谁有51内核无线模块NRF905或NRF2401 C程序
你用的51单片机是带SPI接口的还是不带的?
我朋友用AVR做过,当时跟我讨论过SPI的流程,所以我记得。如果需要,站内短信,我可以帮你要一下。不过他不会帮你移植到51的。你得确认你自己能看懂AVR的,并且能移植。
引用: 引用楼主 qdicao 的帖子:
建议你去www.ouravr.com看看,那里有AVR的成功例子。
不带SPI的51单片机
lbing7你好:给我参孝参孝好吗。谢谢你了:caofeicf@163.com
我有,你直接向他们公司的人要就行了
#include
#include
#include "api.h"
#define uchar unsigned char
#define TX_ADR_WIDTH 5 // 5 bytes TX(RX) address width
#define TX_PLOAD_WIDTH 20 // 20 bytes TX payload
uchar const TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01};
uchar rx_buf[TX_PLOAD_WIDTH];
uchar tx_buf[TX_PLOAD_WIDTH];
uchar flag;
sbit CE = P2^5;
sbit CSN= P2^0;
sbit SCK= P2^1;
sbit MOSI= P2^2;
sbit MISO= P2^3;
sbit IRQ = P3^2;
uchar bdata sta;
sbit RX_DR =sta^6;
sbit TX_DS =sta^5;
sbit MAX_RT =sta^4;
Function: init_io();
Description:
flash led one time,chip enable(ready to TX or RX Mode),
Spi disable,Spi clock line init high
void init_io(void)
P0=0x0f; // led light
CE=0; // chip enable
CSN=1; // Spi disable
SCK=0; // Spi clock line init high
P0=0xff; // led close
Function: Inituart();
Description:
set uart working mode
void Inituart(void)
TMOD = 0x20; //timer1 working mode 1
TL1 = 0xfd; //f7=9600 for 16mhz Fosc,and ...
TH1 = 0xfd; //...fd=19200 for 11.0592mhz Fosc
SCON = 0xd8; //uart mode 3,ren==1
PCON = 0x80; //smod=0
TR1 = 1; //start timer1
Function: init_int0();
Description:
enable int0 interrupt;
void init_int0(void)
EA=1;
EX0=1; // Enable int0 interrupt.
Function: delay100();
Description:
delay 100ms
void delay(uchar )
uchar x;
uchar y;
for(x=0;x<100;x++)
for(y=0;y<100;y++)
_nop_();
Function: SPI_RW();
Description:
Writes one byte to nRF24L01, and return the byte read
from nRF24L01 during write, according to SPI protocol
uchar SPI_RW(uchar byte)
uchar bit_ctr;
for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit
MOSI = (byte & 0x80); // output 'byte', MSB to MOSI
byte = (byte << 1); // shift next bit into MSB..
SCK = 1; // Set SCK high..
byte |= MISO; // capture current MISO bit
SCK = 0; // ..then set SCK low again
return(byte); // return read byte
Function: SPI_RW_Reg();
Description:
Writes value 'value' to register 'reg'
uchar SPI_RW_Reg(BYTE reg, BYTE value)
uchar status;
CSN = 0; // CSN low, init SPI transaction
status = SPI_RW(reg); // select register
SPI_RW(value); // ..and write value to it..
CSN = 1; // CSN high again
return(status); // return nRF24L01 status byte
Function: SPI_Read();
Description:
Read one byte from nRF24L01 register, 'reg'
BYTE SPI_Read(BYTE reg)
BYTE reg_val;
CSN = 0; // CSN low, initialize SPI communication...
SPI_RW(reg); // Select register to read from..
reg_val = SPI_RW(0); // ..then read registervalue
CSN = 1; // CSN high, terminate SPI communication
return(reg_val); // return register value
Function: SPI_Read_Buf();
Description:
Reads 'bytes' #of bytes from register 'reg'
Typically used to read RX payload, Rx/Tx address
uchar SPI_Read_Buf(BYTE reg, BYTE *pBuf, BYTE bytes)
uchar status,byte_ctr;
CSN = 0; // Set CSN low, init SPI tranaction
status = SPI_RW(reg); // Select register to write to and read status byte
for(byte_ctr=0;byte_ctr
pBuf[byte_ctr] = SPI_RW(0); // Perform SPI_RW to read byte from nRF24L01
CSN = 1; // Set CSN high again
Function: SPI_Write_Buf();
Description:
Writes contents of buffer '*pBuf' to nRF24L01
Typically used to write TX payload, Rx/Tx address
uchar SPI_Write_Buf(BYTE reg, BYTE *pBuf, BYTE bytes)
for(byte_ctr=0; byte_ctr
SPI_RW(*pBuf++);
Function: RX_Mode();
Description:
This function initializes one nRF24L01 device to
RX Mode, set RX address, writes RX payload width,
select RF channel, datarate & LNA HCURR.
After init, CE is toggled high, which means that
this device is now ready to receive a datapacket.
void RX_Mode(void)
{ CE=0;
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);
SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // Enable Auto.Ack:Pipe0
SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // Enable Pipe0
SPI_RW_Reg(WRITE_REG + RF_CH, 40); // Select RF channel 40
SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH);
SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // PWR_UP, enable CRC(2 bytes).
CE = 1; // Set CE pin high to enable RX device
Function: TX_Mode();
Description:
TX mode, set TX address, set RX address for auto.ack,
fill TX payload, select RF channel, datarate & TX pwr.
PWR_UP is set, CRC(2 bytes) is enabled, & PRIM:TX.
ToDo: One high pulse(>10us) on CE will now send this
packet and expext an acknowledgment from the RX device.
void TX_Mode(void)
CE=0;
SPI_Write_Buf(WRITE_REG+TX_ADDR,TX_ADDRESS,TX_ADR_WIDTH);//Writes TX_Address
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // RX_Addr0 same as
TX_Adr for Auto.Ack
SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // Writes data to TX payload
SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1a); // 500us + 86us, 10 retrans...
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // Set PWR_UP bit, enable CRC(2 bytes).
CE=1;
Function: check_ACK();
Description:
check if have "Data sent TX FIFO interrupt",if TX_DS=1,
all led light and after delay 100ms all led close
void check_ACK()
uchar test;
test=SPI_Read(READ_REG+STATUS); // read register STATUS's
test=test&0x20; // check if have Data sent TX FIFO interrupt (TX_DS=1)
if(test==0x20) // TX_DS =1
P0=0x00; // turn on all led
delay100(); // delay 100ms
P0=0xff;
Function: TxData();
Description:
write data x to SBUF
void TxData (uchar x)
SBUF=x; // write data x to SBUF
while(TI==0);
TI=0;
Function: CheckButtons();
Description:
check buttons ,if have press,read the key values,
turn on led and transmit it; after transmition,
if received ACK, clear TX_DS interrupt and enter RX Mode;
turn off the led
void CheckButtons()
uchar Temp,xx,Tempi;
P0=0xff;
Temp=P0&0x0f; //read key value from port P0
if (Temp!=0x0f)
delay_ms(10);
Temp=P0&0x0f; // read key value from port P0
if (Temp!=0x0f)
xx=Temp;
Tempi=Temp<<4; // Left shift 4 bits
P0=Tempi; // Turn On the led
tx_buf[0]=Tempi; // Save to tx_buf[0]
TX_Mode(); // set TX Mode and transmitting
TxData(xx); // send data to uart
//check_ACK(); // if have acknowledgment from RX device,turn on all led
SPI_RW_Reg(WRITE_REG+STATUS,SPI_Read(READ_REG+STATUS));
delay_ms(200);
P0=0xff; // Turn off the led
RX_Mode(); // set receive mode
while((P0&0x0f)!=0x0f);
Function: main();
Description:
control all subprogrammes;
void main(void)
uchar xx;
init_io(); // Initialize IO port
Inituart(); // initialize 232 uart
init_int0(); // enable int0 interrupt
RX_Mode(); // set RX mode
while(1)
CheckButtons(); // scan key value and transmit
if(flag) // finish received
flag=0; // set flag=0
P0=rx_buf[0]; // turn on led
delay_ms(200);
P0=0xff; // turn off led
xx=rx_buf[0]>>4;// right shift 4 bits
Function: ISR_int0() interrupt 0;
Description:
if RX_DR=1 or TX_DS or MAX_RT=1,enter this subprogram;
if RX_DR=1,read the payload from RX_FIFO and set flag;
void ISR_int0(void) interrupt 0
sta=SPI_Read(STATUS); // read register STATUS's value
if(RX_DR) // if receive data ready (RX_DR) interrupt
SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);//Read receive payload
flag=1;
if(MAX_RT)
SPI_RW_Reg(FLUSH_TX,0);
SPI_RW_Reg(WRITE_REG+STATUS,sta);// clear RX_DR or TX_DS or MAX_RT interrupt flag
api.h
// BYTE type definition
#ifndef _BYTE_DEF_
#define _BYTE_DEF_
typedef unsigned char BYTE;
#endif /* _BYTE_DEF_ */
// SPI(nRF24L01) commands
#define READ_REG 0x00 // Define read command to register
#define WRITE_REG 0x20 // Define write command to register
#define RD_RX_PLOAD 0x61 // Define RX payload register address
#define WR_TX_PLOAD 0xA0 // Define TX payload register address
#define FLUSH_TX 0xE1 // Define flush TX register command
#define FLUSH_RX 0xE2 // Define flush RX register command
#define REUSE_TX_PL 0xE3 // Define reuse TX payload register command
#define NOP 0xFF // Define No Operation, might be used to read status register
// SPI(nRF24L01) registers(addresses)
#define CONFIG 0x00 // 'Config' register address
#define EN_AA 0x01 // 'Enable Auto Acknowledgment' register address
#define EN_RXADDR 0x02 // 'Enabled RX addresses' register address
#define SETUP_AW 0x03 // 'Setup address width' register address
#define SETUP_RETR 0x04 // 'Setup Auto. Retrans' register address
#define RF_CH 0x05 // 'RF channel' register address
#define RF_SETUP 0x06 // 'RF setup' register address
#define STATUS 0x07 // 'Status' register address
#define OBSERVE_TX 0x08 // 'Observe TX' register address
#define CD 0x09 // 'Carrier Detect' register address
#define RX_ADDR_P0 0x0A // 'RX address pipe0' register address
#define RX_ADDR_P1 0x0B // 'RX address pipe1' register address
#define RX_ADDR_P2 0x0C // 'RX address pipe2' register address
#define RX_ADDR_P3 0x0D // 'RX address pipe3' register address
#define RX_ADDR_P4 0x0E // 'RX address pipe4' register address
#define RX_ADDR_P5 0x0F // 'RX address pipe5' register address
#define TX_ADDR 0x10 // 'TX address' register address
#define RX_PW_P0 0x11 // 'RX payload width, pipe0' register address
#define RX_PW_P1 0x12 // 'RX payload width, pipe1' register address
#define RX_PW_P2 0x13 // 'RX payload width, pipe2' register address
#define RX_PW_P3 0x14 // 'RX payload width, pipe3' register address
#define RX_PW_P4 0x15 // 'RX payload width, pipe4' register address
#define RX_PW_P5 0x16 // 'RX payload width, pipe5' register address
#define FIFO_STATUS 0x17 // 'FIFO Status Register' register address
// FUNCTION's PROTOTYPES //
void SPI_Init(BYTE Mode); // Init HW or SW SPI
BYTE SPI_RW(BYTE byte); // Single SPI read/write
BYTE SPI_Read(BYTE reg); // Read one byte from nRF24L01
BYTE SPI_RW_Reg(BYTE reg, BYTE byte); // Write one byte to register 'reg'
BYTE SPI_Write_Buf(BYTE reg, BYTE *pBuf, BYTE bytes); // Writes multiply bytes to one register
BYTE SPI_Read_Buf(BYTE reg, BYTE *pBuf, BYTE bytes); // Read multiply bytes from one register
这是他们的一个用2401的模块的程序PTRxxx,你最好买模块,模块比IC简单
建议楼主还是看看芯片的datasheet,里面讲的很详细,连PCB布板都有图给你,你这样套用别人的程序调试的时候不通你都不知道从哪找原因,其实时间耽误的更多
我不是想套用。我没有做过这个想参考一下。你位老大有中文注释的。谢了
引用: 引用 14 楼 qdicao 的回复:
我觉要走的远,就不能老抄袭程序,自己狠下功夫,看数据手册,自己写出来。
无非是左移右移,以及一些高低电平时序控制问题。
各位老大,spi 比i2c筒单多了,我英语不好。所以看看各位程序。
