6410无法进中断!
精灵小妹   2010-5-7 16:04 楼主
  我用6410裸奔,首先在NAND的0地址烧写了我自己的BOOT(一下简称“BOOT部分程序”),然后在把用户裸奔程序用仿真器烧写到NAND的第2个BLOCK,上电启动通过BOOT把用户程序下载进DDR里面运行,但是现在进步了中断,具体代码如下:
   这是START.S的代码
        GET                option.inc
                                GET                sfr6410.inc
                                MACRO
$HandlerLabel         HANDLER                $HandleLabel
$HandlerLabel
                                sub                sp,sp,#4                ;decrement sp(to store jump address)
                                stmfd        sp!,{r0}                ;PUSH the work register to stack(lr doesnt push because it return to original address)
                                ldr     r0,=$HandleLabel        ;load the address of HandleXXX to r0
                                ldr     r0,[r0]                 ;load the contents(service routine start address) of HandleXXX
                                str     r0,[sp,#4]              ;store the contents(ISR) of HandleXXX to stack
                                ldmfd   sp!,{r0,pc}             ;POP the work register and pc(jump to ISR)
                                MEND
                                IMPORT        InitDmc                                ;DMC initialize
;                                                ENTRY
                                AREA    Init,CODE,READONLY
                                ENTRY
                                b                ResetHandler
                                b                HandlerUndef
                                b                HandlerSWI
                                b                HandlerPabort
                                b                HandlerDabort
                                b                .
                           b                HandlerIRQ
                                b                HandlerFIQ
HandlerUndef        HANDLER HandleUndef
HandlerSWI                HANDLER HandleSWI
HandlerPabort        HANDLER HandlePabort
HandlerDabort        HANDLER HandleDabort
HandlerIRQ                HANDLER        HandleIRQ
HandlerFIQ                HANDLER        HandleFIQ
ResetHandler
        [        (SILICON)
                                bl                InitSyscon
        ;                        bl                InitSmc
                                bl                InitDmc
                        ;; memport1 drive strength change 3mA->7mA
                        ldr r3, =0x7F0081D4
                        ldr r4, =0x55555555
                        str r4, [r3]
                                IMPORT  __main
                                   bl                __main
                                   b                .
;------------[Syscon Initialize Routine]----------------
InitSyscon                PROC
                                ; Peri Port Setup
                                ; Disable WatchDog
                                ; Operating Mode Change
                                ; Set PLL LockTime
                                ; Set PMS valuse and enable PLL
                                ; Set Clock Divider
                                ; Select Clock Source for SYSCLK
                                ; Expand DRAM Port
                                ldr                r0,        =0x70000013                        ; Peri. Port Setup
                                mcr                p15,0,r0,c15,c2,4                ; 256M(0x7000_0000 ~ 0x7fff_ffff
                                ldr                r0,        =rWTCON                                ; Disable WatchDog
                                mov                r1,        #0
                                str                r1,[r0]
        [        (SYNCMODE)        ; Operating Mode Change
                                ldr                r0, =rOTHERS
                                ldr                r1, [r0]
                                mov                r2, #0x40                                ; rOTHERS[6] = "1"
                                orr                r1,        r1, r2
                                str                r1,        [r0]                                ; SYNCMUXSEL
                                ;DELAY
                                NOP
                                NOP
                                NOP
                                NOP
                                NOP
                                ldr                r2, =((1<<7))                        ; SYNCMODE,
                                orr                r1,        r1, r2
                                str                r1, [r0]                                ; Assert SYNCACK, VICSYNCEN
Check_SYNCACK
                                ldr                r1, [r0]
                                ldr                r2, =(0xF<<8)
                                and                r1, r1, r2                                ; rOTHERS[11:8]
                                cmp                r1, #0xF00
                                bne                Check_SYNCACK
                                mov                r1, #0xff00
                                orr                r1,r1,#0xff                                ; Lock Time Value, Fin=12MHz - 0x4B1(min)
                                ldr                r0, =rAPLL_LOCK                        ; APLL Lock Time
                                str                r1, [r0]
                                str                r1, [r0,#0x4]                        ; MPLL Lock Time
                                ;;Set Clock Divider0
                                ldr                r1,        [r0,#0x20]                        ; Load Clock Divider Value
                                bic   r1, #0x30000
                                bic                r1, #0xff00
                                bic                r1, #0xff
                                ldr                r2, =((PCLK_DIV<<12)|(HCLKx2_DIV<<9)|(HCLK_DIV<<8)|(MPLL_DIV<<4)|(APLL_DIV<<0))
                                orr                r1,r1,r2
                                str                r1,        [r0,#0x20]                        ; CLK_DIV0 Register
                                ;; APLL M,P,S Value & Enable
                                ldr                r1, =((1<<31)|(APLL_MVAL<<16)|(APLL_PVAL<<8)|(APLL_SVAL))
                                str                r1, [r0,#0xC]                        ; APLL_CON Register
                                ;; MPLL M,P,S Value & Enable
                                ldr                r1, =((1<<31)|(MPLL_MVAL<<16)|(MPLL_PVAL<<8)|(MPLL_SVAL))
                                str                r1, [r0,#0x10]                        ; MPLL_CON Register
                                ;;Select PLL clock out
                                ldr                r1, [r0, #0x1c]
                                orr                r1,r1,#0x3
                                str                r1, [r0,#0x1c]
                                ;;Expand Memory 1 Port to X32
                                ldr                r1,        [r0, #0x120]
                                bic                r1, #0x80                                ; ADDR_EXPAND to "0"
                                str                r1,        [r0, #0x120]                ; MEM_SYS_CFG Register
                                mov                pc,lr
                                ENDP
;---------------[SMC Initialize Routine]----------------
InitSmc                        PROC
                                ; Initialize SMC
                        mov                pc,lr
                           ; b  main
                                ENDP
                                LTORG
                                   ALIGN
                                   AREA IntVector, DATA, READWRITE
                                ^   Exception_Vector
HandleReset         #   4
HandleUndef         #   4
HandleSWI           #   4
HandlePabort    #   4
HandleDabort    #   4
HandleReserved  #   4
HandleIRQ           #   4
HandleFIQ           #   4
                        END
对以上代码我是那么理解的,我的程序正在DDR里面运行,当中断来的时候程序会跳转到BOOT部分程序的0X18地址,也就是执行b                HandlerIRQ这语句,而HandlerIRQ是一个汇编的宏定义:
MACRO
$HandlerLabel
                                MEND
仔细看就是跳转到了$HandleLabel地址,我在去找$HandleLabel地址到底是多少:
^   Exception_Vector
HandleReset         #   4
HandleUndef         #   4
HandleSWI           #   4
HandlePabort    #   4
HandleDabort    #   4
HandleReserved  #   4
HandleIRQ           #   4
HandleFIQ           #   4
而#define         _Exception_Vector                (_DRAM_BaseAddress+        0x07ffff00)
也就是中断一来就跳转到了_Exception_Vector+0x18地址。
然后我在加入以下几行代码:
#define pExceptionRESET                        (*(u32 *)(_Exception_Vector + 0x0))
#define pExceptionUNDEF                        (*(u32 *)(_Exception_Vector + 0x4))
#define pExceptionSWI                        (*(u32 *)(_Exception_Vector + 0x8))
#define pExceptionPABORT                (*(u32 *)(_Exception_Vector + 0xc))
#define pExceptionDABORT                (*(u32 *)(_Exception_Vector + 0x10))
#define pExceptionRESERVED                (*(u32 *)(_Exception_Vector + 0x14))
#define pExceptionIRQ                        (*(u32 *)(_Exception_Vector + 0x18))
#define pExceptionFIQ                        (*(u32 *)(_Exception_Vector + 0x1c))
void  eExceptionIRQ(void)
        DisplayLED(0x00);
        while(1);
void SYSTEM_InitException( void)
        pExceptionUNDEF                =        (u32)ExceptionUNDEF;
        pExceptionSWI                  =        (u32)ExceptionSWI;
        pExceptionPABORT        =        (u32)ExceptionPABORT;
        pExceptionDABORT        =        (u32)ExceptionDABORT;
#if (VIC_MODE == 1)        //0
        pExceptionIRQ                =        (u32)IsrIRQ;
#else
        pExceptionIRQ                =        (u32)eExceptionIRQ;
#endif
        pExceptionFIQ                =        (u32)ExceptionFIQ;
        INTC_Init();
#if (VIC_MODE == 0)
        SYSTEM_DisableVIC();
#else
        SYSTEM_EnableVIC();
#endif
        SYSTEM_EnableIRQ();
        SYSTEM_EnableFIQ();
以上代码的作用是:既然中断来了直接跳转到_Exception_Vector+0x18地址,那我在这地址里面赋值,赋的值就是中断函数的地址,那也就是执行了我的中断函数。
最后我开启串口中断:
        INTC_SetVectAddr(uart_num, SW_isr);
        INTC_Enable(uart_num);
那么我在PC机上发数据给6410,6410发生串口中断,应为串口中断也是属于普通中断,它也会跳转到eExceptionIRQ执行,一旦执行就会把我的LED灯熄灭,但是我在调试的过程中就没进中断函数 ,我就想不通了,有些兄弟说一定要开启MMU映射,但是我不那么想  ,我想不开启也可以进中断的,现在就是希望各位兄弟能指点下 ,帮我看看我以上的想法对吗?  谢谢各位!
回复评论 (4)
自己在顶下
点赞  2010-5-7 21:50
帮你顶
点赞  2010-5-7 23:13
你的这段是烧录到哪里的?
$HandlerLabel
BLOCK0?BLOCK2?还是在你的代码里边?我有一篇关于ADS下调试中断的文章,你可以去看下,也许对你有帮助
点赞  2010-5-8 01:10
你的CODE跑在DDR里,不过DDR是被映射在0地址上的吗?
如果不是,你把0地址里面的东西读出来看看。
看这里是否存在向二级中断向量表跳转的代码。
点赞  2010-5-8 15:00
    写回复
