[MCU] 【翌创ET6001测评】RTC电子时钟
jinglixixi   2024-10-31 10:22 楼主
翌创ET6001开发板具有RTC计时功能,在使用串口0连接外部USB转TTL模块的情况下,可查看到RTC计时的效果,见图2所示。
图1 串口0接口
图2 测试效果
若将RTC与串行数码管显示模块相结合,则可实现电子时钟的计时效果,其主程序为:
int main(void)
    rtcDatetime calendar;
    uint8_t tick = 0;
    RTC_Calendar_init();
    EVB_SMG_Init();
	Init_MAX7219();
    Write_Max7219(1,1);
    Write_Max7219(2,0);
	Write_Max7219(3,10);
    Write_Max7219(4,0);
    Write_Max7219(5,0);
    Write_Max7219(6,10);
    Write_Max7219(7,0);
    Write_Max7219(8,0);
    while (1)
        RTC_GetDatetime(&calendar);
        if(tick != calendar.second)
            tick = calendar.second;
		    Write_Max7219(1,calendar.second%10);
            Write_Max7219(2,calendar.second/10);
			Write_Max7219(4,calendar.minute%10);
            Write_Max7219(5,calendar.minute/10);
			Write_Max7219(7,calendar.hour%10);
            Write_Max7219(8,calendar.hour/10);
经程序的编译与运行,其效果如图3所示。
图3 电子时钟效果
演示视频:
VID_20241024_130839
回复评论 (2)
优秀啊,点赞
点赞  2024-11-5 17:40
引用: kouko 发表于 2024-11-5 17:40 优秀啊,点赞
感谢支持!!!
点赞  2024-11-8 20:59
    写回复
