SD专家gsymichae请进:关于 SDwifi
stoutstone   2008-11-24 13:49 楼主
gsymichae兄:
    现在的状态是:加上SDIO_INTERRUPT_CHECK_ON(pController);后
     在case SDHCDAckSDIOInterrupt:中打印两条SDControl.c_SDHSlotOptionHandler:SDIO INT (still)!
     又进入else打印一条SDControl.c_SDHSlotOptionHandler:into else if,之后不知道进哪就死掉了(SD卡不死)
     具体代码如下: case SDHCDAckSDIOInterrupt:
                           // acquire the lock to block the SDIO interrupt thread
            ACQUIRE_LOCK(pController);
            if ( ( pController->pSDMMCRegisters->stat & 0x8000 ) &&
                 ( pController->pSDMMCRegisters->ireg & 0x0800 ) &&
                 pController->fSDIOEnabled )
                 RETAILMSG(1, (TEXT("SDControl.c_SDHSlotOptionHandler:SDIO INT (still)!\r\n")));
                SDHCDIndicateSlotStateChange(pController->pHCContext,
                                                0,
                                                DeviceInterrupting);
            else if( pController->fSDIOEnabled )
                         RETAILMSG(1, (TEXT("SDControl.c_SDHSlotOptionHandler:into else if!\r\n")));
                                          SDIO_INTERRUPT_ON(pController);
                                  SDIO_INTERRUPT_CHECK_ON(pController);//wx_20081122
                                 pController->fSDIOEnabled = TRUE;
回复评论 (5)
帮顶
点赞  2008-11-24 14:00
搞定了
揭贴接分啦
点赞  2008-11-25 12:00
强。说说怎么搞定的。
点赞  2008-11-25 12:11
对把经验分享一下
点赞  2008-11-25 12:33
是硬件问题
估计我试的那个板子硬件上有缺陷(应该是电源问题)
把程序烧到新修改的板子里就可以上网了
非常感谢gsymichael 兄这两天帮我调试!!!
点赞  2008-11-25 13:35
    写回复
