出\ip,例如\\192.168.1.43
,这个ip就是上面ssh中查到的ip地址
就可以跟使用文件夹一样,对树莓派里面的文件进行操作了
设置
加载项
加载项商店
搜索MQTT
设置-》设备于服务-》打开MQTT-》配置,就可以了以下界面,进行配置ip,用户名、密码等信息,记住这些信息哟
添加设备,使用的软件是MQTTx,发送下面数据,湿度同理
"name": "SHT40 Humidity",
"state_topic": "homeassistant/sensor/sht40_humidity/state",
"unit_of_measurement": "%rH",
"device_class": "temperature",
"json_attributes_topic": "homeassistant/sensor/sht40_humidity/attributes",
"unique_id": "sht40_humidity",
"device": {
"identifiers": ["sht40"],
"name": "SHT40 Sensor",
"model": "SHT40",
"manufacturer": "SHT"
就可以看到添加的设备了
#define SDA_PIN 27
#define SCL_PIN 26
#include <WiFi.h>
#include <ArduinoMqttClient.h>
char ssid[] = "wifi"; // your network SSID (name)
char pass[] = "passpword"; // your network password
char mqtt_user[] = "master";
char mqtt_pass[] = "1";
WiFiClient wifiClient;
MqttClient mqttClient(wifiClient);
const char broker[] = "192.168.1.22"; // MQTT broker address
int port = 1883;
const char subscribe_topic[] = "/status";
const char publish_topic_sht40_temperature[] = "homeassistant/sensor/sht40_temperature/state";
const char publish_topic_sht40_humidity[] = "homeassistant/sensor/sht40_humidity/state";
void setup() {
//打开串口
while (!Serial)
//连接WIFI
// Connect to WiFi
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
while (WiFi.begin(ssid, pass) != WL_CONNECTED) {
// failed, retry
Serial.print(".");
delay(5000);
Serial.println("\nYou're connected to the network");
Serial.print("IP Address: ");
Serial.println(WiFi.localIP());
Serial.print("Gateway IP: ");
Serial.println(WiFi.gatewayIP());
Serial.print("Subnet Mask: ");
Serial.println(WiFi.subnetMask());
Serial.print("MAC Address: ");
//Serial.println(WiFi.macAddress());
Serial.println();
//连接MQTT
// Set MQTT username and password
mqttClient.setUsernamePassword(mqtt_user, mqtt_pass);
Serial.print("Attempting to connect to the MQTT broker.");
if (!mqttClient.connect(broker, port)) {
Serial.print("MQTT connection failed! Error code = ");
Serial.println(mqttClient.connectError());
while (1);
Serial.println("You're connected to the MQTT broker!");
Serial.print("Subscribing to topic: ");
Serial.println(subscribe_topic);
// Subscribe to a topic
mqttClient.subscribe(subscribe_topic);
Serial.print("Waiting for messages on topic: ");
//连接SHT40
Serial.println("SHT40 测试");
Serial.println("无法访问SHT40");
while (1) delay(1);
Serial.println("开始读取SHT40序列号");
Serial.print("SHT40的序列号是:");
delay(1000);
void loop() {
// put your main code here, to run repeatedly:
Serial.println("1");
Serial.println("2");
delay(1000);
publishMessage_sht40_temperature(String(temp.temperature));
publishMessage_sht40_humidity(String(humidity.relative_humidity));
// Function to publish a message to the MQTT broker
//发布温度信息
void publishMessage_sht40_temperature(const String &message) {
mqttClient.beginMessage(publish_topic_sht40_temperature);
mqttClient.print(message);
mqttClient.endMessage();
//发布湿度信息
void publishMessage_sht40_humidity(const String &message) {
mqttClient.beginMessage(publish_topic_sht40_humidity);
