瞬联软件招聘,杭州职位,待遇从优!!顶者有分
chen_jia_   2008-2-14 11:37 楼主
简历发给neilxp@163.com
WiMAX AP S/W: (4)         Location: Hangzhou
Job Description:
Looking for experienced embedded software Engineer with solid telecommunication background.
Job Responsibilities:
Design, implement and test lower level MAC and SCH algorithms and features;
Simulate performance of design, particularly MAC and scheduler.
Update the access protocol to minimize latency & maximize throughput & utilization.
Job Requirements:
Strong proficiency in C and VxWorks
1+ years experience with MAC design & simulation (not limited in WiMax)
MSEE/CS with 2+ years exp. or BSEE/CS with 3+ years exp.
Strong communication and interpersonal skills to work effectively
Additional Desirable Skills:
Familiarity with OFDMA PHY/MAC and WiMax profiles;
Wireless MAC design experience;
Ability to logically and methodically develop and analyze access protocols
Ability to write clear and accurate technical papers in English
Over-sea work experience.
Dimetra development Engineer(2)      Location: Hangzhou
Description      Responsible for developing the new features for Dimetra system
Requirement    Be familiar with core network and radio access network of mobile communication such as AuC, HLR, VLR, MSC, BSC, RNC etc,
Experience of core network element development is a plus.
.Unix scripting
.Professional in C/C++ programming
.Protocols: TCP/IP, UDP
.Windows programming in C/C++ (for DGUT and ATS)
.Tetra, iDen, Gota, GT800 Standard (Plus)
.Familiar with Clear case tool.
.BS or MS in Computer Science, Telecommunication Engineering or equivalent
.Good communication skills in Chinese and English
CDMA AEMS Test ENGINEER (2)      Location: Hangzhou
Description      ·Setting up the necessary test equipment
· Writing test scripts
· Carrying out tests (some automated, some manual)
· Perform System Test, Integration Test, Unit Test (where applicable), Performance Testing, Field Trial
·Initial analysis of problems found
·Writing test reports
·Verification of bug fixes
· Inter-operability testing to ensure product works with newly released AP loads
Requirement
·A minimum of 2-3 years structured software testing experience is required
· The ability to interpret published detail requirements and design efficient test cases
·Ability to work independently
·A good understanding of GSM/CDMA and Telecommunication networks in general
·Experience of writing test strategy, test cases and test scripts
·A methodical approach to carrying out tests and recording the results
· Good knowledge in UNIX, shell scripts
·Knowledge in Test automation tools
·Candidate must have the confidence and drive to work alongside development teams as either the sole tester or part of a small test team
· Should be comfortable working in a dynamic and technically complex domain
· Excellent command in English, verbal and written
回复评论 (8)
可惜我是北京的
点赞  2008-2-15 11:39
顶了,接分
点赞  2008-2-15 22:24
Ding
点赞  2008-2-17 11:32
点赞  2008-2-20 14:13
过年了!!!
有分拿了~~
点赞  2008-2-25 16:44
I like it!
点赞  2008-2-28 15:27
接分
点赞  2008-2-28 21:06
点赞  2008-3-2 22:52
    写回复
