Platform 配置环境后出现的fatal error U1077错误
amountain   2008-10-13 01:24 楼主
Building combined coredll res file for 0409
        res2res %COREDLL_RESOURCES% -fo C:\WINCE600\OSDesigns\EBOX2003TEST\EBOX2003TEST\Wince600\ICOP_Vortex86_60B_x86\cesysgen\oak\target\x86\retail\0409\coredll.res
Res2Res for Windows CE (Release) (Built on Jun 30 2006 16:52:50)
Copyright (C) Microsoft Corp. 1991-2004.  All rights reserved.
Res2Res: Using C:\WINCE600\public\common\oak\Bin\i386\R2RDUMMY.DLL for temp exe
Res2Res: Using resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\coreres.res.
Res2Res: Adding resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\coreres.res to C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\R2R15.tmp.
Res2Res: Using resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\shcore.res.
Res2Res: Adding resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\shcore.res to C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\R2R15.tmp.
Res2Res: Using resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\shortcut.res.
Res2Res: Adding resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\shortcut.res to C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\R2R15.tmp.
Res2Res: Using resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\shexec.res.
Res2Res: Adding resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\shexec.res to C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\R2R15.tmp.
Res2Res: Using resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\shmisc.res.
Res2Res: Adding resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\shmisc.res to C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\R2R15.tmp.
Res2Res: Using resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\timezones.res.
Res2Res: Adding resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\timezones.res to C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\R2R15.tmp.
Res2Res: Using resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\coreloc.res.
Res2Res: Adding resources from C:\WINCE600\public\common\oak\lib\x86\retail\0409\coreloc.res to C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\R2R15.tmp.
Res2Res: Building C:\WINCE600\OSDesigns\EBOX2003TEST\EBOX2003TEST\Wince600\ICOP_Vortex86_60B_x86\cesysgen\oak\target\x86\retail\0409\coredll.res from temp file C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\R2R15.tmp.
Res2Res: Error extracting resources from temp file (3: unknown)
NMAKE : fatal error U1077: 'res2res' : return code '0x3'
Stop.
刚刚接触eBox 完全搞不明白这个错误是哪里来的
回复评论 (2)
QUARTZ0_COMPONENTS=amutil fgctl filgraph
QUARTZ1_COMPONENTS= waveout wavemsr mp3filter mpgsplit acmwrap dmowrap image urlrdr
QUARTZ2_COMPONENTS=asyncrdr qtzbase
QUARTZ3_COMPONENTS= scmdout filerend wmt_strmcore wmt_splitter acmobj icmobj m3uplayl asxplayl xmlplayl urlgrab urlobj nscfileparser wmt_httpstrm wmt_mmsstrm wmt_msbstrm wmt_nethelp wmt_filestrm
MSDXM_COMPONENTS=toolbar statbar bkgndbmp
DATASYNC_MODULES= wceload unloadNETCFV2_MODULES= dotnetv2
这个是编辑的时候 出现的错误提示
点赞  2008-10-13 01:40
用Clean Sysgen编译一下应该会过。
点赞  2009-2-18 09:14
    写回复
