为什么我的串口总丢数据
hbbyq111   2008-8-5 11:23 楼主
我用的单片机是renesas的r8c/25,和gprs通信接收到的数据总是丢字符,没有规律!接收是用的中断,优先级是最高,另外程序还有个Timer中断
void SendCommandToGPRS( unsigned char *Data )
        unsigned char count = 0;
        while ( Data[count] )
                PutCharToGPRS(Data[count]);
                count++;
void InitGPRSSerial( void )
        /* Setting port direction registers */
        pd1 = pd1 | 0x10;                                        /* TXD0 port direction = output */
        pd1 = pd1 & 0xDF;                                        /* RXD0 port direction = input */
//        pu03 = 1;
/*        tiosel_traioc = 0;
        tmod2_tramr = 0;
        tmod1_tramr = 0;
        tmod0_tramr =1;
        u0mr = 0x05;                                                /* UART mode transfer data 8 bits long */
        /* 1 stop bit */
        /* Parity disabled */
        u0c0 = 0x00;                                                /* BRG count sorce :"f1" */
        /* TXD0 pin is for CMOS output */
        /* LSB first */
        u0c1 = 0x10;                                                /* Disables transmission */
        /* Disables reception */
        /* Transmission buffer empty causes UART0 transmit interrupt */
        u0brg = 0x26;                                                /* 6MHz/16*(38+1)=9615.3846153846 */
        s0tic = 0x00;                                                /* Disable UART0 transmit Interrupt */
        s0ric = 0x07;                                                /* enable UART0 receive Interrupt */
        /*interrupt priority level select is 7*/
        te_u0c1 = 1;                                                /* Enables transmission */
        re_u0c1 = 1;                                                /* Enables reception */
#pragma INTERRUPT RevDataGPRS
void RevDataGPRS(void)
        /* GPS mode Receive */
        unsigned short rcv_work;
//        static unsigned char CheckLineBuf[3];
//        static unsigned char CheckTimes = 0;
        rcv_work = u0rb;                                        /* Read out the U0RB register in 16-bit units */
        if ( (unsigned char)rcv_work == '\n' || (unsigned char)rcv_work == '\r' )
/*                CheckLineBuf[CheckTimes] = (unsigned char)rcv_work;
                if ( CheckTimes >= 1 )
                        CheckTimes = 0;
                        if ( CheckLineBuf[0] == '\r' )
                                if ( CheckLineBuf[1] == '\n' )
                                        ReceiveALine = 0x01;
                CheckTimes++;*/
        else
//                CheckTimes = 0;
                ReceiveALine = 0x00;
        REV_GPRS_BUF[RevGPRSCnt] = (unsigned char)rcv_work;
        RevGPRSCnt++;
        if ( RevGPRSCnt >= REV_GPRS_SIZE )
                RevGPRSCnt = 0;
回复评论 (8)
贴出来的代码不是很全,看你现在的代码,去除注释掉的部分后,可以看出,如果gprs接收到的是换行回车,那么你都认为是接受到数据了!但是据我知道的,一帮情况下,接受函数会考虑如何过滤掉这样的没有实际意义的字符,包括在接收的过程中间过滤转义字符!
点赞  2008-8-6 22:37
可能是流控问题,即如果buffer满了的情况程序可能不再接受数据或可能出现溢出
点赞  2008-11-15 21:07
点赞  2008-11-16 12:37
先看看丢掉的字符数据有和规律,1楼说的很有可能。
点赞  2008-11-23 00:28
顶一楼的,从你现在的代码看,不像是缓存区的问题
点赞  2008-11-23 08:37
学习。
点赞  2008-11-28 15:36
硬件有没有问题?用示波器看看,看你的电平是不是很直? 还是有干扰?
点赞  2008-11-29 13:32
mark
点赞  2008-12-4 09:03
    写回复
